[Swift-commit] r3480 - trunk/src/org/griphyn/vdl/karajan
noreply at svn.ci.uchicago.edu
Tue Jul 27 21:56:41 CDT 2010
Author: hategan
Date: 2010-07-27 21:56:41 -0500 (Tue, 27 Jul 2010)
New Revision: 3480
Modified:
trunk/src/org/griphyn/vdl/karajan/ArrayIndexFutureList.java
Log:
the copy on write set is a waste of resources since addition can never happen when iterating over listeners
Modified: trunk/src/org/griphyn/vdl/karajan/ArrayIndexFutureList.java
--- trunk/src/org/griphyn/vdl/karajan/ArrayIndexFutureList.java 2010-07-28 01:43:34 UTC (rev 3479)
+++ trunk/src/org/griphyn/vdl/karajan/ArrayIndexFutureList.java 2010-07-28 02:56:41 UTC (rev 3480)
@@ -5,7 +5,8 @@
import java.util.ArrayList;
import java.util.HashSet;
-import java.util.Iterator;
+import java.util.LinkedList;
+import java.util.List;
import java.util.Map;
import java.util.Set;
@@ -19,155 +20,146 @@
import org.globus.cog.karajan.workflow.futures.FutureIterator;
import org.globus.cog.karajan.workflow.futures.FutureList;
import org.globus.cog.karajan.workflow.futures.FutureNotYetAvailable;
-import org.globus.cog.util.CopyOnWriteHashSet;
import org.griphyn.vdl.mapping.DSHandle;
import org.griphyn.vdl.mapping.DSHandleListener;
public class ArrayIndexFutureList implements FutureList, DSHandleListener {
- private ArrayList keys;
- private Map values;
- private boolean closed;
- private CopyOnWriteHashSet listeners;
- private FutureEvaluationException exception;
+ private ArrayList<Object> keys;
+ private Map values;
+ private boolean closed;
+ private List<EventTargetPair> listeners;
+ private FutureEvaluationException exception;
- public ArrayIndexFutureList(DSHandle handle, Map values) {
- this.values = values;
- keys = new ArrayList();
- handle.addListener(this);
- private RuntimeException notYetAvailable() {
- if (exception != null) {
- return exception;
- return new FutureNotYetAvailable(this);
+ public ArrayIndexFutureList(DSHandle handle, Map values) {
+ this.values = values;
+ keys = new ArrayList<Object>();
+ handle.addListener(this);
- public Object get(int index) {
- throw exception;
- if (!closed && index >= keys.size()) {
- throw notYetAvailable();
- else {
- Object key = keys.get(index);
- return new Pair(key, values.get(key));
+ private RuntimeException notYetAvailable() {
+ if (exception != null) {
+ return exception;
+ return new FutureNotYetAvailable(this);
- public int available() {
- return keys.size();
+ public Object get(int index) {
+ throw exception;
+ if (!closed && index >= keys.size()) {
+ throw notYetAvailable();
+ else {
+ Object key = keys.get(index);
+ return new Pair(key, values.get(key));
- public void addKey(Object key) {
- keys.add(key);
- notifyListeners();
+ public int available() {
+ return keys.size();
- public FutureIterator futureIterator() {
- return new FuturePairIterator(this);
+ public void addKey(Object key) {
+ keys.add(key);
+ notifyListeners();
- public FutureIterator futureIterator(VariableStack stack) {
- return new FuturePairIterator(this, stack);
+ public FutureIterator futureIterator() {
+ return new FuturePairIterator(this);
- public synchronized void close() {
- closed = true;
- Set allkeys = new HashSet(values.keySet());
- Iterator i = keys.iterator();
- while (i.hasNext()) {
- allkeys.remove(i.next());
- // remaining keys must be added
- i = allkeys.iterator();
- keys.add(i.next());
+ public FutureIterator futureIterator(VariableStack stack) {
+ return new FuturePairIterator(this, stack);
- public boolean isClosed() {
- return closed;
+ public synchronized void close() {
+ closed = true;
+ Set<Object> allkeys = new HashSet<Object>(values.keySet());
+ allkeys.removeAll(keys);
+ // remaining keys must be added
+ keys.addAll(allkeys);
- public Object getValue() throws VariableNotFoundException {
- return this;
+ public boolean isClosed() {
+ return closed;
- public synchronized void addModificationAction(EventListener target, Event event) {
- if (listeners == null) {
- listeners = new CopyOnWriteHashSet();
+ public Object getValue() throws VariableNotFoundException {
+ return this;
- listeners.add(new EventTargetPair(event, target));
- if (closed) {
+ public synchronized void addModificationAction(EventListener target,
+ Event event) {
+ if (listeners == null) {
+ listeners = new LinkedList<EventTargetPair>();
- private synchronized void notifyListeners() {
- return;
+ listeners.add(new EventTargetPair(event, target));
+ if (closed) {
- Iterator i = listeners.iterator();
- try {
- try {
- EventTargetPair etp = (EventTargetPair) i.next();
- etp.getTarget().event(etp.getEvent());
- catch (ExecutionException e) {
- e.printStackTrace();
- finally {
- listeners.release();
+ private synchronized void notifyListeners() {
+ return;
- public EventTargetPair[] getListenerEvents() {
- return (EventTargetPair[]) listeners.toArray(new EventTargetPair[0]);
+ for (EventTargetPair etp : listeners) {
+ try {
+ etp.getTarget().event(etp.getEvent());
+ catch (ExecutionException e) {
+ e.printStackTrace();
+ listeners = null;
- public int size() {
- if (closed) {
- else {
+ public EventTargetPair[] getListenerEvents() {
+ return listeners.toArray(new EventTargetPair[0]);
- public String toString() {
- String l;
- l = "no listeners";
- else {
- l = listeners.size() + " listeners";
- if (!closed) {
- return "Open, " + keys.size() + " elements, " + l;
- else {
- return "Closed, " + keys.size() + " elements, " + l;
- public void fail(FutureEvaluationException e) {
- this.exception = e;
- public FutureEvaluationException getException() {
- return exception;
+ public int size() {
+ if (closed) {
+ else {
- public void handleClosed(DSHandle handle) {
- close();
+ public String toString() {
+ String l;
+ l = "no listeners";
+ else {
+ l = listeners.size() + " listeners";
+ if (!closed) {
+ return "Open, " + keys.size() + " elements, " + l;
+ else {
+ if (listeners != null) {
+ System.out.println("Badness");
+ return "Closed, " + keys.size() + " elements, " + l;
+ public void fail(FutureEvaluationException e) {
+ this.exception = e;
+ public FutureEvaluationException getException() {
+ return exception;
+ public void handleClosed(DSHandle handle) {
+ close();
More information about the Swift-commit
