[Swift-commit] r3478 - in trunk: libexec src/org/griphyn/vdl/engine src/org/griphyn/vdl/karajan/lib/swiftscript
noreply at svn.ci.uchicago.edu
Tue Jul 27 20:11:31 CDT 2010
Author: jonmon
Date: 2010-07-27 20:11:31 -0500 (Tue, 27 Jul 2010)
New Revision: 3478
Modified:
trunk/libexec/vdl-lib.xml
trunk/src/org/griphyn/vdl/engine/ProcedureSignature.java
trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java
Log:
o trunk/src/org/griphyn/vdl/engine/ProcedureSignature.java
o trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java
o trunk/libexec/vdl-lib.xml
-- Added format function. Takes in a float and formats to desired precision which it returns as a string.
-- Added pad function. Pads arbitrary number of zeros to the front of an int and return a string.
-- Added length fucntion. Returns the number of elements of a closed list.
-- toint and tofloat are now polymorphic. They will try to convert anything to an int or float respectively.
If they can't they return an ExecutionException.
Modified: trunk/libexec/vdl-lib.xml
--- trunk/libexec/vdl-lib.xml 2010-07-27 19:21:35 UTC (rev 3477)
+++ trunk/libexec/vdl-lib.xml 2010-07-28 01:11:31 UTC (rev 3478)
@@ -13,6 +13,8 @@
<export name="regexp"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
<export name="toint"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
<export name="tofloat"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
+ <export name="format"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
+ <export name="pad"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
<export name="tostring"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
<export name="trace"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
<export name="tracef"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Tracef"/></export>
@@ -20,6 +22,7 @@
<export name="fileName"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.FileName"/></export>
<export name="fileNames"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.FileNames"/></export>
<export name="dirname"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
+ <export name="length"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
<export name="arg">
<import file="sys.xml"/>
<if>
Modified: trunk/src/org/griphyn/vdl/engine/ProcedureSignature.java
--- trunk/src/org/griphyn/vdl/engine/ProcedureSignature.java 2010-07-27 19:21:35 UTC (rev 3477)
+++ trunk/src/org/griphyn/vdl/engine/ProcedureSignature.java 2010-07-28 01:11:31 UTC (rev 3478)
@@ -194,6 +194,13 @@
FormalArgumentSignature dirnameOut1 = new FormalArgumentSignature("string");
dirname.addOutputArg(dirnameOut1);
functionsMap.put(dirname.getName(), dirname);
+ ProcedureSignature length = new ProcedureSignature("length");
+ FormalArgumentSignature lengthIn1 = new FormalArgumentSignature(true);
+ length.addInputArg(lengthIn1);
+ FormalArgumentSignature lengthOut1 = new FormalArgumentSignature("int");
+ length.addOutputArg(lengthOut1);
+ functionsMap.put(length.getName(), length);
ProcedureSignature regexp = new ProcedureSignature("regexp");
FormalArgumentSignature regexpIn1 = new FormalArgumentSignature("string");
@@ -240,19 +247,37 @@
functionsMap.put(strsplit.getName(), strsplit);
ProcedureSignature toint = new ProcedureSignature("toint");
- FormalArgumentSignature tointIn1 = new FormalArgumentSignature("string");
+ FormalArgumentSignature tointIn1 = new FormalArgumentSignature(true);
toint.addInputArg(tointIn1);
FormalArgumentSignature toOut1 = new FormalArgumentSignature("int");
toint.addOutputArg(toOut1);
functionsMap.put(toint.getName(), toint);
ProcedureSignature tofloat = new ProcedureSignature("tofloat");
- FormalArgumentSignature tofloatIn1 = new FormalArgumentSignature("string");
+ FormalArgumentSignature tofloatIn1 = new FormalArgumentSignature(true);
tofloat.addInputArg(tofloatIn1);
FormalArgumentSignature tofloatOut1 = new FormalArgumentSignature("float");
tofloat.addOutputArg(tofloatOut1);
functionsMap.put(tofloat.getName(), tofloat);
+ ProcedureSignature format = new ProcedureSignature("format");
+ FormalArgumentSignature formatIn1 = new FormalArgumentSignature("float");
+ FormalArgumentSignature formatIn2 = new FormalArgumentSignature("int");
+ format.addInputArg(formatIn1);
+ format.addInputArg(formatIn2);
+ FormalArgumentSignature formatOut = new FormalArgumentSignature("string");
+ format.addOutputArg(formatOut);
+ functionsMap.put(format.getName(), format);
+ ProcedureSignature pad = new ProcedureSignature("pad");
+ FormalArgumentSignature padIn1 = new FormalArgumentSignature("int");
+ FormalArgumentSignature padIn2 = new FormalArgumentSignature("int");
+ pad.addInputArg(padIn1);
+ pad.addInputArg(padIn2);
+ FormalArgumentSignature padOut = new FormalArgumentSignature("string");
+ pad.addOutputArg(padOut);
+ functionsMap.put(pad.getName(), pad);
ProcedureSignature tostring = new ProcedureSignature("tostring");
FormalArgumentSignature tostringIn1 = new FormalArgumentSignature(true);
tostring.addInputArg(tostringIn1);
Modified: trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java
--- trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java 2010-07-27 19:21:35 UTC (rev 3477)
+++ trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java 2010-07-28 01:11:31 UTC (rev 3478)
@@ -1,6 +1,8 @@
package org.griphyn.vdl.karajan.lib.swiftscript;
import java.io.IOException;
+import java.util.List;
+import java.util.ArrayList;
import java.util.regex.Matcher;
import java.util.regex.Pattern;
@@ -26,6 +28,8 @@
import org.griphyn.vdl.mapping.AbsFile;
import org.globus.cog.karajan.workflow.futures.FutureNotYetAvailable;
+import org.griphyn.vdl.mapping.ArrayDataNode;
public class Misc extends FunctionsCollection {
private static final Logger logger = Logger.getLogger(Misc.class);
@@ -43,8 +47,11 @@
setArguments("swiftscript_regexp", new Arg[] { PA_INPUT, PA_PATTERN, PA_TRANSFORM });
setArguments("swiftscript_toint", new Arg[] { PA_INPUT });
setArguments("swiftscript_tofloat", new Arg[] { PA_INPUT });
+ setArguments("swiftscript_format", new Arg[] { PA_INPUT, PA_TRANSFORM });
+ setArguments("swiftscript_pad", new Arg[] { PA_INPUT, PA_TRANSFORM });
setArguments("swiftscript_tostring", new Arg[] { PA_INPUT });
setArguments("swiftscript_dirname", new Arg[] { Arg.VARGS });
+ setArguments("swiftscript_length", new Arg[] { Arg.VARGS });
private static final Logger traceLogger = Logger.getLogger("org.globus.swift.trace");
@@ -206,8 +213,17 @@
inputString = inputString.substring(0, i);
DSHandle handle = new RootDataNode(Types.INT);
- handle.setValue(new Double(inputString));
+ try
+ handle.setValue(new Double(inputString));
+ catch(NumberFormatException e)
+ throw new ExecutionException(stack, "Could not convert value \""+inputString+"\" to type int");
handle.closeShallow();
int provid=VDLFunction.nextProvenanceID();
VDLFunction.logProvenanceResult(provid, handle, "toint");
VDLFunction.logProvenanceParameter(provid, PA_INPUT.getRawValue(stack), "string");
@@ -218,7 +234,15 @@
InvalidPathException {
String inputString = TypeUtil.toString(PA_INPUT.getValue(stack));
DSHandle handle = new RootDataNode(Types.FLOAT);
+ try
+ throw new ExecutionException(stack, "Could not convert value \""+inputString+"\" to type float");
VDLFunction.logProvenanceResult(provid, handle, "tofloat");
@@ -226,6 +250,50 @@
return handle;
+ * Takes in a float and formats to desired precision and returns a string
+ public DSHandle swiftscript_format(VariableStack stack) throws ExecutionException, NoSuchTypeException,
+ InvalidPathException {
+ String inputString = TypeUtil.toString(PA_INPUT.getValue(stack));
+ String inputFormat = TypeUtil.toString(PA_TRANSFORM.getValue(stack));
+ DSHandle handle = new RootDataNode(Types.STRING);
+ String output = String.format("%."+inputFormat+"f", Double.parseDouble(inputString));
+ handle.setValue(output);
+ handle.closeShallow();
+ int provid=VDLFunction.nextProvenanceID();
+ VDLFunction.logProvenanceResult(provid, handle, "format");
+ VDLFunction.logProvenanceParameter(provid, PA_INPUT.getRawValue(stack), "float");
+ VDLFunction.logProvenanceParameter(provid, PA_TRANSFORM.getRawValue(stack), "float");
+ return handle;
+ * Takes in an int and pads zeros to the left and returns a string
+ public DSHandle swiftscript_pad(VariableStack stack) throws ExecutionException, NoSuchTypeException,
+ int num_length = inputString.length();
+ int zeros_to_pad = Integer.parseInt(inputFormat);
+ zeros_to_pad += num_length;
+ String output = String.format("%0"+zeros_to_pad+"d", Integer.parseInt(inputString));
+ VDLFunction.logProvenanceResult(provid, handle, "pad");
+ VDLFunction.logProvenanceParameter(provid, PA_INPUT.getRawValue(stack), "int");
+ VDLFunction.logProvenanceParameter(provid, PA_TRANSFORM.getRawValue(stack), "int");
+ return handle;
public DSHandle swiftscript_tostring(VariableStack stack)
@@ -236,26 +304,51 @@
return handle;
- public DSHandle swiftscript_dirname(VariableStack stack)
- throws ExecutionException, NoSuchTypeException, InvalidPathException {
- DSHandle handle;
- try
- DSHandle[] args = SwiftArg.VARGS.asDSHandleArray(stack);
- DSHandle arg = args[0];
- String[] input = VDLFunction.filename(arg);
- String name = input[0];
- String result = new AbsFile(name).getDir();
- handle = new RootDataNode(Types.STRING);
- handle.setValue(result);
- handle.closeShallow();
- catch (HandleOpenException e) {
- throw new FutureNotYetAvailable
- (VDLFunction.addFutureListener(stack, e.getSource()));
- return handle;
+ public DSHandle swiftscript_dirname(VariableStack stack)
+ throws ExecutionException, NoSuchTypeException, InvalidPathException {
+ DSHandle handle;
+ try
+ DSHandle[] args = SwiftArg.VARGS.asDSHandleArray(stack);
+ DSHandle arg = args[0];
+ String[] input = VDLFunction.filename(arg);
+ String name = input[0];
+ String result = new AbsFile(name).getDir();
+ handle = new RootDataNode(Types.STRING);
+ handle.setValue(result);
+ catch (HandleOpenException e) {
+ throw new FutureNotYetAvailable
+ (VDLFunction.addFutureListener(stack, e.getSource()));
+ return handle;
+ * This is copied from swiftscript_dirname. Both the functions could be changed to be more readable.
+ * Returns length of an array.
+ * Good for debugging because array needs to be closed before the length is determined
+ public DSHandle swiftscript_length(VariableStack stack)
+ DSHandle handle;
+ DSHandle[] args = SwiftArg.VARGS.asDSHandleArray( stack );
+ ArrayDataNode adn = (ArrayDataNode)arg;
+ if( !( adn.isClosed() ) )
+ throw new FutureNotYetAvailable( VDLFunction.addFutureListener( stack, adn ) );
+ int result = adn.size();
+ handle = new RootDataNode(Types.INT);
+ return handle;
More information about the Swift-commit
