[Swift-commit] r3431 - in trunk: libexec resources src/org/griphyn/vdl/engine src/org/griphyn/vdl/karajan/lib/swiftscript
noreply at svn.ci.uchicago.edu
Sat Jul 10 22:38:07 CDT 2010
Author: jonmon
Date: 2010-07-10 22:38:07 -0500 (Sat, 10 Jul 2010)
New Revision: 3431
Modified:
trunk/libexec/vdl-lib.xml
trunk/resources/swiftscript.g
trunk/src/org/griphyn/vdl/engine/Karajan.java
trunk/src/org/griphyn/vdl/engine/ProcedureSignature.java
trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java
Log:
o src/org/griphyn/vdl/engine/Karajan.java
o resources/swiftscript.g
-- Modifications to allow the import directive to accept a relative or absolute path to the script being imported.
o src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java
o src/org/griphyn/vdl/engine/ProcedureSignature.java
o libexec/vdl-lib.xml
-- Added tofloat function. Takes in a string and converts the string to a floating point type.
-- Added %f to tracef. This allows tracef to print out the floating point type.
-- Fixed toint function. When a floating type string representation was passed to toint, the value was not truncated, an error was thrown instead.
Modified: trunk/libexec/vdl-lib.xml
--- trunk/libexec/vdl-lib.xml 2010-07-08 02:19:22 UTC (rev 3430)
+++ trunk/libexec/vdl-lib.xml 2010-07-11 03:38:07 UTC (rev 3431)
@@ -12,6 +12,7 @@
<export name="strsplit"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
<export name="regexp"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
<export name="toint"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
+ <export name="tofloat"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
<export name="tostring"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
<export name="trace"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
<export name="tracef"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
Modified: trunk/resources/swiftscript.g
--- trunk/resources/swiftscript.g 2010-07-08 02:19:22 UTC (rev 3430)
+++ trunk/resources/swiftscript.g 2010-07-11 03:38:07 UTC (rev 3431)
@@ -78,7 +78,7 @@
importStatement [StringTemplate code]
- : "import" name:ID SEMI {
+ : "import" name:STRING_LITERAL SEMI {
StringTemplate i = template("import");
i.setAttribute("target", name.getText());
code.setAttribute("imports", i);
Modified: trunk/src/org/griphyn/vdl/engine/Karajan.java
--- trunk/src/org/griphyn/vdl/engine/Karajan.java 2010-07-08 02:19:22 UTC (rev 3430)
+++ trunk/src/org/griphyn/vdl/engine/Karajan.java 2010-07-11 03:38:07 UTC (rev 3431)
@@ -155,19 +155,20 @@
Imports imports = prog.getImports();
if(imports!=null) {
logger.debug("Processing SwiftScript imports");
-// process imports in reverse order
+ // process imports in reverse order
for(int i = imports.sizeOfImportArray() - 1 ; i >=0 ; i--) {
String moduleToImport = imports.getImportArray(i);
logger.debug("Importing module "+moduleToImport);
if(!importedNames.contains(moduleToImport)) {
// TODO PATH/PERL5LIB-style path handling
- String swiftfilename = "./"+moduleToImport+".swift";
- String xmlfilename = "./"+moduleToImport+".xml";
+ //String swiftfilename = "./"+moduleToImport+".swift";
+ //String xmlfilename = "./"+moduleToImport+".xml";
+ String swiftfilename = moduleToImport+".swift";
+ String xmlfilename = moduleToImport+".xml";
try {
- VDLt2VDLx.compile(new FileInputStream(swiftfilename),new PrintStream(new FileOutputStream(xmlfilename)));
+ VDLt2VDLx.compile(new FileInputStream(swiftfilename),new PrintStream(new FileOutputStream(xmlfilename)));
logger.debug("Compiled. Now reading in compiled XML for "+moduleToImport);
Program importedProgram = parseProgramXML(xmlfilename).getProgram();
logger.debug("Read in compiled XML for "+moduleToImport);
Modified: trunk/src/org/griphyn/vdl/engine/ProcedureSignature.java
--- trunk/src/org/griphyn/vdl/engine/ProcedureSignature.java 2010-07-08 02:19:22 UTC (rev 3430)
+++ trunk/src/org/griphyn/vdl/engine/ProcedureSignature.java 2010-07-11 03:38:07 UTC (rev 3431)
@@ -188,7 +188,7 @@
filenames.addOutputArg(filenamesOut1);
functionsMap.put(filenames.getName(), filenames);
- ProcedureSignature dirname = new ProcedureSignature("dirname");
+ ProcedureSignature dirname = new ProcedureSignature("dirname");
FormalArgumentSignature dirnameIn1 = new FormalArgumentSignature(true); /* dir can be specified as any type */
dirname.addInputArg(dirnameIn1);
FormalArgumentSignature dirnameOut1 = new FormalArgumentSignature("string");
@@ -245,6 +245,13 @@
FormalArgumentSignature toOut1 = new FormalArgumentSignature("int");
toint.addOutputArg(toOut1);
functionsMap.put(toint.getName(), toint);
+ ProcedureSignature tofloat = new ProcedureSignature("tofloat");
+ FormalArgumentSignature tofloatIn1 = new FormalArgumentSignature("string");
+ tofloat.addInputArg(tofloatIn1);
+ FormalArgumentSignature tofloatOut1 = new FormalArgumentSignature("float");
+ tofloat.addOutputArg(tofloatOut1);
+ functionsMap.put(tofloat.getName(), tofloat);
ProcedureSignature tostring = new ProcedureSignature("tostring");
FormalArgumentSignature tostringIn1 = new FormalArgumentSignature(true);
Modified: trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java
--- trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java 2010-07-08 02:19:22 UTC (rev 3430)
+++ trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java 2010-07-11 03:38:07 UTC (rev 3431)
@@ -41,10 +41,11 @@
setArguments("swiftscript_tracef", new Arg[] { Arg.VARGS });
setArguments("swiftscript_strcat", new Arg[] { Arg.VARGS });
setArguments("swiftscript_strcut", new Arg[] { PA_INPUT, PA_PATTERN });
- setArguments("swiftscript_strstr", new Arg[] { PA_INPUT, PA_PATTERN });
+ setArguments("swiftscript_strstr", new Arg[] { PA_INPUT, PA_PATTERN });
setArguments("swiftscript_strsplit", new Arg[] { PA_INPUT, PA_PATTERN });
setArguments("swiftscript_regexp", new Arg[] { PA_INPUT, PA_PATTERN, PA_TRANSFORM });
setArguments("swiftscript_toint", new Arg[] { PA_INPUT });
+ setArguments("swiftscript_tofloat", new Arg[] { PA_INPUT });
setArguments("swiftscript_tostring", new Arg[] { PA_INPUT });
setArguments("swiftscript_dirname", new Arg[] { Arg.VARGS });
@@ -171,6 +172,14 @@
else {
throw new ExecutionException("tracef(): %i requires an int!");
+ else if (c == 'f') {
+ if (args[arg].getType() == Types.FLOAT) {
+ output.append(args[arg]).toString();
+ else {
+ throw new ExecutionException("tracef(): %f requires a float!");
else if (c == 'q') {
if (args[arg] instanceof ArrayDataNode) {
@@ -358,6 +367,11 @@
public DSHandle swiftscript_toint(VariableStack stack) throws ExecutionException, NoSuchTypeException,
InvalidPathException {
String inputString = TypeUtil.toString(PA_INPUT.getValue(stack));
+ int i = inputString.indexOf(".");
+ if( i >= 0 )
+ inputString = inputString.substring(0, i);
DSHandle handle = new RootDataNode(Types.INT);
handle.setValue(new Double(Integer.parseInt(inputString)));
handle.closeShallow();
@@ -366,6 +380,18 @@
VDLFunction.logProvenanceParameter(provid, PA_INPUT.getRawValue(stack), "string");
return handle;
+ public DSHandle swiftscript_tofloat(VariableStack stack) throws ExecutionException, NoSuchTypeException,
+ InvalidPathException {
+ String inputString = TypeUtil.toString(PA_INPUT.getValue(stack));
+ DSHandle handle = new RootDataNode(Types.FLOAT);
+ handle.setValue(new Double(inputString));
+ handle.closeShallow();
+ int provid=VDLFunction.nextProvenanceID();
+ VDLFunction.logProvenanceResult(provid, handle, "tofloat");
+ VDLFunction.logProvenanceParameter(provid, PA_INPUT.getRawValue(stack), "string");
+ return handle;
public DSHandle swiftscript_tostring(VariableStack stack)
More information about the Swift-commit
