[Swift-commit] r3432 - in SwiftApps/Montage: . example scripts
Mon Jul 12 14:26:40 CDT 2010
Author: jonmon
Date: 2010-07-12 14:26:40 -0500 (Mon, 12 Jul 2010)
New Revision: 3432
Added:
   SwiftApps/Montage/example/
   SwiftApps/Montage/example/corr_dir/
   SwiftApps/Montage/example/diff_dir/
   SwiftApps/Montage/example/final/
   SwiftApps/Montage/example/m101_montage.sh
   SwiftApps/Montage/example/m101_montage.swift
   SwiftApps/Montage/example/makefile
   SwiftApps/Montage/example/proj_dir/
   SwiftApps/Montage/example/raw_dir/
   SwiftApps/Montage/example/template.hdr
   SwiftApps/Montage/scripts/
   SwiftApps/Montage/scripts/Background_list.py
   SwiftApps/Montage/scripts/Swift_Montage_Apps.swift
   SwiftApps/Montage/scripts/Swift_Montage_Batch.swift
   SwiftApps/Montage/scripts/Swift_Montage_Types.swift
Removed:
   SwiftApps/Montage/Background_list.py
   SwiftApps/Montage/Swift_Montage_Apps.swift
   SwiftApps/Montage/Swift_Montage_Batch.swift
   SwiftApps/Montage/Swift_Montage_Types.swift
   SwiftApps/Montage/corr_dir/
   SwiftApps/Montage/diff_dir/
   SwiftApps/Montage/final/
   SwiftApps/Montage/makefile
   SwiftApps/Montage/montage.sh
   SwiftApps/Montage/montage.swift
   SwiftApps/Montage/proj_dir/
   SwiftApps/Montage/raw_dir/
   SwiftApps/Montage/template.hdr
Log:
Organization of file. Montage wrapper moved into scripts directory. The m101 tutorial using the Swift wrappers is in the example directory.
Deleted: SwiftApps/Montage/Background_list.py
--- SwiftApps/Montage/Background_list.py	2010-07-11 03:38:07 UTC (rev 3431)
+++ SwiftApps/Montage/Background_list.py	2010-07-12 19:26:40 UTC (rev 3432)
@@ -1,36 +0,0 @@
-#!/usr/bin/python
-import sys
-#import string
-args = sys.argv;
-file_tbl_1 = open( args[1], 'r' );
-file_tbl_o = open( args[3], 'w' );
-i = 0
-for line_tbl_1 in file_tbl_1:
-    l1 = line_tbl_1.split();
-    if l1[0] != "|" and l1[0] != "\\datatype":
-        file_tbl_2 = open( args[2], 'r' );
-        for line_tbl_2 in file_tbl_2:
-            l2 = line_tbl_2.split();
-            if l2[0] == l1[0]:
-                str_out = "["+str(i)+"].fname = "+l1[len(l1) - 1]+"\n"
-                str_out += "["+str(i)+"].a = "+l2[1]+"\n"
-                str_out += "["+str(i)+"].b = "+l2[2]+"\n"
-                str_out += "["+str(i)+"].c = "+l2[3]+"\n"
-                file_tbl_o.write( str_out )
-                i+=1
-                break
-        file_tbl_2.close();
-file_tbl_1.close();
-file_tbl_o.close();
Deleted: SwiftApps/Montage/Swift_Montage_Apps.swift
--- SwiftApps/Montage/Swift_Montage_Apps.swift	2010-07-11 03:38:07 UTC (rev 3431)
+++ SwiftApps/Montage/Swift_Montage_Apps.swift	2010-07-12 19:26:40 UTC (rev 3432)
@@ -1,148 +0,0 @@
-/*! \fn app Image mAdd( Image imgs[], Table img_tbl, MosaicData hdr )
-    \brief Adds all images in imgs[] into one image file based off the information in img_tbl and hdr.
-    \param imgs[] List of images to be added into one image. All images but reside in same directory.
-    \param img_tbl Table containing information about images being added
-    \param hdr MosaicData file containing information about how mosaic will look.
-    \return mos Image file containing data about mosaic.
-( Image mos ) mAdd( Image imgs[], Table img_tbl, MosaicData hdr )
-    app
-        mAdd "-p" @dirname( imgs[0] ) "-n" @img_tbl @hdr @mos;
-/*! \fn app Image mBackground( Image img, Table img_tbl, Table corr_tbl )
-    \brief Generates a corrected image from imgs and the information from corr_tbl
-    \param img Image to be corrected
-    \param corr_tbl Correction table containing correction coefficients to be applied
-    \return mos bg_img corrected image
-( Image bg_img ) mBackground( Image img, float a, float b, float c )
-    app
-        mBackground "-n" @img @bg_img a b c;
-/*! \fn app Table mBgModel( Table img_tbl, Table fits_tbl )
-    \brief Generates the corrected image table from the coefficeints data from fits_tbl and data from the projected image table
-    \param img_tbl Table containing information about the projected images.
-    \param fits_tbl Table containing information about how to correct an image
-    \return corr_tbl Correction table containing correction coefficients to be applied
-( Table corr_tbl ) mBgModel( Table img_tbl, Table fits_tbl )
-    app
-        mBgModel @img_tbl @fits_tbl @corr_tbl;
-/*! \fn app Image mDiff( Image proj_img_1, Image proj_img_2, MosaicData hdr )
-    \brief Calculates the difference image from the two projected images and the header file.
-    \param proj_img_1 The first image to calculate how much is overlapped
-    \param proj_img_2 The second image to calculate how much is overlapped
-    \param hdr MosaicData file that tells how the mosaic is set up
-    \return diff_img Difference image that contains overlapped information
-( Image diff_img ) mDiff( Image proj_img_1, Image proj_img_2, MosaicData hdr )
-    app
-        mDiff "-n" @proj_img_1 @proj_img_2 @diff_img @hdr;
-/*! \fn app Table mImgtbl( Image imgs[] )
-    \brief Take a list of of images and create a table out of them. All images in the list must be located in the same directory.
-    \param imgs[] List of files to create an table out of.
-    \return img_tbl Table of information of the list of images.
-( Table img_tbl ) mImgtbl( Image imgs[] )
-    app
-        mImgtbl @dirname( imgs[0] ) @img_tbl;
-/*! \fn app JPEG mJPEG( Image mos_img )
-    \brief Creates a viewable jpeg image from the mosaic data image
-    \param mos_img Image file to create a jpeg out of.
-    \return mos_img_jpg Jpeg picture.
-( JPEG mos_img_jpg ) mJPEG( Image mos_img )
-    app
-        mJPEG "-gray" @mos_img "20%" "99.98%" "loglog" "-out" @mos_img_jpg;
-/*! \fn app Table mOverlaps( Table img_tbl )
-    \brief Calculates which images overlaps each other and creates a table out of.
-    \param img_tbl Table of projected images.
-    \return diff_tbl Table of which overlapped images
-( Table diff_tbl ) mOverlaps( Table img_tbl )
-    app
-        mOverlaps @img_tbl @diff_tbl;
-/*! \fn app Image mProjectPP( Image raw_img, MosaicData hdr )
-    \brief Projects an image based off of the header file.
-    \param raw_img Raw image to project.
-    \param hdr MosaicData file telling how the mosaic will be set up in the end.
-    \return proj_img Projected image.
-( Image proj_img ) mProjectPP( Image raw_img, MosaicData hdr )
-    app
-        mProjectPP "-X" @raw_img @proj_img @hdr;
-/*                                Util Scripts                                      */
-/*! \fn app Table Background_list( Table imgs_tbl, Table corrs_tbl
-    \brief Generates a list of coefficients that need to be applied and the files to apply them to.
-    \param imgs_tbl Table generated by mImgtbl containing information on the set of images
-    \param corrs_tbl Table containing the coefficients and the id of the image to apply them to
-    \return back_tbl Table containing the Image file name and the coefficients that need to be applied to the image. Data is set up so readDatat2 can read the data.
-( Table back_tbl ) Background_list( Table imgs_tbl, Table corrs_tbl )
-    app
-        Background_list @imgs_tbl @corrs_tbl @back_tbl;
Deleted: SwiftApps/Montage/Swift_Montage_Batch.swift
--- SwiftApps/Montage/Swift_Montage_Batch.swift	2010-07-11 03:38:07 UTC (rev 3431)
+++ SwiftApps/Montage/Swift_Montage_Batch.swift	2010-07-12 19:26:40 UTC (rev 3432)
@@ -1,97 +0,0 @@
-/*! \file Swift_Montage_Batch.swift
-    \brief File containing Batch functions for the Swift Montage wrappers
-    Each batch function allows basic Montage functions to be called on a list of
-    images.
-/*! \fn Image mBgBatch( Image bg_imgs[], Table img_tbl, Table corr_tbl )
-    \brief Runs the mBackground wrapper on a list of images in parallel.
-    \param bg_imgs[] The list of images to run the mBackground wrapper on.
-    \param img_tbl Table containing information on original images.
-    \param corr_tbl Table containing correction coefficients to be applied to the images.
-    \return corr_imgs[] List of the corrected images to be added to create image mosaic.
-( Image corr_imgs[] ) mBgBatch( Image bg_imgs[], Table img_tbl, Table corr_tbl )
-    Table tmp <"back_tmp.tbl">;
-    tmp = Background_list( img_tbl, corr_tbl );
-    BackgroundStruct back_struct[] = readData2( tmp );
-    foreach background_entry, i in back_struct
-        Image proj_img <single_file_mapper; file = @strcat( @dirname( bg_imgs[0] )+"/", @background_entry.fname )>;
-        Image corr_img <regexp_mapper; source = @proj_img, match = ".*\\/(.*)", transform = "corr_dir/\\1">;
-        float a = background_entry.a;
-        float b = background_entry.b;
-        float c = background_entry.c;
-        corr_img = mBackground( proj_img, a, b, c );
-        corr_imgs[ i ] = corr_img;
-/*! \fn Image mDiffBatch( Table diff_tbl, MosaicData hdr )
-    \brief Runs the mDiff wrapper on a list of images in parallel.
-    \param diff_tbl Table containing a list of images that overlap and must calculate by how much they overlap.
-    \param hdr File containing information on how the final mosaic will be set up.
-    \return diff_imgs[] List of the difference images that must have correction coefficients calculated.
-( Image diff_imgs[] ) mDiffBatch( Table diff_tbl, MosaicData hdr )
-	DiffStruct diffs[] <csv_mapper; file = diff_tbl, skip = 1, hdelim="| ">;
-    foreach d_entry, i in diffs
-//        tracef("plus: %s \n", @d_entry.plus );
-        Image proj_1 <single_file_mapper; file = @strcat( "proj_dir/", @d_entry.plus )>;
-        Image proj_2 <single_file_mapper; file = @strcat( "proj_dir/", @d_entry.minus )>;
-        Image diff_img <single_file_mapper; file = @strcat( "diff_dir/", @d_entry.diff )>;
-        diff_img = mDiff( proj_1, proj_2, hdr );
-        diff_imgs[ i ] = diff_img;
-/*! \fn app Table mFitBatch( Table diff_tbl, Image diff_imgs[] )
-    \param diff_tbl
-    \param diff_imgs
-    \return fits_tbl
-( Table fits_tbl ) mFitBatch( Table diff_tbl, Image diff_imgs[] )
-    app
-        mFitExec @diff_tbl @fits_tbl @dirname( diff_imgs[0] );
-/*! \fn Image mProjectPPBatch( Image raw_imgs[], MosaicData hdr )
-    \brief Projects the raw images from raw_imgs to a new plane that was declared in hdr.
-    \param raw_imgs[] List of raw images that need to be projected to new plane.
-    \return proj_imgs[] List of newly reprojected images.
-( Image proj_imgs[] ) mProjectPPBatch( Image raw_imgs[], MosaicData hdr )
-    foreach img, i in raw_imgs
-		Image proj_img <regexp_mapper; source = @img, match = ".*\\/(.*)", transform = "proj_dir/proj_\\1">;
-        proj_img = mProjectPP( img, hdr );
-        proj_imgs[ i ] = proj_img;
Deleted: SwiftApps/Montage/Swift_Montage_Types.swift
--- SwiftApps/Montage/Swift_Montage_Types.swift	2010-07-11 03:38:07 UTC (rev 3431)
+++ SwiftApps/Montage/Swift_Montage_Types.swift	2010-07-12 19:26:40 UTC (rev 3432)
@@ -1,50 +0,0 @@
-/*! \file Swift_Montage_Types.swift
-    \brief File containing declared Swift types for the Swift Montage wrappers
-/*! \typdef type Image
-    \brief Declared Image Swift type.
-type Image;
-/*! \typdef type MosaicData
-    \brief Declared MosaicData Swift type.
-type MosaicData;
-/*! \typdef type Table
-    \brief Declared Table Swift type.
-type Table;
-/*! \typdef type JPEG
-    \brief Declared JPEG Swift type.
-type JPEG;
-/*! \struct BackgroundStruct
-    \brief Stuct to hold data found in the tables generated my mImgtbl and mBgModel
-type BackgroundStruct
-    string fname;
-    float a;
-    float b;
-    float c;
-/*! \struct DiffStruct
-    \brief Stuct to hold data found in the table that is generated from the mOverlaps wrapper.
-type DiffStruct
-	int cntr1;
-	int cntr2;
-	Image plus;
-	Image minus;
-	Image diff;
Copied: SwiftApps/Montage/example/corr_dir (from rev 3428, SwiftApps/Montage/corr_dir)
Copied: SwiftApps/Montage/example/diff_dir (from rev 3428, SwiftApps/Montage/diff_dir)
Copied: SwiftApps/Montage/example/final (from rev 3428, SwiftApps/Montage/final)
Copied: SwiftApps/Montage/example/m101_montage.sh (from rev 3430, SwiftApps/Montage/montage.sh)
--- SwiftApps/Montage/example/m101_montage.sh	                        (rev 0)
+++ SwiftApps/Montage/example/m101_montage.sh	2010-07-12 19:26:40 UTC (rev 3432)
@@ -0,0 +1,22 @@
+#!/bin/bash
+mImgtbl raw_dir images-rawdir.tbl
+START=$(date +%s)
+mProjExec -p raw_dir images-rawdir.tbl template.hdr proj_dir stats.tbl
+rm -f proj_dir/*area*
+mImgtbl proj_dir images.tbl
+# mAdd -p pro_jdir -n images.tbl template.hdr final/uncorrected.fits
+# mJPEG -gray final/uncorrected.fits 20% 99.98% loglog -out final/uncorrected.jpg
+mOverlaps images.tbl diffs.tbl
+mDiffExec -p proj_dir -n diffs.tbl template.hdr diff_dir
+mFitExec diffs.tbl fits.tbl diff_dir
+mBgModel images.tbl fits.tbl corrections.tbl
+mBgExec -p proj_dir -n images.tbl corrections.tbl corr_dir
+mAdd -p corr_dir -n images.tbl template.hdr final/mosaic.fits
+mJPEG -gray final/mosaic.fits 20% 99.98% loglog -out final/mosaic.jpg
+END=$(date +%s)
+DIFF=$(( $END - $START ))
+echo "It took $DIFF seconds"
Copied: SwiftApps/Montage/example/m101_montage.swift (from rev 3430, SwiftApps/Montage/montage.swift)
--- SwiftApps/Montage/example/m101_montage.swift	                        (rev 0)
+++ SwiftApps/Montage/example/m101_montage.swift	2010-07-12 19:26:40 UTC (rev 3432)
@@ -0,0 +1,29 @@
+import "../scripts/Swift_Montage_Types";
+import "../scripts/Swift_Montage_Apps";
+import "../scripts/Swift_Montage_Batch";
+MosaicData template <"template.hdr">;
+Table images_tbl <"images.tbl">;
+Table difference_tbl <"diffs.tbl">;
+Table fits_images_tbl <"fits.tbl">;
+Table corrections_tbl <"corrections.tbl">;
+/* Image uncorrected_mos <"final/uncorrected.fits">; */
+Image corrected_mos <"final/corrected.fits">;
+/* JPEG uncorrected_jpg_img <"final/uncorrected.jpg">; */
+JPEG corrected_jpg_img <"final/corrected.jpg">;
+Image raw_image_files[] <filesys_mapper; location = "raw_dir", suffix = ".fits">;
+Image projected_images[];
+Image difference_images[];
+Image corrected_images[];
+projected_images = mProjectPPBatch( raw_image_files, template );
+images_tbl = mImgtbl( projected_images );
+/* uncorrected_mos = mAdd( projected_images, images_tbl, template ); */
+/* uncorrected_jpg_img = mJPEG( uncorrected_mos ); */
+difference_tbl = mOverlaps( images_tbl );
+difference_images = mDiffBatch( difference_tbl, template );
+fits_images_tbl = mFitBatch( difference_tbl, difference_images );
+corrections_tbl = mBgModel( images_tbl, fits_images_tbl );
+corrected_images = mBgBatch( projected_images, images_tbl, corrections_tbl );
+corrected_mos = mAdd( corrected_images, images_tbl, template );
+corrected_jpg_img = mJPEG( corrected_mos );
Copied: SwiftApps/Montage/example/makefile (from rev 3430, SwiftApps/Montage/makefile)
--- SwiftApps/Montage/example/makefile	                        (rev 0)
+++ SwiftApps/Montage/example/makefile	2010-07-12 19:26:40 UTC (rev 3432)
@@ -0,0 +1,13 @@
+.PHONY:	shell swift DAG
+shell:
+	./m101_montage.sh
+swift:
+	swiftrun m101_montage.swift
+DAG:
+	swiftrun -pgraph Montage_DAT.dot montage.swift
+clean:
+	@rm -rvf proj_dir/* diff_dir/* final/* corr_dir/* debug scripts/*.xml diffs.tbl images-rawdir.tbl images.tbl corrections.tbl fits.tbl stats.tbl back_tmp.tbl *.txt
Copied: SwiftApps/Montage/example/proj_dir (from rev 3428, SwiftApps/Montage/proj_dir)
Copied: SwiftApps/Montage/example/raw_dir (from rev 3428, SwiftApps/Montage/raw_dir)
Copied: SwiftApps/Montage/example/template.hdr (from rev 3428, SwiftApps/Montage/template.hdr)
--- SwiftApps/Montage/example/template.hdr	                        (rev 0)
+++ SwiftApps/Montage/example/template.hdr	2010-07-12 19:26:40 UTC (rev 3432)
@@ -0,0 +1,16 @@
+SIMPLE  = T
+BITPIX  = -64
+NAXIS   = 2
+NAXIS1  = 2259
+NAXIS2  = 2199
+CTYPE1  = 'RA---TAN'
+CTYPE2  = 'DEC--TAN'
+CRVAL1  =  210.835222357
+CRVAL2  =   54.367562188
+CDELT1  =   -0.000277780
+CDELT2  =    0.000277780
+CRPIX1  =      1130.0000
+CRPIX2  =      1100.0000
+CROTA2  =   -0.052834592
+HISTORY =   MONTAGE TUTORIAL
+END
Deleted: SwiftApps/Montage/makefile
--- SwiftApps/Montage/makefile	2010-07-11 03:38:07 UTC (rev 3431)
+++ SwiftApps/Montage/makefile	2010-07-12 19:26:40 UTC (rev 3432)
@@ -1,10 +0,0 @@
-.PHONY:	shell swift
-shell:
-	./montage.sh
-swift:
-	swiftrun montage.swift
-clean:
-	@rm -rvf proj_dir/* diff_dir/* final/* corr_dir/* debug diffs.tbl images-rawdir.tbl images.tbl corrections.tbl fits.tbl stats.tbl back_tmp.tbl *.txt
Deleted: SwiftApps/Montage/montage.sh
--- SwiftApps/Montage/montage.sh	2010-07-11 03:38:07 UTC (rev 3431)
+++ SwiftApps/Montage/montage.sh	2010-07-12 19:26:40 UTC (rev 3432)
@@ -1,22 +0,0 @@
-#!/bin/bash
-mImgtbl raw_dir images-rawdir.tbl
-START=$(date +%s)
-mProjExec -p raw_dir images-rawdir.tbl template.hdr proj_dir stats.tbl
-rm -f proj_dir/*area*
-mImgtbl proj_dir images.tbl
-# mAdd -p pro_jdir -n images.tbl template.hdr final/uncorrected.fits
-# mJPEG -gray final/uncorrected.fits 20% 99.98% loglog -out final/uncorrected.jpg
-mOverlaps images.tbl diffs.tbl
-mDiffExec -p proj_dir -n diffs.tbl template.hdr diff_dir
-mFitExec diffs.tbl fits.tbl diff_dir
-mBgModel images.tbl fits.tbl corrections.tbl
-mBgExec -p proj_dir -n images.tbl corrections.tbl corr_dir
-mAdd -p corr_dir -n images.tbl template.hdr final/mosaic.fits
-mJPEG -gray final/mosaic.fits 20% 99.98% loglog -out final/mosaic.jpg
-END=$(date +%s)
-DIFF=$(( $END - $START ))
-echo "It took $DIFF seconds"
Deleted: SwiftApps/Montage/montage.swift
--- SwiftApps/Montage/montage.swift	2010-07-11 03:38:07 UTC (rev 3431)
+++ SwiftApps/Montage/montage.swift	2010-07-12 19:26:40 UTC (rev 3432)
@@ -1,29 +0,0 @@
-import Swift_Montage_Types;
-import Swift_Montage_Apps;
-import Swift_Montage_Batch;
-MosaicData template <"template.hdr">;
-Table images_tbl <"images.tbl">;
-Table difference_tbl <"diffs.tbl">;
-Table fits_images_tbl <"fits.tbl">;
-Table corrections_tbl <"corrections.tbl">;
-/* Image uncorrected_mos <"final/uncorrected.fits">; */
-Image corrected_mos <"final/corrected.fits">;
-/* JPEG uncorrected_jpg_img <"final/uncorrected.jpg">; */
-JPEG corrected_jpg_img <"final/corrected.jpg">;
-Image raw_image_files[] <filesys_mapper; location = "raw_dir", suffix = ".fits">;
-Image projected_images[];
-Image difference_images[];
-Image corrected_images[];
-projected_images = mProjectPPBatch( raw_image_files, template );
-images_tbl = mImgtbl( projected_images );
-/* uncorrected_mos = mAdd( projected_images, images_tbl, template ); */
-/* uncorrected_jpg_img = mJPEG( uncorrected_mos ); */
-difference_tbl = mOverlaps( images_tbl );
-difference_images = mDiffBatch( difference_tbl, template );
-fits_images_tbl = mFitBatch( difference_tbl, difference_images );
-corrections_tbl = mBgModel( images_tbl, fits_images_tbl );
-corrected_images = mBgBatch( projected_images, images_tbl, corrections_tbl );
-corrected_mos = mAdd( corrected_images, images_tbl, template );
-corrected_jpg_img = mJPEG( corrected_mos );
Copied: SwiftApps/Montage/scripts/Background_list.py (from rev 3430, SwiftApps/Montage/Background_list.py)
--- SwiftApps/Montage/scripts/Background_list.py	                        (rev 0)
+++ SwiftApps/Montage/scripts/Background_list.py	2010-07-12 19:26:40 UTC (rev 3432)
@@ -0,0 +1,36 @@
+#!/usr/bin/python
+import sys
+#import string
+args = sys.argv;
+file_tbl_1 = open( args[1], 'r' );
+file_tbl_o = open( args[3], 'w' );
+i = 0
+for line_tbl_1 in file_tbl_1:
+    l1 = line_tbl_1.split();
+    if l1[0] != "|" and l1[0] != "\\datatype":
+        file_tbl_2 = open( args[2], 'r' );
+        for line_tbl_2 in file_tbl_2:
+            l2 = line_tbl_2.split();
+            if l2[0] == l1[0]:
+                str_out = "["+str(i)+"].fname = "+l1[len(l1) - 1]+"\n"
+                str_out += "["+str(i)+"].a = "+l2[1]+"\n"
+                str_out += "["+str(i)+"].b = "+l2[2]+"\n"
+                str_out += "["+str(i)+"].c = "+l2[3]+"\n"
+                file_tbl_o.write( str_out )
+                i+=1
+                break
+        file_tbl_2.close();
+file_tbl_1.close();
+file_tbl_o.close();
Copied: SwiftApps/Montage/scripts/Swift_Montage_Apps.swift (from rev 3430, SwiftApps/Montage/Swift_Montage_Apps.swift)
--- SwiftApps/Montage/scripts/Swift_Montage_Apps.swift	                        (rev 0)
+++ SwiftApps/Montage/scripts/Swift_Montage_Apps.swift	2010-07-12 19:26:40 UTC (rev 3432)
@@ -0,0 +1,148 @@
+/*! \fn app Image mAdd( Image imgs[], Table img_tbl, MosaicData hdr )
+    \brief Adds all images in imgs[] into one image file based off the information in img_tbl and hdr.
+    \param imgs[] List of images to be added into one image. All images but reside in same directory.
+    \param img_tbl Table containing information about images being added
+    \param hdr MosaicData file containing information about how mosaic will look.
+    \return mos Image file containing data about mosaic.
+( Image mos ) mAdd( Image imgs[], Table img_tbl, MosaicData hdr )
+    app
+        mAdd "-p" @dirname( imgs[0] ) "-n" @img_tbl @hdr @mos;
+/*! \fn app Image mBackground( Image img, Table img_tbl, Table corr_tbl )
+    \brief Generates a corrected image from imgs and the information from corr_tbl
+    \param img Image to be corrected
+    \param corr_tbl Correction table containing correction coefficients to be applied
+    \return mos bg_img corrected image
+( Image bg_img ) mBackground( Image img, float a, float b, float c )
+    app
+        mBackground "-n" @img @bg_img a b c;
+/*! \fn app Table mBgModel( Table img_tbl, Table fits_tbl )
+    \brief Generates the corrected image table from the coefficeints data from fits_tbl and data from the projected image table
+    \param img_tbl Table containing information about the projected images.
+    \param fits_tbl Table containing information about how to correct an image
+    \return corr_tbl Correction table containing correction coefficients to be applied
+( Table corr_tbl ) mBgModel( Table img_tbl, Table fits_tbl )
+    app
+        mBgModel @img_tbl @fits_tbl @corr_tbl;
+/*! \fn app Image mDiff( Image proj_img_1, Image proj_img_2, MosaicData hdr )
+    \brief Calculates the difference image from the two projected images and the header file.
+    \param proj_img_1 The first image to calculate how much is overlapped
+    \param proj_img_2 The second image to calculate how much is overlapped
+    \param hdr MosaicData file that tells how the mosaic is set up
+    \return diff_img Difference image that contains overlapped information
+( Image diff_img ) mDiff( Image proj_img_1, Image proj_img_2, MosaicData hdr )
+    app
+        mDiff "-n" @proj_img_1 @proj_img_2 @diff_img @hdr;
+/*! \fn app Table mImgtbl( Image imgs[] )
+    \brief Take a list of of images and create a table out of them. All images in the list must be located in the same directory.
+    \param imgs[] List of files to create an table out of.
+    \return img_tbl Table of information of the list of images.
+( Table img_tbl ) mImgtbl( Image imgs[] )
+    app
+        mImgtbl @dirname( imgs[0] ) @img_tbl;
+/*! \fn app JPEG mJPEG( Image mos_img )
+    \brief Creates a viewable jpeg image from the mosaic data image
+    \param mos_img Image file to create a jpeg out of.
+    \return mos_img_jpg Jpeg picture.
+( JPEG mos_img_jpg ) mJPEG( Image mos_img )
+    app
+        mJPEG "-gray" @mos_img "20%" "99.98%" "loglog" "-out" @mos_img_jpg;
+/*! \fn app Table mOverlaps( Table img_tbl )
+    \brief Calculates which images overlaps each other and creates a table out of.
+    \param img_tbl Table of projected images.
+    \return diff_tbl Table of which overlapped images
+( Table diff_tbl ) mOverlaps( Table img_tbl )
+    app
+        mOverlaps @img_tbl @diff_tbl;
+/*! \fn app Image mProjectPP( Image raw_img, MosaicData hdr )
+    \brief Projects an image based off of the header file.
+    \param raw_img Raw image to project.
+    \param hdr MosaicData file telling how the mosaic will be set up in the end.
+    \return proj_img Projected image.
+( Image proj_img ) mProjectPP( Image raw_img, MosaicData hdr )
+    app
+        mProjectPP "-X" @raw_img @proj_img @hdr;
+/*                                Util Scripts                                      */
+/*! \fn app Table Background_list( Table imgs_tbl, Table corrs_tbl
+    \brief Generates a list of coefficients that need to be applied and the files to apply them to.
+    \param imgs_tbl Table generated by mImgtbl containing information on the set of images
+    \param corrs_tbl Table containing the coefficients and the id of the image to apply them to
+    \return back_tbl Table containing the Image file name and the coefficients that need to be applied to the image. Data is set up so readDatat2 can read the data.
+( Table back_tbl ) Background_list( Table imgs_tbl, Table corrs_tbl )
+    app
+        Background_list @imgs_tbl @corrs_tbl @back_tbl;
Copied: SwiftApps/Montage/scripts/Swift_Montage_Batch.swift (from rev 3430, SwiftApps/Montage/Swift_Montage_Batch.swift)
--- SwiftApps/Montage/scripts/Swift_Montage_Batch.swift	                        (rev 0)
+++ SwiftApps/Montage/scripts/Swift_Montage_Batch.swift	2010-07-12 19:26:40 UTC (rev 3432)
@@ -0,0 +1,98 @@
+/*! \file Swift_Montage_Batch.swift
+    \brief File containing Batch functions for the Swift Montage wrappers
+    Each batch function allows basic Montage functions to be called on a list of
+    images.
+/*! \fn Image mBgBatch( Image bg_imgs[], Table img_tbl, Table corr_tbl )
+    \brief Runs the mBackground wrapper on a list of images in parallel.
+    \param bg_imgs[] The list of images to run the mBackground wrapper on.
+    \param img_tbl Table containing information on original images.
+    \param corr_tbl Table containing correction coefficients to be applied to the images.
+    \return corr_imgs[] List of the corrected images to be added to create image mosaic.
+( Image corr_imgs[] ) mBgBatch( Image bg_imgs[], Table img_tbl, Table corr_tbl )
+    Table tmp <"back_tmp.tbl">;
+    tmp = Background_list( img_tbl, corr_tbl );
+    BackgroundStruct back_struct[] = readData2( tmp );
+    foreach background_entry, i in back_struct
+        Image proj_img <single_file_mapper; file = @strcat( @dirname( bg_imgs[0] )+"/", @background_entry.fname )>;
+        Image corr_img <regexp_mapper; source = @proj_img, match = ".*\\/(.*)", transform = "corr_dir/\\1">;
+        float a = background_entry.a;
+        float b = background_entry.b;
+        float c = background_entry.c;
+        corr_img = mBackground( proj_img, a, b, c );
+        corr_imgs[ i ] = corr_img;
+/*! \fn Image mDiffBatch( Table diff_tbl, MosaicData hdr )
+    \brief Runs the mDiff wrapper on a list of images in parallel.
+    \param diff_tbl Table containing a list of images that overlap and must calculate by how much they overlap.
+    \param hdr File containing information on how the final mosaic will be set up.
+    \return diff_imgs[] List of the difference images that must have correction coefficients calculated.
+( Image diff_imgs[] ) mDiffBatch( Table diff_tbl, MosaicData hdr )
+	DiffStruct diffs[] <csv_mapper; file = diff_tbl, skip = 1, hdelim="| ">;
+    foreach d_entry, i in diffs
+        /* Not always going to be in proj_dir. Maybe read diff_tbl for directory. */
+        /* Not sure if the information is there. */
+        Image proj_1 <single_file_mapper; file = @strcat( "proj_dir/", @d_entry.plus )>;
+        Image proj_2 <single_file_mapper; file = @strcat( "proj_dir/", @d_entry.minus )>;
+        Image diff_img <single_file_mapper; file = @strcat( "diff_dir/", @d_entry.diff )>;
+        diff_img = mDiff( proj_1, proj_2, hdr );
+        diff_imgs[ i ] = diff_img;
+/*! \fn app Table mFitBatch( Table diff_tbl, Image diff_imgs[] )
+    \param diff_tbl
+    \param diff_imgs
+    \return fits_tbl
+( Table fits_tbl ) mFitBatch( Table diff_tbl, Image diff_imgs[] )
+    app
+        mFitExec @diff_tbl @fits_tbl @dirname( diff_imgs[0] );
+/*! \fn Image mProjectPPBatch( Image raw_imgs[], MosaicData hdr )
+    \brief Projects the raw images from raw_imgs to a new plane that was declared in hdr.
+    \param raw_imgs[] List of raw images that need to be projected to new plane.
+    \return proj_imgs[] List of newly reprojected images.
+( Image proj_imgs[] ) mProjectPPBatch( Image raw_imgs[], MosaicData hdr )
+    foreach img, i in raw_imgs
+		Image proj_img <regexp_mapper; source = @img, match = ".*\\/(.*)", transform = "proj_dir/proj_\\1">;
+        proj_img = mProjectPP( img, hdr );
+        proj_imgs[ i ] = proj_img;
Copied: SwiftApps/Montage/scripts/Swift_Montage_Types.swift (from rev 3430, SwiftApps/Montage/Swift_Montage_Types.swift)
--- SwiftApps/Montage/scripts/Swift_Montage_Types.swift	                        (rev 0)
+++ SwiftApps/Montage/scripts/Swift_Montage_Types.swift	2010-07-12 19:26:40 UTC (rev 3432)
@@ -0,0 +1,50 @@
+/*! \file Swift_Montage_Types.swift
+    \brief File containing declared Swift types for the Swift Montage wrappers
+/*! \typdef type Image
+    \brief Declared Image Swift type.
+type Image;
+/*! \typdef type MosaicData
+    \brief Declared MosaicData Swift type.
+type MosaicData;
+/*! \typdef type Table
+    \brief Declared Table Swift type.
+type Table;
+/*! \typdef type JPEG
+    \brief Declared JPEG Swift type.
+type JPEG;
+/*! \struct BackgroundStruct
+    \brief Stuct to hold data found in the tables generated my mImgtbl and mBgModel
+type BackgroundStruct
+    string fname;
+    float a;
+    float b;
+    float c;
+/*! \struct DiffStruct
+    \brief Stuct to hold data found in the table that is generated from the mOverlaps wrapper.
+type DiffStruct
+	int cntr1;
+	int cntr2;
+	Image plus;
+	Image minus;
+	Image diff;
Deleted: SwiftApps/Montage/template.hdr
--- SwiftApps/Montage/template.hdr	2010-07-11 03:38:07 UTC (rev 3431)
+++ SwiftApps/Montage/template.hdr	2010-07-12 19:26:40 UTC (rev 3432)
@@ -1,16 +0,0 @@
-SIMPLE  = T
-BITPIX  = -64
-NAXIS   = 2
-NAXIS1  = 2259
-NAXIS2  = 2199
-CTYPE1  = 'RA---TAN'
-CTYPE2  = 'DEC--TAN'
-CRVAL1  =  210.835222357
-CRVAL2  =   54.367562188
-CDELT1  =   -0.000277780
-CDELT2  =    0.000277780
-CRPIX1  =      1130.0000
-CRPIX2  =      1100.0000
-CROTA2  =   -0.052834592
-HISTORY =   MONTAGE TUTORIAL
-END
