[Swift-commit] r3430 - SwiftApps/Montage
Wed Jul 7 21:19:22 CDT 2010
Author: jonmon
Date: 2010-07-07 21:19:22 -0500 (Wed, 07 Jul 2010)
New Revision: 3430
Added:
   SwiftApps/Montage/Background_list.py
Modified:
   SwiftApps/Montage/Swift_Montage_Apps.swift
   SwiftApps/Montage/Swift_Montage_Batch.swift
   SwiftApps/Montage/Swift_Montage_Types.swift
   SwiftApps/Montage/makefile
   SwiftApps/Montage/montage.sh
   SwiftApps/Montage/montage.swift
Log:
o SwiftApps/Montage/Background_list.py
  -- Script created to replace the id in the correction table with the image file name. This allows me to run mBackground insteado mBgExec.
o SwiftApps/Montage/Swift_Montage_Apps.swift
o SwiftApps/Montage/Swift_Montage_Batch.swift
o SwiftApps/Montage/Swift_Montage_Types.swift
  -- Modifications to finish the mBgBatch swift script.  Now all wrappers are implemented needed to run general cases of Montage.
o SwiftApps/Montage/montage.swift
  -- Added lines to the script to run the m101 tutorial in Swift.
o SwiftApps/Montage/montage.sh
o SwiftApps/Montage/makefile
  -- Minor modifications.
Added: SwiftApps/Montage/Background_list.py
--- SwiftApps/Montage/Background_list.py	                        (rev 0)
+++ SwiftApps/Montage/Background_list.py	2010-07-08 02:19:22 UTC (rev 3430)
@@ -0,0 +1,36 @@
+#!/usr/bin/python
+import sys
+#import string
+args = sys.argv;
+file_tbl_1 = open( args[1], 'r' );
+file_tbl_o = open( args[3], 'w' );
+i = 0
+for line_tbl_1 in file_tbl_1:
+    l1 = line_tbl_1.split();
+    if l1[0] != "|" and l1[0] != "\\datatype":
+        file_tbl_2 = open( args[2], 'r' );
+        for line_tbl_2 in file_tbl_2:
+            l2 = line_tbl_2.split();
+            if l2[0] == l1[0]:
+                str_out = "["+str(i)+"].fname = "+l1[len(l1) - 1]+"\n"
+                str_out += "["+str(i)+"].a = "+l2[1]+"\n"
+                str_out += "["+str(i)+"].b = "+l2[2]+"\n"
+                str_out += "["+str(i)+"].c = "+l2[3]+"\n"
+                file_tbl_o.write( str_out )
+                i+=1
+                break
+        file_tbl_2.close();
+file_tbl_1.close();
+file_tbl_o.close();
Property changes on: SwiftApps/Montage/Background_list.py
___________________________________________________________________
Modified: SwiftApps/Montage/Swift_Montage_Apps.swift
--- SwiftApps/Montage/Swift_Montage_Apps.swift	2010-07-07 20:20:19 UTC (rev 3429)
+++ SwiftApps/Montage/Swift_Montage_Apps.swift	2010-07-08 02:19:22 UTC (rev 3430)
@@ -1,12 +1,3 @@
-/*! \file Swift_Montage_Apps.swift
-    \brief File containing Swift wrappers to basic Montage functions
-    Each app function is a wrapper to a scalar Montage function.
-    Using the word scalar becuase each function takes a single image to
-    work on unlike the Swift batch functions.
 /*! \fn app Image mAdd( Image imgs[], Table img_tbl, MosaicData hdr )
     \brief Adds all images in imgs[] into one image file based off the information in img_tbl and hdr.
@@ -32,11 +23,11 @@
     \param corr_tbl Correction table containing correction coefficients to be applied
     \return mos bg_img corrected image
-( Image bg_img ) mBackground( Image img, Table img_tbl, Table corr_tbl )
+( Image bg_img ) mBackground( Image img, float a, float b, float c )
     app
-        mBackground "-n" @img @bg_img @img_tbl @corr_tbl;
+        mBackground "-n" @img @bg_img a b c;
@@ -133,3 +124,25 @@
         mProjectPP "-X" @raw_img @proj_img @hdr;
+/*                                Util Scripts                                      */
+/*! \fn app Table Background_list( Table imgs_tbl, Table corrs_tbl
+    \brief Generates a list of coefficients that need to be applied and the files to apply them to.
+    \param imgs_tbl Table generated by mImgtbl containing information on the set of images
+    \param corrs_tbl Table containing the coefficients and the id of the image to apply them to
+    \return back_tbl Table containing the Image file name and the coefficients that need to be applied to the image. Data is set up so readDatat2 can read the data.
+( Table back_tbl ) Background_list( Table imgs_tbl, Table corrs_tbl )
+    app
+        Background_list @imgs_tbl @corrs_tbl @back_tbl;
Modified: SwiftApps/Montage/Swift_Montage_Batch.swift
--- SwiftApps/Montage/Swift_Montage_Batch.swift	2010-07-07 20:20:19 UTC (rev 3429)
+++ SwiftApps/Montage/Swift_Montage_Batch.swift	2010-07-08 02:19:22 UTC (rev 3430)
@@ -1,54 +1,47 @@
 /*! \file Swift_Montage_Batch.swift
-  \brief File containing Batch functions for the Swift Montage wrappers
+    \brief File containing Batch functions for the Swift Montage wrappers
-  Each batch function allows basic Montage functions to be called on a list of
-  images.
+    Each batch function allows basic Montage functions to be called on a list of
+    images.
 /*! \fn Image mBgBatch( Image bg_imgs[], Table img_tbl, Table corr_tbl )
-  \brief Runs the mBackground wrapper on a list of images in parallel.
+    \brief Runs the mBackground wrapper on a list of images in parallel.
-  \param bg_imgs[] The list of images to run the mBackground wrapper on.
-  \param img_tbl Table containing information on original images.
-  \param corr_tbl Table containing correction coefficients to be applied to the images.
-  \return corr_imgs[] List of the corrected images to be added to create image mosaic.
+    \param bg_imgs[] The list of images to run the mBackground wrapper on.
+    \param img_tbl Table containing information on original images.
+    \param corr_tbl Table containing correction coefficients to be applied to the images.
+    \return corr_imgs[] List of the corrected images to be added to create image mosaic.
 ( Image corr_imgs[] ) mBgBatch( Image bg_imgs[], Table img_tbl, Table corr_tbl )
+    Table tmp <"back_tmp.tbl">;
+    tmp = Background_list( img_tbl, corr_tbl );
-    /* ImageStruct img_struct_tbl[] <>; */
-    /* CorrectStruct correct_stuct_tbl[] <>; */
-    /* Image proj_img; */
-    /* Image corr_img; */
-    /* int A; */
-    /* int B; */
-    /* int C; */
+    BackgroundStruct back_struct[] = readData2( tmp );
-    /* foreach img_tbl_entry, i in img_struct_tbl */
-    /*     foreach correct_tbl_entry in correct_struct_tbl */
-    /*         if( img_tbl_entry.cntr == correct_tbl_entry.id ) */
-    /*             img <single_file_mapper; file = @strcat( @dirname( bg_imgs[0] ), @img_tbl_entry.fname ); */
-    /*             corr_img <regexp_mapper; source = @img, match = ".*\\\\/(.*)", transform = "corr_dir/corr_\\1">; */
+    foreach background_entry, i in back_struct
+        Image proj_img <single_file_mapper; file = @strcat( @dirname( bg_imgs[0] )+"/", @background_entry.fname )>;
+        Image corr_img <regexp_mapper; source = @proj_img, match = ".*\\/(.*)", transform = "corr_dir/\\1">;
-    /*             corr_img = mBackground( img, A, B, C ); */
+        float a = background_entry.a;
+        float b = background_entry.b;
+        float c = background_entry.c;
+        corr_img = mBackground( proj_img, a, b, c );
-    /*             corr_imgs[ i ] = corr_img; */
+        corr_imgs[ i ] = corr_img;
 /*! \fn Image mDiffBatch( Table diff_tbl, MosaicData hdr )
-  \brief Runs the mDiff wrapper on a list of images in parallel.
+    \brief Runs the mDiff wrapper on a list of images in parallel.
-  \param diff_tbl Table containing a list of images that overlap and must calculate by how much they overlap.
-  \param hdr File containing information on how the final mosaic will be set up.
-  \return diff_imgs[] List of the difference images that must have correction coefficients calculated.
+    \param diff_tbl Table containing a list of images that overlap and must calculate by how much they overlap.
+    \param hdr File containing information on how the final mosaic will be set up.
+    \return diff_imgs[] List of the difference images that must have correction coefficients calculated.
 ( Image diff_imgs[] ) mDiffBatch( Table diff_tbl, MosaicData hdr )
@@ -56,6 +49,7 @@
     foreach d_entry, i in diffs
+//        tracef("plus: %s \n", @d_entry.plus );
         Image proj_1 <single_file_mapper; file = @strcat( "proj_dir/", @d_entry.plus )>;
         Image proj_2 <single_file_mapper; file = @strcat( "proj_dir/", @d_entry.minus )>;
@@ -68,11 +62,11 @@
 /*! \fn app Table mFitBatch( Table diff_tbl, Image diff_imgs[] )
-  \brief Generates a corrected image from imgs and the information from corr_tbl
+    \brief Generates a corrected image from imgs and the information from corr_tbl
-  \param diff_tbl
-  \param diff_imgs
-  \return fits_tbl
+    \param diff_tbl
+    \param diff_imgs
+    \return fits_tbl
 ( Table fits_tbl ) mFitBatch( Table diff_tbl, Image diff_imgs[] )
@@ -84,11 +78,11 @@
 /*! \fn Image mProjectPPBatch( Image raw_imgs[], MosaicData hdr )
-  \brief Projects the raw images from raw_imgs to a new plane that was declared in hdr.
+    \brief Projects the raw images from raw_imgs to a new plane that was declared in hdr.
-  \param raw_imgs[] List of raw images that need to be projected to new plane.
-  \return proj_imgs[] List of newly reprojected images.
+    \param raw_imgs[] List of raw images that need to be projected to new plane.
+    \return proj_imgs[] List of newly reprojected images.
 ( Image proj_imgs[] ) mProjectPPBatch( Image raw_imgs[], MosaicData hdr )
Modified: SwiftApps/Montage/Swift_Montage_Types.swift
--- SwiftApps/Montage/Swift_Montage_Types.swift	2010-07-07 20:20:19 UTC (rev 3429)
+++ SwiftApps/Montage/Swift_Montage_Types.swift	2010-07-08 02:19:22 UTC (rev 3430)
@@ -25,35 +25,26 @@
 type JPEG;
-/*! \struct CorrectStruct
-    \brief Struct to hold data found in the table that is generated from the mBgModel wrapper.
+/*! \struct BackgroundStruct
+    \brief Stuct to hold data found in the tables generated my mImgtbl and mBgModel
-type CorrectStruct
+type BackgroundStruct
-    int id; /*!< The id referencing which image this entry belongs to */
+    string fname;
+    float a;
+    float b;
+    float c;
 /*! \struct DiffStruct
     \brief Stuct to hold data found in the table that is generated from the mOverlaps wrapper.
-    \var int cntr1 The id referencing the first image in the difference table.
 type DiffStruct
-	int cntr1;   /*!< The id referencing the first image in the difference table. */
-	int cntr2;   /*!< The id referencing the second image in the difference table. */
-	Image plus;  /*!< The name of the image referenced by the id number cntr1. */
-	Image minus; /*!< The name of the image referenced by the id number cntr2. */
-	Image diff;  /*!< The name of the difference image that was created by plus and minus. */
+	int cntr1;
+	int cntr2;
+	Image plus;
+	Image minus;
+	Image diff;
-/*! \struct ImageStruct
-    \brief Struct to hold data found in the table that is generated from the mImgtbl wrapper.
-type ImageStruct
-    int cntr; /*!< The id referencing which image this entry belongs to */
Modified: SwiftApps/Montage/makefile
--- SwiftApps/Montage/makefile	2010-07-07 20:20:19 UTC (rev 3429)
+++ SwiftApps/Montage/makefile	2010-07-08 02:19:22 UTC (rev 3430)
@@ -7,4 +7,4 @@
 	swiftrun montage.swift
 clean:
-	@rm -rvf proj_dir/* diff_dir/* final/* corr_dir/* debug diffs.tbl images-rawdir.tbl images.tbl corrections.tbl fits.tbl stats.tbl
+	@rm -rvf proj_dir/* diff_dir/* final/* corr_dir/* debug diffs.tbl images-rawdir.tbl images.tbl corrections.tbl fits.tbl stats.tbl back_tmp.tbl *.txt
Modified: SwiftApps/Montage/montage.sh
--- SwiftApps/Montage/montage.sh	2010-07-07 20:20:19 UTC (rev 3429)
+++ SwiftApps/Montage/montage.sh	2010-07-08 02:19:22 UTC (rev 3430)
@@ -13,9 +13,9 @@
 mDiffExec -p proj_dir -n diffs.tbl template.hdr diff_dir
 mFitExec diffs.tbl fits.tbl diff_dir
 mBgModel images.tbl fits.tbl corrections.tbl
-# mBgExec -p proj_dir -n images.tbl corrections.tbl corr_dir
-# mAdd -p corr_dir -n images.tbl template.hdr final/mosaic.fits
-# mJPEG -gray final/mosaic.fits 20% 99.98% loglog -out final/mosaic.jpg
+mBgExec -p proj_dir -n images.tbl corrections.tbl corr_dir
+mAdd -p corr_dir -n images.tbl template.hdr final/mosaic.fits
+mJPEG -gray final/mosaic.fits 20% 99.98% loglog -out final/mosaic.jpg
 END=$(date +%s)
 DIFF=$(( $END - $START ))
Modified: SwiftApps/Montage/montage.swift
--- SwiftApps/Montage/montage.swift	2010-07-07 20:20:19 UTC (rev 3429)
+++ SwiftApps/Montage/montage.swift	2010-07-08 02:19:22 UTC (rev 3430)
@@ -24,10 +24,6 @@
 difference_images = mDiffBatch( difference_tbl, template );
 fits_images_tbl = mFitBatch( difference_tbl, difference_images );
 corrections_tbl = mBgModel( images_tbl, fits_images_tbl );
-// Up to here the scripts work.
-//corrected_images = mBgBatch( images_tbl, corrections_tbl );
-/* mBgBatch( images_tbl, corrections_tbl ); */
-/* corrected_mos = mAdd( corrected_images, images_tbl, template ); */
-/* corrected_jpg_img = mJPEG( corrected_mos ); */
+corrected_images = mBgBatch( projected_images, images_tbl, corrections_tbl );
+corrected_mos = mAdd( corrected_images, images_tbl, template );
+corrected_jpg_img = mJPEG( corrected_mos );
