[Swift-commit] r3429 - trunk/src/org/griphyn/vdl/mapping/file
Wed Jul 7 15:20:19 CDT 2010
Author: wozniak
Date: 2010-07-07 15:20:19 -0500 (Wed, 07 Jul 2010)
New Revision: 3429
Modified:
   trunk/src/org/griphyn/vdl/mapping/file/CSVMapper.java
Log:
Follow-up bug fix to CSVMapper
Modified: trunk/src/org/griphyn/vdl/mapping/file/CSVMapper.java
--- trunk/src/org/griphyn/vdl/mapping/file/CSVMapper.java	2010-07-06 21:54:12 UTC (rev 3428)
+++ trunk/src/org/griphyn/vdl/mapping/file/CSVMapper.java	2010-07-07 20:20:19 UTC (rev 3429)
@@ -21,6 +21,7 @@
 import org.griphyn.vdl.mapping.MappingParam;
 import org.griphyn.vdl.mapping.Path;
 import org.griphyn.vdl.mapping.PhysicalFormat;
+import org.griphyn.vdl.type.Types;
 public class CSVMapper extends AbstractMapper {
 	public static final MappingParam PARAM_FILE = new MappingParam("file");
@@ -133,10 +134,16 @@
 	    String result = null;
 	    Object object = PARAM_FILE.getRawValue(this);
         DSHandle handle = (DSHandle) object;
-        Mapper mapper = handle.getMapper();
-        PhysicalFormat format = mapper.map(Path.EMPTY_PATH);
-        GeneralizedFileFormat fileFormat =
-            (GeneralizedFileFormat) format;
+        GeneralizedFileFormat fileFormat;
+        if (handle.getType().equals(Types.STRING)) {
+            String path = (String) handle.getValue();
+            fileFormat = new AbsFile(path);
+        else {
+            Mapper mapper = handle.getMapper();
+            PhysicalFormat format = mapper.map(Path.EMPTY_PATH);
+            fileFormat = (GeneralizedFileFormat) format;
         result  = fileFormat.getPath();
         return result;
