[Swift-commit] r3579 - trunk/tests/cdm-ps
noreply at svn.ci.uchicago.edu
Mon Aug 30 12:16:13 CDT 2010
Author: wozniak
Date: 2010-08-30 12:16:13 -0500 (Mon, 30 Aug 2010)
New Revision: 3579
Added:
trunk/tests/cdm-ps/201-direct-output.check.sh
trunk/tests/cdm-ps/201-direct-output.clean.sh
trunk/tests/cdm-ps/201-direct-output.setup.sh
trunk/tests/cdm-ps/201-direct-output.swift
trunk/tests/cdm-ps/README.txt
trunk/tests/cdm-ps/fs.template.data
trunk/tests/cdm-ps/title.txt
Log:
Copy of CDM tests for provider staging tests
Copied: trunk/tests/cdm-ps/201-direct-output.check.sh (from rev 3576, trunk/tests/cdm/201-direct-output.check.sh)
--- trunk/tests/cdm-ps/201-direct-output.check.sh (rev 0)
+++ trunk/tests/cdm-ps/201-direct-output.check.sh 2010-08-30 17:16:13 UTC (rev 3579)
@@ -0,0 +1,8 @@
+#!/bin/sh
+set -x
+grep $( uname -m ) 201-input.txt || exit 1
+grep $( uname -m ) 201/output.txt || exit 1
+exit 0
Copied: trunk/tests/cdm-ps/201-direct-output.clean.sh (from rev 3576, trunk/tests/cdm/201-direct-output.clean.sh)
--- trunk/tests/cdm-ps/201-direct-output.clean.sh (rev 0)
+++ trunk/tests/cdm-ps/201-direct-output.clean.sh 2010-08-30 17:16:13 UTC (rev 3579)
@@ -0,0 +1,7 @@
+#!/bin/sh
+set -x
+rm -rv 201-input.txt 201
+exit 0
Copied: trunk/tests/cdm-ps/201-direct-output.setup.sh (from rev 3576, trunk/tests/cdm/201-direct-output.setup.sh)
--- trunk/tests/cdm-ps/201-direct-output.setup.sh (rev 0)
+++ trunk/tests/cdm-ps/201-direct-output.setup.sh 2010-08-30 17:16:13 UTC (rev 3579)
@@ -0,0 +1,10 @@
+#!/bin/sh
+set -x
+ uname -a
+ date
+} > 201-input.txt
+exit 0
Copied: trunk/tests/cdm-ps/201-direct-output.swift (from rev 3576, trunk/tests/cdm/201-direct-output.swift)
--- trunk/tests/cdm-ps/201-direct-output.swift (rev 0)
+++ trunk/tests/cdm-ps/201-direct-output.swift 2010-08-30 17:16:13 UTC (rev 3579)
@@ -0,0 +1,14 @@
+type file;
+app (file o) copy (file i)
+ cp @i @o;
+file f1<"201-input.txt">;
+// Will be transformed by CDM to 201/output.txt:
+file f2<"output.txt">;
+f2 = copy(f1);
Copied: trunk/tests/cdm-ps/README.txt (from rev 3576, trunk/tests/cdm/README.txt)
--- trunk/tests/cdm-ps/README.txt (rev 0)
+++ trunk/tests/cdm-ps/README.txt 2010-08-30 17:16:13 UTC (rev 3579)
@@ -0,0 +1,5 @@
+000 series : noop tests
+200 series : DIRECT tests
+300 series : BROADCAST test
Copied: trunk/tests/cdm-ps/fs.template.data (from rev 3576, trunk/tests/cdm/fs.template.data)
--- trunk/tests/cdm-ps/fs.template.data (rev 0)
+++ trunk/tests/cdm-ps/fs.template.data 2010-08-30 17:16:13 UTC (rev 3579)
@@ -0,0 +1 @@
+rule .*output.txt DIRECT _PWD_/201
Copied: trunk/tests/cdm-ps/title.txt (from rev 3576, trunk/tests/cdm/title.txt)
--- trunk/tests/cdm-ps/title.txt (rev 0)
+++ trunk/tests/cdm-ps/title.txt 2010-08-30 17:16:13 UTC (rev 3579)
@@ -0,0 +1 @@
+CDM tests
More information about the Swift-commit
