[Swift-commit] r3578 - trunk/libexec
noreply at svn.ci.uchicago.edu
Fri Aug 27 17:15:46 CDT 2010
Author: wozniak
Date: 2010-08-27 17:15:46 -0500 (Fri, 27 Aug 2010)
New Revision: 3578
Modified:
trunk/libexec/_swiftwrap
trunk/libexec/_swiftwrap.staging
trunk/libexec/cdm_lib.sh
trunk/libexec/vdl-int-staging.k
Log:
Enable CDM DIRECT for input with provider staging
Modified: trunk/libexec/_swiftwrap
--- trunk/libexec/_swiftwrap 2010-08-27 22:15:23 UTC (rev 3577)
+++ trunk/libexec/_swiftwrap 2010-08-27 22:15:46 UTC (rev 3578)
@@ -6,7 +6,7 @@
echo >& "$INFO"
echo "_____________________________________________________________________________" >& "$INFO"
echo >& "$INFO"
- echo " $1" >& "$INFO"
+ echo " $1" >& "$INFO"
echo >& "$INFO"
@@ -121,104 +121,23 @@
for a in ${!ARRAY}
do
- if [[ ${a} == ${X} ]]; then
+ if [[ ${a} == ${X} ]]; then
return 0
fi
done
return 1
-# Output:
-cdm_lookup() {
- FILE=$1
- CDM_FILE=$2
- RESULT="DEFAULT"
- if [ -f shared/cdm.pl ]; then
- RESULT=$( perl shared/cdm.pl lookup $FILE < $CDM_FILE 2> $INFO )
- checkError 254 "CDM[LOOKUP]: failed! (malformed CDM file?)"
- fi
- echo $RESULT
-cdm_action() {
- log "CDM_ACTION: $@"
- local JOBDIR=$1 # Given jobdir
- local MODE=$2 # INPUT or OUTPUT
- local FILE=$3 # User file
- local POLICY=$4 # DIRECT, BROADCAST, ...
- shift 4
- local ARGS=$@
- case $POLICY in
- DIRECT)
- DIRECT_DIR=${ARGS[0]}
- log "CDM[DIRECT]: Linking to $DIRECT_DIR/$FILE via $JOBDIR/$FILE"
- if [ $MODE == "INPUT" ]; then
- [ -f "$DIRECT_DIR/$FILE" ]
- checkError 254 "CDM[DIRECT]: $DIRECT_DIR/$FILE does not exist!"
- ln -s $DIRECT_DIR/$FILE $JOBDIR/$FILE
- checkError 254 "CDM[DIRECT]: Linking to $DIRECT_DIR/$FILE failed!"
- elif [ $MODE == "OUTPUT" ]; then
- mkdir -p $DIRECT_DIR
- checkError 254 "CDM[DIRECT]: mkdir -p $DIRECT_DIR failed!"
- mkdir -p $( dirname $DIRECT_DIR/$FILE )
- checkError 254 "CDM[DIRECT]: mkdir -p $( dirname $FILE ) failed!"
- touch $DIRECT_DIR/$FILE
- checkError 254 "CDM[DIRECT]: Touching $DIRECT_DIR/$FILE failed!"
- else
- fail 254 "Unknown MODE: $MODE"
- fi
- LOCAL)
- TOOL=${ARGS[0]}
- REMOTE_DIR=${ARGS[1]}
- FLAGS=${ARGS[3]}
- log "CDM[LOCAL]: Copying $DIRECT_DIR/$FILE to $JOBDIR/$FILE"
- checkError 254 "CDM[LOCAL]: $REMOTE_DIR/$FILE does not exist!"
- $TOOL $FLAGS $REMOTE_DIR/$FILE $JOBDIR/$FILE
- checkError 254 "CDM[LOCAL]: Tool failed!"
- log "CDM[LOCAL]..."
- else
- fi
- BROADCAST)
- BROADCAST_DIR=${ARGS[0]}
- log "CDM[BROADCAST]: Linking $JOBDIR/$FILE to $BROADCAST_DIR/$FILE"
- [ -f "$BROADCAST_DIR/$FILE" ]
- checkError 254 "CDM[BROADCAST]: $BROADCAST_DIR/$FILE does not exist!"
- ln -s $BROADCAST_DIR/$FILE $JOBDIR/$FILE
- checkError 254 "CDM[BROADCAST]: Linking to $BROADCAST_DIR/$FILE failed!"
- else
- echo "CDM[BROADCAST]: Skipping output file: ${FILE}"
- fi
- GATHER)
- fail 254 "Cannot GATHER an input file!"
- fi
- esac
cdm_local_output()
L=$1
- if [[ $CDM_FILE == "" ]]; then
+ if [[ $CDM_FILE == "" ]]; then
return
fi
- CDM_POLICY=$( cdm_lookup $L $CDM_FILE )
- if [[ $CDM_POLICY == "LOCAL" ]]; then
+ CDM_POLICY=$( cdm_lookup shared/cdm.pl $CDM_FILE $L )
+ if [[ $CDM_POLICY == "LOCAL" ]]; then
cdm_local_output_perform $L $CDM_POLICY
fi
@@ -239,13 +158,13 @@
cdm_gather()
GATHER_OUTPUT=${*}
return
fi
- if [[ $GATHER_OUTPUT == "" ]]; then
+ if [[ $GATHER_OUTPUT == "" ]]; then
return
fi
cdm_gather_action $GATHER_MAX $GATHER_OUTPUT
@@ -333,7 +252,7 @@
getarg "-cdmfile" "$@"
CDM_FILE=
-if [ "X$VALUE" != "X" ]; then
+if [ "X$VALUE" != "X" ]; then
CDM_FILE=shared/$VALUE
fi
shift $SHIFTCOUNT
@@ -429,10 +348,10 @@
logstate "LINK_INPUTS"
for L in $INF ; do
if [ $CDM_POLICY != "DEFAULT" ]; then
log "CDM_POLICY: $L -> $CDM_POLICY"
- eval cdm_action $DIR "INPUT" $L $CDM_POLICY
+ eval cdm_action $DIR "INPUT" $L $CDM_POLICY
continue
fi
if [ $COPYNOTLINK = 1 ]; then
@@ -441,7 +360,7 @@
log "Copied input: $WFDIR/shared/$L to $DIR/$L"
else
[ -f $WFDIR/shared/$L ]
- checkError 254 "Could not locate input file: $L"
+ checkError 254 "Could not locate input file: $L"
ln -s "$WFDIR/shared/$L" "$DIR/$L" 2>&1 >& $INFO
checkError 254 "Failed to link input file $L"
log "Linked input: $WFDIR/shared/$L to $DIR/$L"
@@ -452,16 +371,16 @@
SKIPPED_OUTPUT=()
GATHER_OUTPUT=()
for L in $OUTF ; do
- if [[ $CDM_POLICY != "DEFAULT" &&
+ if [[ $CDM_POLICY != "DEFAULT" &&
$CDM_POLICY != "BROADCAST"* ]]; then
- log "CDM_POLICY: $L -> $CDM_POLICY"
+ log "CDM_POLICY: $L -> $CDM_POLICY"
eval cdm_action $DIR "OUTPUT" $L $CDM_POLICY
SKIPPED_OUTPUT=( $SKIPPED_OUTPUT $L )
fi
- if [ $CDM_POLICY == "GATHER" ]; then
+ if [ $CDM_POLICY == "GATHER" ]; then
GATHER_OUTPUT=( $GATHER_OUTPUT $L )
- elif [ $CDM_POLICY == "LOCAL" ]; then
+ elif [ $CDM_POLICY == "LOCAL" ]; then
CDM_LOCAL_OUTPUT=( $CDM_LOCAL_OUTPUT $L )
fi
done
@@ -496,7 +415,7 @@
else
if [ ! -f "$KICKSTART" ]; then
log "Kickstart executable ($KICKSTART) not found"
- fail 254 "The Kickstart executable ($KICKSTART) was not found"
+ fail 254 "The Kickstart executable ($KICKSTART) was not found"
elif [ ! -x "$KICKSTART" ]; then
log "Kickstart executable ($KICKSTART) is not executable"
fail 254 "The Kickstart executable ($KICKSTART) does not have the executable bit set"
@@ -550,7 +469,7 @@
logstate "RM_JOBDIR"
rm -rf "$DIR" 2>&1 >& "$INFO"
-checkError 254 "Failed to remove job directory $DIR"
+checkError 254 "Failed to remove job directory $DIR"
if [ "$STATUSMODE" = "files" ]; then
logstate "TOUCH_SUCCESS"
@@ -569,7 +488,7 @@
# ensure we exit with a 0 after a successful execution
exit 0
-# Local Variables:
+# Local Variables:
# mode: sh
# sh-basic-offset: 8
# End:
Modified: trunk/libexec/_swiftwrap.staging
--- trunk/libexec/_swiftwrap.staging 2010-08-27 22:15:23 UTC (rev 3577)
+++ trunk/libexec/_swiftwrap.staging 2010-08-27 22:15:46 UTC (rev 3578)
@@ -4,7 +4,7 @@
echo >& "$INFO"
echo >& "$INFO"
echo >& "$INFO"
@@ -164,6 +164,14 @@
KICKSTART=$VALUE
shift $SHIFTCOUNT
+getarg "-cdmfile" "$@"
+CDM_FILE=
+ CDM_FILE=$VALUE
+ log "CDM_FILE: $CDM_FILE"
+fi
+shift $SHIFTCOUNT
getarg "-status" "$@"
STATUSMODE=$VALUE
shift $SHIFTCOUNT
@@ -187,6 +195,8 @@
fail 254 "Missing arguments (-a option)"
fi
+[[ $CDM_FILE != "" ]] && source cdm_lib.sh
PATH=$PATH:/bin:/usr/bin
if [ "$PATHPREFIX" != "" ]; then
@@ -205,6 +215,7 @@
fi
fi
+log "PWD=$PWD"
log "EXEC=$EXEC"
log "STDIN=$STDIN"
log "STDOUT=$STDOUT"
@@ -225,6 +236,14 @@
log "Created output directory: $D"
done
+if [[ $CDM_FILE != "" ]] ; then
+ for F in $INF ; do
+ CDM_POLICY=$( cdm_lookup cdm.pl $CDM_FILE $F )
+ log "CDM_POLICY: $F -> $CDM_POLICY"
+ eval cdm_action $PWD "INPUT" $F $CDM_POLICY
+ done
+fi
logstate "EXECUTE"
#ls >>$WRAPPERLOG
@@ -285,3 +304,9 @@
exit 0
+# Local Variables:
+# mode: sh
+# sh-basic-offset: 4
+# tab-width: 4
+# indent-tabs-mode: 1
+# End:
Modified: trunk/libexec/cdm_lib.sh
--- trunk/libexec/cdm_lib.sh 2010-08-27 22:15:23 UTC (rev 3577)
+++ trunk/libexec/cdm_lib.sh 2010-08-27 22:15:46 UTC (rev 3578)
@@ -1,6 +1,90 @@
# Source this for CDM shell functions
+log "Reading cdm_lib.sh ..."
+# Do a CDM lookup
+cdm_lookup() {
+ CDM_PL=$1
+ CDM_FILE=$2
+ FILE=$3
+ RESULT="DEFAULT"
+ if [ -f $CDM_PL ]; then
+ RESULT=$( perl $CDM_PL lookup $FILE < $CDM_FILE 2> $INFO )
+ checkError 254 "cdm_lookup(): failed! (malformed CDM file?)"
+ fi
+ echo $RESULT
+cdm_action() {
+ log "CDM_ACTION: $@"
+ local JOBDIR=$1 # Given jobdir
+ local MODE=$2 # INPUT or OUTPUT
+ local FILE=$3 # User file
+ local POLICY=$4 # DIRECT, BROADCAST, ...
+ shift 4
+ local ARGS=$@
+ log "POLICY=$POLICY"
+ case $POLICY in
+ DIRECT)
+ DIRECT_DIR=${ARGS[0]}
+ log "CDM[DIRECT]: Linking to $DIRECT_DIR/$FILE via $JOBDIR/$FILE"
+ if [ $MODE == "INPUT" ]; then
+ [ -f "$DIRECT_DIR/$FILE" ]
+ checkError 254 "CDM[DIRECT]: $DIRECT_DIR/$FILE does not exist!"
+ ln -s $DIRECT_DIR/$FILE $JOBDIR/$FILE
+ checkError 254 "CDM[DIRECT]: Linking to $DIRECT_DIR/$FILE failed!"
+ elif [ $MODE == "OUTPUT" ]; then
+ mkdir -p $DIRECT_DIR
+ checkError 254 "CDM[DIRECT]: mkdir -p $DIRECT_DIR failed!"
+ mkdir -p $( dirname $DIRECT_DIR/$FILE )
+ checkError 254 "CDM[DIRECT]: mkdir -p $( dirname $FILE ) failed!"
+ touch $DIRECT_DIR/$FILE
+ checkError 254 "CDM[DIRECT]: Touching $DIRECT_DIR/$FILE failed!"
+ else
+ fail 254 "Unknown MODE: $MODE"
+ fi
+ LOCAL)
+ TOOL=${ARGS[0]}
+ REMOTE_DIR=${ARGS[1]}
+ FLAGS=${ARGS[3]}
+ log "CDM[LOCAL]: Copying $DIRECT_DIR/$FILE to $JOBDIR/$FILE"
+ checkError 254 "CDM[LOCAL]: $REMOTE_DIR/$FILE does not exist!"
+ $TOOL $FLAGS $REMOTE_DIR/$FILE $JOBDIR/$FILE
+ checkError 254 "CDM[LOCAL]: Tool failed!"
+ log "CDM[LOCAL]..."
+ else
+ fi
+ BROADCAST)
+ BROADCAST_DIR=${ARGS[0]}
+ log "CDM[BROADCAST]: Linking $JOBDIR/$FILE to $BROADCAST_DIR/$FILE"
+ [ -f "$BROADCAST_DIR/$FILE" ]
+ checkError 254 "CDM[BROADCAST]: $BROADCAST_DIR/$FILE does not exist!"
+ ln -s $BROADCAST_DIR/$FILE $JOBDIR/$FILE
+ checkError 254 "CDM[BROADCAST]: Linking to $BROADCAST_DIR/$FILE failed!"
+ else
+ echo "CDM[BROADCAST]: Skipping output file: ${FILE}"
+ fi
+ GATHER)
+ fail 254 "Cannot GATHER an input file!"
+ fi
+ esac
# Setup GATHER_DIR and some variables
cdm_gather_setup() {
GATHER_DIR=$1
@@ -8,7 +92,7 @@
logstate "GATHER_DIR $GATHER_DIR"
mkdir -p $GATHER_DIR
checkError 254 "Could not create: $GATHER_DIR"
GATHER_LOCKFILE=$GATHER_DIR/.cdm.lock
GATHER_MY_FILE=$GATHER_DIR/.cdm-$ID.lock
GATHER_MY_OUTBOX=$GATHER_DIR/.cdm-outgoing-$ID
@@ -72,7 +156,7 @@
unlink $GATHER_LOCKFILE
-# Move files from (LFS) OUTBOX to (GFS) GATHER_TARGET
+# Move files from (LFS) OUTBOX to (GFS) GATHER_TARGET
cdm_gather_flush() {
pushd ${GATHER_MY_OUTBOX}
logstate "GATHER_TARGET $GATHER_TARGET"
@@ -93,10 +177,10 @@
GATHER_MAX=$( perl shared/cdm.pl property GATHER_LIMIT < $CDM_FILE )
GATHER_TARGET=$( perl shared/cdm.pl property GATHER_TARGET < $CDM_FILE )
- cdm_gather_setup $GATHER_DIR
- cdm_gather_lock_acquire
+ cdm_gather_setup $GATHER_DIR
+ cdm_gather_lock_acquire
- cdm_gather_import
+ cdm_gather_import
USAGE=$( du -s --exclude=".cdm*" -B 1 $GATHER_DIR )
USAGE=${USAGE% *} # Chop off filename in output
@@ -104,22 +188,22 @@
logstate "USAGE_CHECK $USAGE / $GATHER_MAX"
FLUSH="no"
- if (( USAGE > GATHER_MAX )); then
+ if (( USAGE > GATHER_MAX )); then
FLUSH="yes"
cdm_gather_export
fi
cdm_gather_lock_release
- if [ $FLUSH == "yes" ]; then
- cdm_gather_flush
+ if [ $FLUSH == "yes" ]; then
+ cdm_gather_flush
fi
# Called by cdm_cleanup.sh at the end of the workflow
cdm_gather_cleanup() {
declare -p PWD DIR GATHER_DIR GATHER_TARGET ID
cdm_gather_export
EXPORT_RESULT=$?
@@ -128,7 +212,10 @@
fi
-# Local Variables:
+# Local Variables:
# mode: sh
-# sh-basic-offset: 8
+# tab-width: 4
# End:
Modified: trunk/libexec/vdl-int-staging.k
--- trunk/libexec/vdl-int-staging.k 2010-08-27 22:15:23 UTC (rev 3577)
+++ trunk/libexec/vdl-int-staging.k 2010-08-27 22:15:46 UTC (rev 3578)
@@ -22,11 +22,11 @@
ddir
element(inFiles, [stageins]
pathnames(stageins)
element(fileDirs, [stageins, stageouts]
list(
unique(
@@ -35,13 +35,13 @@
element(graphStuff, [tr, stagein, stageout, err, optional(args)]
if(
vdl:configProperty("pgraph") != "false" then(
errprops := if(err ",color=lightsalmon" ",color=lightsteelblue1")
tp := vdl:threadPrefix()
- to(graph,
+ to(graph,
concat(str:quote(tp), " [label=", str:quote(tr), "{errprops}]")
for(si, stagein
@@ -57,7 +57,7 @@
file := basename(file)
label := vdl:niceName(var, path = path)
to(graph
- concat(str:quote(file), " [shape=parallelogram,label=",
+ concat(str:quote(file), " [shape=parallelogram,label=",
str:quote(label), "]")
concat(str:quote(tp), " -> ", str:quote(file))
@@ -65,13 +65,13 @@
element(fileSizes, [files]
math:sum(
for(f, files, file:size(file))
element(cleanups, [cleanup]
log(LOG:INFO, "START cleanups={cleanup}")
@@ -80,17 +80,17 @@
replicationGroup, replicationChannel]
stagein := list(unique(each(stagein)))
stageout := list(unique(each(stageout)))
allocateHost(rhost, constraints=vdl:jobConstraints(tr, stagein=stagein)
ddir := initDDir()
uid := uid()
jobdir := substring(uid, from=0, to=1)
jobid := "{tr}-{uid}"
fileDirs := fileDirs(stagein, stageout)
log(LOG:DEBUG, "THREAD_ASSOCIATION jobid={jobid} thread={#thread} host={rhost} replicationGroup={replicationGroup}")
wrapper := "_swiftwrap.staging"
@@ -102,11 +102,12 @@
vdl:setprogress("Stage in")
wfdir := "{VDL:SCRIPTNAME}-{VDL:RUNID}"
tmpdir := dircat("{wfdir}/jobs/{jobdir}", jobid)
+ cdmfile := cdm:file()
try(
sequential(
log(LOG:DEBUG, "JOB_START jobid={jobid} tr={tr}", maybe(" arguments=", arguments), " tmpdir={tmpdir} host={rhost}")
vdl:setprogress("Submitting")
vdl:execute(
@@ -114,14 +115,15 @@
list(
vdl:siteprofile(rhost, "swift:wrapperInterpreterOptions"),
wrapper,
- "-e", vdl:executable(tr, rhost),
+ "-e", vdl:executable(tr, rhost),
"-out", stdout,
- "-err", stderr,
+ "-err", stderr,
"-i", maybe(stdin),
"-d", flatten(each(fileDirs)),
- "-if", flatten(infiles(stagein)),
+ "-if", flatten(infiles(stagein)),
"-of", flatten(outfiles(stageout)),
"-k",
+ "-cdmfile", cdmfile,
"-status", "provider"
"-a", maybe(each(arguments))
@@ -132,17 +134,27 @@
replicationGroup = replicationGroup
replicationChannel = replicationChannel
jobid = jobid
- stagingMethod := vdl:siteProfile(rhost, "swift:stagingMethod", default="proxy")
+ stagingMethod := vdl:siteProfile(rhost, "swift:stagingMethod", default="proxy")
stageIn("{stagingMethod}://localhost/{swift.home}/libexec/{wrapper}", wrapper)
+ if( cdmfile != "" then(
+ d := vdl:dirname(cdmfile)
+ f := basename(cdmfile)
+ echo("d: {d} f: {f}")
+ stageIn("{stagingMethod}://localhost/{d}/{f}", cdmfile)
+ stageIn("{stagingMethod}://localhost/{swift.home}/libexec/cdm.pl", "cdm.pl")
+ stageIn("{stagingMethod}://localhost/{swift.home}/libexec/cdm_lib.sh", "cdm_lib.sh")
appStageins(jobid, stagein, ".", stagingMethod)
stageOut("wrapper.log", "{stagingMethod}://localhost/{ddir}/{jobid}.info")
//stageOut("{stdout}", "{stagingMethod}://localhost/{ddir}/{stdout}")
//stageOut("{stderr}", "{stagingMethod}://localhost/{ddir}/{stderr}")
appStageouts(jobid, stageout, ".", stagingMethod)
task:cleanUp(".") //the whole job directory
doRestartlog(restartout)
@@ -155,7 +167,7 @@
catch("^(?!Abort$).*"
vdl:setprogress("Failed but can retry")
log(LOG:DEBUG, "APPLICATION_EXCEPTION jobid={jobid} - Application exception: ", exception)
throw(
exception(
concat(
@@ -173,7 +185,7 @@
element(generateProvenanceGraph, [gdata]
pgraph := vdl:configProperty("pgraph")
gname := if(pgraph == "true" "{VDL:SCRIPTNAME}-{VDL:RUNID}.dot" pgraph)
@@ -181,7 +193,7 @@
"digraph SwiftProvenance {{", nl()
" graph [", vdl:configProperty("pgraph.graph.options"), "];", nl()
" node [", vdl:configProperty("pgraph.node.options"), "];", nl()
for(i, gdata
" ", i, nl()
More information about the Swift-commit
