[Swift-commit] r3580 - trunk/tests/cdm-ps
noreply at svn.ci.uchicago.edu
Mon Aug 30 12:17:51 CDT 2010
Author: wozniak
Date: 2010-08-30 12:17:51 -0500 (Mon, 30 Aug 2010)
New Revision: 3580
Added:
trunk/tests/cdm-ps/swift.properties
Log:
Copy of etc/swift.properties
Copied: trunk/tests/cdm-ps/swift.properties (from rev 3566, trunk/etc/swift.properties)
--- trunk/tests/cdm-ps/swift.properties (rev 0)
+++ trunk/tests/cdm-ps/swift.properties 2010-08-30 17:17:51 UTC (rev 3580)
@@ -0,0 +1,352 @@
+sites.file=${swift.home}/etc/sites.xml
+tc.file=${swift.home}/etc/tc.data
+# The host name of the submit machine is used by GRAM as a callback
+# address to report the status of submitted jobs. In general, Swift
+# can automatically detect the host name of the local machine.
+# However, if the machine host name is improperly configured or if
+# it does not represent a valid DNS entry, certain services (such as
+# GRAM) will not be able to send job status notifications back to
+# the client. The value of this property can be an IP address.
+# Format:
+# hostname=string
+#hostname=localhost
+# A TCP port range can be specified to restrict the ports on which GRAM
+# callback services are started. This is likely needed if your submit
+# host is behind a firewall, in which case the firewall should be
+# configured to allow incoming connections on ports in the range.
+# Format:
+# tcp.port.range=start,end
+#tcp.port.range=50000,50100
+# false - means an error will be immediately reported and cause the
+# workflow to abort. At this time remote jobs that are already
+# running will not be canceled
+# true - means that Swift will try to do as much work as possible and
+# report all errors encountered at the end. However, "errors"
+# here only applies to job execution errors. Certain errors
+# that are related to the Swift implementation (should such
+# errors occur) will still be reported eagerly.
+# Default: false
+lazy.errors=false
+# What algorithm to use for caching of remote files. LRU (as in what
+# files to purge) is the only implementation right now. One can set
+# a target size (in bytes) for a host by using the swift:storagesize
+# profile for a host in sites.xml
+# Default: LRU
+caching.algorithm=LRU
+# true - generate a provenance graph in .dot format (Swift will
+# choose a random file name)
+# false - do not generate a provenance graph
+# <filename> - generate a provenange graph in the give file name
+# Default: false
+pgraph=false
+# graph properties for the provenance graph (.dot specific)
+# Default: splines="compound", rankdir="TB"
+pgraph.graph.options=splines="compound", rankdir="TB"
+# node properties for the provenance graph (.dot specific)
+# Default: color="seagreen", style="filled"
+pgraph.node.options=color="seagreen", style="filled"
+# true - clustering of small jobs is enabled. Clustering works in the
+# following way: If a job is clusterable (meaning that it has the
+# GLOBUS::maxwalltime profile specified in tc.data and its value
+# is less than the value of the "clustering.min.time" property) it will
+# be put in a clustering queue. The queue is processed at intervals
+# specified by the "clustering.queue.delay" property. The processing
+# of the clustering queue consists of selecting compatible jobs and
+# grouping them in clusters whose max wall time does not exceed twice
+# the value of the "clustering.min.time" property. Two or more jobs are
+# considered compatible if they share the same site and do not have
+# conflicting profiles (e.g. different values for the same environment
+# variable).
+# false - clustering of small jobs is disabled.
+# Default: false
+clustering.enabled=false
+# <seconds> - the intervals at which the clustering queue is processed
+# Default: 4
+clustering.queue.delay=4
+# <seconds> - the threshold time for clustering
+# Default: 60
+clustering.min.time=60
+# Kickstart is a useful tool that can be used to gather various information
+# about a remote process. Before it can be used it must be installed on the
+# remote site and the corresponding entry be set in the sites file.
+# This option allows controlling of how Swift uses Kickstart. The following
+# values are possible:
+# false - do not use Kickstart
+# true - use Kickstart. If a job is scheduled on a site that does not have
+# Kickstart installed, that job will fail.
+# maybe - Use Kickstart if installed (i.e. the entry is present in the sites
+# file)
+# Default: maybe
+kickstart.enabled=maybe
+# Indicates when Kickstart records should be fetched from the remote site:
+# true - always transfer Kickstart records if Kickstart was used (see
+# kickstart.enabled)
+# false - only transfer Kickstart records if the job fails
+# Default: false
+kickstart.always.transfer=false
+# Indicates when wrapper logs should be fetched from the remote site:
+# true - always transfer wrapper logs
+# false - only transfer wrapper logs if the job fails
+# Default: false
+wrapperlog.always.transfer=false
+# Throttling options #
+# For the throttling parameters, valid values are either a positive integer
+# or "off" (without the quotes).
+# Limits the number of concurrent submissions for a workflow instance. This
+# throttle only limits the number of concurrent tasks (jobs) that are being
+# sent to sites, not the total number of concurrent jobs that can be run.
+# The submission stage in GRAM is one of the most CPU expensive stages (due
+# mostly to the mutual authentication and delegation). Having too many
+# concurrent submissions can overload either or both the submit host CPU
+# and the remote host/head node causing degraded performance.
+# Default: 4
+throttle.submit=4
+#throttle.submit=off
+# Limits the number of concurrent submissions for any of the sites Swift will
+# try to send jobs to. In other words it guarantees that no more than the
+# value of this throttle jobs sent to any site will be concurrently in a state
+# of being submitted.
+# Default: 2
+throttle.host.submit=2
+#throttle.host.submit=off
+# The Swift scheduler has the ability to limit the number of concurrent jobs
+# allowed on a site based on the performance history of that site. Each site
+# is assigned a score (initially 1), which can increase or decrease based
+# on whether the site yields successful or faulty job runs. The score for a
+# site can take values in the (0.1, 100) interval. The number of allowed jobs
+# is calculated using the following formula:
+# 2 + score*throttle.score.job.factor
+# This means a site will always be allowed at least two concurrent jobs and
+# at most 2 + 100*throttle.score.job.factor. With a default of 4 this means
+# at least 2 jobs and at most 402.
+# Default: 4
+throttle.score.job.factor=0.2
+#throttle.score.job.factor=off
+# Limits the total number of concurrent file transfers that can happen at any
+# given time. File transfers consume bandwidth. Too many concurrent transfers
+# can cause the network to be overloaded preventing various other signalling
+# traffic from flowing properly.
+# Default: 4
+throttle.transfers=4
+#throttle.transfers=off
+# Limits the total number of concurrent file operations that can happen at any
+# given time. File operations (like transfers) require an exclusive connection
+# to a site. These connections can be expensive to establish. A large number
+# of concurrent file operations may cause Swift to attempt to establish many
+# such expensive connections to various sites. Limiting the number of concurrent
+# file operations causes Swift to use a small number of cached connections and
+# achieve better overall performance.
+# Default: 8
+throttle.file.operations=8
+#throttle.file.operations=off
+# Indicates whether the working directory on the remote site should be
+# left intact even when the workflow completes successfully. This can be
+# used to inspect the site working directory for debugging purposes.
+# Default: false
+sitedir.keep=false
+# number of time a job will be retried if it fails (giving a maximum of
+# 1 + execution.retries attempts at execution)
+execution.retries=2
+# Enables/disables replication. Replication is used to deal with jobs sitting
+# in batch queues for abnormally large amounts of time. If replication is enabled
+# and certain conditions are met, Swift creates and submits replicas of jobs, and
+# allows multiple instances of a job to compete.
+replication.enabled=false
+# If replication is enabled, this value specifies the minimum time, in seconds,
+# a job needs to be queued in a batch queue in order to be considered for
+# replication
+replication.min.queue.time=60
+# The maximum number of replicas that Swift should attempt.
+replication.limit=3
+# WARNING: This option is deprecated. Please use the hostname option.
+# The IP address of the submit machine is used by GRAM as a callback
+# can automatically detect the IP address of the local machine.
+# However, if the machine has more than one network interface, Swift
+# will pick the first one, which may not be the right choice. It is
+# recommended that this property is set properly before attempting to
+# run jobs through GRAM.
+# Format:
+# ip.address=x.y.z.w
+#ip.address=127.0.0.1
+# Controls how Swift will communicate the result code of running user programs
+# from workers to the submit side. In files mode, a file
+# indicating success or failure will be created on the site shared filesystem.
+# In provider mode, the execution provider job status will
+# be used. Notably, GRAM2 does not return job statuses correctly, and so
+# provider mode will not work with GRAM2. With other
+# providers, it can be used to reduce the amount of filesystem access compared
+# to files mode.
+# status.mode=files
+# Controls how swift will supply parameters to the remote wrapper script.
+# 'args' mode will pass parameters on the command line
+# 'files' mode will pass parameters through an additional input file
+# valid values: args, files
+# Default: files
+# wrapper.parameter.mode=args
+# Determines if Swift remote wrappers will be executed by specifying an
+# absolute path, or a path relative to the job initial working directory
+# valid values: absolute, relative
+# wrapper.invocation.mode=absolute
+# Limits the number of concurrent iterations that each foreach statement
+# can have at one time. This conserves memory for swift programs that
+# have large numbers of iterations (which would otherwise all be executed
+# in parallel).
+# Default: 1024
+foreach.max.threads=16384
+# controls whether the log file will contain provenance information
+# enabling this will increase the size of log files, sometimes
+# significantly.
+provenance.log=false
+# Controls whether file staging is done by swift or by the execution
+# provider. If set to false, the standard swift staging mechanism is
+# used. If set to true, swift does not stage files. Instead, the
+# execution provider is instructed to stage files in and out.
+# Provider staging is experimental.
+# When enabled, and when coasters are used as an execution provider,
+# a staging mechanism can be selected for each site
+# using the swift:stagingMethod site profile in sites.xml. The
+# following is a list of accepted mechanisms:
+# * file: Staging is done from a filesystem accessible to the
+# coaster service (typically running on the head node)
+# * proxy: Staging is done from a filesystem accessible to the
+# client machine that swift is running on, and is proxied
+# through the coaster service
+# * sfs: (short for "shared filesystem") Staging is done by
+# copying files to and from a filesystem accessible
+# by the compute node (such as an NFS or GPFS mount).
+use.provider.staging=false
\ No newline at end of file
More information about the Swift-commit
