sieve-dev error compiling PETSc-3.1 with Sieve on Blue Gene/L
Matthew Knepley
knepley at gmail.com
Sun Apr 4 13:58:48 CDT 2010
Yes, this is a bug in the IBM compiler version I have had other places. In
the latest
petsc-dev, I just commented out the #include of ALE_args.hh in ALE.hh. This
fixes
it. Everyone hates compiler bugs.
Matt
On Sun, Apr 4, 2010 at 1:52 PM, Shi Jin <jinzishuai at gmail.com> wrote:
> Hi,
> I was recently asked to port my code developed a year ago using
> petsc-dev-sieve.
> I just checked, the code works without problem on a Linux cluster with
> gcc-4.3.2 built against petsc-3.1.0.
> However, I got the following error built on the BlueGene. I used the
> following steps:
> - ./configure —with-clanguage=C++ —with-sieve=1 —with-opt-sieve=1
> —download-chaco=1 —download-boost=1 —with-shared=0 —with-debugging=no
> —with-mpi-shared=0 —download-f-blas-lapack=1 —with-batch
> - cqsub -q debug -n 2 -t 00:10:00 conftest. Make sure the job is
> finished by "cqstat".
> - ./reconfigure.py
> It works fine. The output is
> Compilers:
> C Compiler: mpicc -Wall -Wwrite-strings -Wno-strict-aliasing -O
> C++ Compiler: mpicxx -Wall -Wwrite-strings -Wno-strict-aliasing -O
> Fortran Compiler: mpif77 -Wall -Wno-unused-variable -O
> Linkers:
> Static linker: /usr/bin/ar cr
> MPI:
> Includes: -I/bgl/BlueLight/V1R3M4_300_2008-080728/ppc/bglsys/include
> BLAS/LAPACK: -Wl,-rpath,/home/guntaka/src/petsc-3.1-p0/linux-gnu-cxx-opt/lib -L/home/guntaka/src/petsc-3.1-p0/linux-gnu-cxx-opt/lib -lflapack -Wl,-rpath,/home/guntaka/src/petsc-3.1-p0/linux-gnu-cxx-opt/lib -L/home/guntaka/src/petsc-3.1-p0/linux-gnu-cxx-opt/lib -lfblas
> Chaco:
> Library: -Wl,-rpath,/home/guntaka/src/petsc-3.1-p0/linux-gnu-cxx-opt/lib -L/home/guntaka/src/petsc-3.1-p0/linux-gnu-cxx-opt/lib -lchaco
> Sieve:
> Includes: -I/home/guntaka/src/petsc-3.1-p0/include/sieve
> Boost:
> Includes: -I/home/guntaka/src/petsc-3.1-p0/externalpackages/Boost/ -I/bgl/BlueLight/V1R3M4_300_2008-080728/ppc/bglsys/include
> PETSc:
> PETSC_ARCH: linux-gnu-cxx-opt
> PETSC_DIR: /home/guntaka/src/petsc-3.1-p0
> Clanguage: Cxx
> Scalar type: real
> Precision: double
> shared libraries: disabled
> dynamic libraries: disabled
> Memory alignment: 16
> xxx=========================================================================xxx
> Configure stage complete. Now build PETSc libraries with:
> make PETSC_DIR=/home/guntaka/src/petsc-3.1-p0 PETSC_ARCH=linux-gnu-cxx-opt all
> Then I moved ahead to build it
> But I got the following error in compiling sieve:
> /home/guntaka/src/petsc-3.1-p0/include/sieve/ALE_args.hh: In member function `ALE::ArgValue ALE::ArgDB::operator[](const string&) const':
> /home/guntaka/src/petsc-3.1-p0/include/sieve/ALE_args.hh:132: error: call of overloaded `ArgValue(ALE::ArgValue)' is ambiguous
> /home/guntaka/src/petsc-3.1-p0/include/sieve/ALE_args.hh:64: note: candidates are: ALE::ArgValue::ArgValue(const ALE::ArgValue&)
> /home/guntaka/src/petsc-3.1-p0/include/sieve/ALE_args.hh:67: note: ALE::ArgValue::ArgValue(const boost::program_options::variable_value&)
> I am using the mpicxx which is using g++ 3.4.3:
> guntaka at fr0103en:~/src/petsc-3.1-p0> mpicxx -show
> /bgl/BlueLight/V1R3M4_300_2008-080728/ppc/blrts-gnu/bin/powerpc-bgl-blrts-gnu-g++ -I/bgl/BlueLight/V1R3M4_300_2008-080728/ppc/bglsys/include -L/bgl/BlueLight/V1R3M4_300_2008-080728/ppc/bglsys/lib -lcxxmpich.rts -lmpich.rts -L/bgl/BlueLight/V1R3M4_300_2008-080728/ppc/bglsys/lib -lmsglayer.rts -ldevices.rts -lrts.rts -ldevices.rts -lrts.rts
> guntaka at fr0103en:~/src/petsc-3.1-p0> /bgl/BlueLight/V1R3M4_300_2008-080728/ppc/blrts-gnu/bin/powerpc-bgl-blrts-gnu-g++ --version
> I remember there was some issues with older versions of GCC. Not sure this is the same problem.
> Has anyone have any experience on this?
> Thank you very much.
> Shi
> powerpc-bgl-blrts-gnu-g++ (GCC) 3.4.3
> /home/guntaka/src/petsc-3.1-p0/include/sieve/ALE_args.hh:132: error: initializing temporary from result of `ALE::ArgValue::ArgValue(const boost::program_options::variable_value&)'
> Shi Jin, Ph.D.
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/sieve-dev/attachments/20100404/e3e0cf6d/attachment.htm>
More information about the sieve-dev
