sieve-dev error compiling PETSc-3.1 with Sieve on Blue Gene/L
Shi Jin jinzishuai at gmail.com
Sun Apr 4 16:54:09 CDT 2010
Thanks a lot Matt.
After switching to petsc-dev, I've successfully build petsc-dev-sieve with
the same configuration options on the BlueGene/L.
However, when I tried to build my code, I got the error at the final linking
stage (all objects are compiled sucessfully):
guntaka at fr0103en:~/src/fcpu> make
mpicxx -Wall -Wwrite-strings -Wno-strict-aliasing -O  -o fcpu main.o
Options.o USG.o Wall.o PlaneWall.o BC.o Quadrature.o Tetrahedron.o
TetrahedronTaylorHood.o Cylinder.o Sphere.o CylinderWall.o CFD.o NSSolver.o
ParticulateFlow.o BodyFitMeshPF.o CollisionBox.o GranularFlow.o
-Wl,-rpath,/home/guntaka/src/petsc-dev/linux-gnu-cxx-opt/lib
-L/home/guntaka/src/petsc-dev/linux-gnu-cxx-opt/lib -lpetsc
-L/home/guntaka/src/petsc-dev/linux-gnu-cxx-opt/lib -lchaco -lflapack
-lfblas -lm -L/bgl/BlueLight/V1R3M4_300_2008-080728/ppc/bglsys/lib
-L/bgl/BlueLight/V1R3M4_300_2008-080728/ppc/blrts-gnu/lib/gcc/powerpc-bgl-blrts-gnu/3.4.3
-L/bgl/BlueLight/V1R3M4_300_2008-080728/ppc/blrts-gnu/powerpc-bgl-blrts-gnu/lib
-lmpich.rts -lmsglayer.rts -ldevices.rts -lrts.rts -lg2c -lm -lm
-lcxxmpich.rts -lstdc++ -lmpich.rts -lmsglayer.rts -ldevices.rts -lrts.rts
collect2: ld terminated with signal 11 [Segmentation fault]
make: *** [fcpu] Error 1
The error message is not terribly helpful identifying the problem.
Do you know what could be wrong here?
Is there a known sieve test code I can try to build?
I tried to build something inside petsc-dev/src/dm/mesh/examples/tutorials
but haven't got anything to work yet.
Thanks a lot.
Shi
On Sun, Apr 4, 2010 at 12:58 PM, Matthew Knepley <knepley at gmail.com> wrote:
> Yes, this is a bug in the IBM compiler version I have had other places. In
> the latest
> petsc-dev, I just commented out the #include of ALE_args.hh in ALE.hh. This
> fixes
> it. Everyone hates compiler bugs.
>  Thanks,
>    Matt
> On Sun, Apr 4, 2010 at 1:52 PM, Shi Jin <jinzishuai at gmail.com> wrote:
>> Hi,
>> I was recently asked to port my code developed a year ago using
>> petsc-dev-sieve.
>> I just checked, the code works without problem on a Linux cluster with
>> gcc-4.3.2 built against petsc-3.1.0.
>> However, I got the following error built on the BlueGene. I used the
>> following steps:
>>    - ./configure —with-clanguage=C++ —with-sieve=1 —with-opt-sieve=1
>>    —download-chaco=1 —download-boost=1 —with-shared=0 —with-debugging=no
>>    —with-mpi-shared=0 —download-f-blas-lapack=1 —with-batch
>>    - cqsub -q debug -n 2 -t 00:10:00 conftest. Make sure the job is
>>    finished by "cqstat".
>>    - ./reconfigure.py
>> It works fine. The output is
>> Compilers:
>>   C Compiler:         mpicc  -Wall -Wwrite-strings -Wno-strict-aliasing -O
>>   C++ Compiler:       mpicxx  -Wall -Wwrite-strings -Wno-strict-aliasing -O
>>   Fortran Compiler:   mpif77  -Wall -Wno-unused-variable -O
>> Linkers:
>>   Static linker:   /usr/bin/ar cr
>> MPI:
>>   Includes: -I/bgl/BlueLight/V1R3M4_300_2008-080728/ppc/bglsys/include
>> BLAS/LAPACK: -Wl,-rpath,/home/guntaka/src/petsc-3.1-p0/linux-gnu-cxx-opt/lib -L/home/guntaka/src/petsc-3.1-p0/linux-gnu-cxx-opt/lib -lflapack -Wl,-rpath,/home/guntaka/src/petsc-3.1-p0/linux-gnu-cxx-opt/lib -L/home/guntaka/src/petsc-3.1-p0/linux-gnu-cxx-opt/lib -lfblas
>> Chaco:
>>   Library:  -Wl,-rpath,/home/guntaka/src/petsc-3.1-p0/linux-gnu-cxx-opt/lib -L/home/guntaka/src/petsc-3.1-p0/linux-gnu-cxx-opt/lib -lchaco
>> Sieve:
>>   Includes: -I/home/guntaka/src/petsc-3.1-p0/include/sieve
>> Boost:
>>   Includes: -I/home/guntaka/src/petsc-3.1-p0/externalpackages/Boost/ -I/bgl/BlueLight/V1R3M4_300_2008-080728/ppc/bglsys/include
>> PETSc:
>>   PETSC_ARCH: linux-gnu-cxx-opt
>>   PETSC_DIR: /home/guntaka/src/petsc-3.1-p0
>>   Clanguage: Cxx
>>   Scalar type: real
>>   Precision: double
>>   shared libraries: disabled
>>   dynamic libraries: disabled
>>   Memory alignment: 16
>> xxx=========================================================================xxx
>>    Configure stage complete. Now build PETSc libraries with:
>>    make PETSC_DIR=/home/guntaka/src/petsc-3.1-p0 PETSC_ARCH=linux-gnu-cxx-opt all
>> Then I moved ahead to build it
>> But I got the following error in compiling sieve:
>> /home/guntaka/src/petsc-3.1-p0/include/sieve/ALE_args.hh: In member function `ALE::ArgValue ALE::ArgDB::operator[](const string&) const':
>> /home/guntaka/src/petsc-3.1-p0/include/sieve/ALE_args.hh:132: error: call of overloaded `ArgValue(ALE::ArgValue)' is ambiguous
>> /home/guntaka/src/petsc-3.1-p0/include/sieve/ALE_args.hh:64: note: candidates are: ALE::ArgValue::ArgValue(const ALE::ArgValue&)
>> /home/guntaka/src/petsc-3.1-p0/include/sieve/ALE_args.hh:67: note:                 ALE::ArgValue::ArgValue(const boost::program_options::variable_value&)
>> I am using the mpicxx which is using g++ 3.4.3:
>> guntaka at fr0103en:~/src/petsc-3.1-p0> mpicxx -show
>> /bgl/BlueLight/V1R3M4_300_2008-080728/ppc/blrts-gnu/bin/powerpc-bgl-blrts-gnu-g++ -I/bgl/BlueLight/V1R3M4_300_2008-080728/ppc/bglsys/include -L/bgl/BlueLight/V1R3M4_300_2008-080728/ppc/bglsys/lib -lcxxmpich.rts -lmpich.rts -L/bgl/BlueLight/V1R3M4_300_2008-080728/ppc/bglsys/lib -lmsglayer.rts -ldevices.rts -lrts.rts -ldevices.rts -lrts.rts
>> guntaka at fr0103en:~/src/petsc-3.1-p0> /bgl/BlueLight/V1R3M4_300_2008-080728/ppc/blrts-gnu/bin/powerpc-bgl-blrts-gnu-g++ --version
>> I remember there was some issues with older versions of GCC. Not sure this is the same problem.
>> Has anyone have any experience on this?
>> Thank you very much.
>> Shi
>> powerpc-bgl-blrts-gnu-g++ (GCC) 3.4.3
>> /home/guntaka/src/petsc-3.1-p0/include/sieve/ALE_args.hh:132: error:   initializing temporary from result of `ALE::ArgValue::ArgValue(const boost::program_options::variable_value&)'
>> Shi Jin, Ph.D.
> experiments lead.
> -- Norbert Wiener
Shi Jin, Ph.D.
URL: <http://lists.mcs.anl.gov/pipermail/sieve-dev/attachments/20100404/3568dea4/attachment-0001.htm>
More information about the sieve-dev mailing list
