sieve-dev building petsc-dev on IBM AIX
Shi Jin jinzishuai at gmail.com
Sat Jun 28 19:04:56 CDT 2008
I've noticed that changes are made to the latest petsc-dev source so that
the compilation has a quote like
mpCC_r -q64 -o mesh.o -c -qrtti=dyna -O -+ -Isieve
-I/scratch_ibm/seki/software/src/petsc-dev/externalpackages/Boost/
-I/home/seki/software/src/petsc-dev
-I/home/seki/software/src/petsc-dev/aix5.3.0.0-cxx-opt/include
-I/home/seki/software/src/petsc-dev/include
-I/scratch_ibm/seki/software/src/petsc-dev/src/dm/mesh/sieve
-I/usr/lpp/ppe.poe/include
-I/scratch_ibm/seki/software/src/petsc-dev/externalpackages/Boost/*-D__SDIR__="src/dm/mesh/"
* mesh.c
However, this is still not correct since one pair of single quotes are
missing. It should be * -D__SDIR__='"src/dm/mesh/"'* . Could you please look
into this furthermore to correct the AIX behavior?
Even this is corrected as above, I still get three error messages (produced
with the -w option to suppress warnings):
"sieve/Mesh.hh", line 1181.30: 1540-1110 (S) The referenced type
"ALE::IBundle" contains a circular reference back to "".
"mesh.c", line 1622.39: 1540-0130 (S)
"ALE::Generator<ALE::IMesh>::refineMeshV" is not declared.
"mesh.c", line 1643.39: 1540-0130 (S)
I would appreciate it if you could take a look at this problem after solving
the first.
Thank you very much.
Shi
On Wed, Jun 18, 2008 at 3:48 PM, Shi Jin <jinzishuai at gmail.com> wrote:
> I did the test on src/dm/mesh/
> On my linux system, the mesh.c is built by (got it by running make mesh.o)
> g++ -o newmesh.c -E -Wall -Wwrite-strings -Wno-strict-aliasing -g
> -Isieve -I/mnt/UofA/sekidata/petsc-dev/externalpackages/Boost/
> -I/home/seki/UofA/petsc-dev/linux-gnu-cxx-debug/include
> -I/home/seki/UofA/petsc-dev/include
> -I/mnt/UofA/sekidata/petsc-dev/src/dm/mesh/sieve -I/usr/local/include
> -I/mnt/UofA/sekidata/petsc-dev/externalpackages/Boost/      *-D__SDIR__='"src/dm/mesh/"'
> *  mesh.c
> This one works fine.
> On the AIX system,, it is done by
> -I/scratch_ibm/seki/software/src/petsc-dev/externalpackages/Boost/ *
> -D__SDIR__=src/dm/mesh/* mesh.c
> It gives lots of (S) error messages
> After putting quotes to the *-D__SDIR__='"src/dm/mesh/"'*  as in the first
> case, those errors are gone.
> I hope this identifies the problem. I guess modification can be made to
> some global makefile variables so that it is effective everywhere.
> Please let me know if this is helpful.
> Thanks.
> Shi
> On Wed, Jun 18, 2008 at 11:45 AM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> Please send me the compile line ofr this file.
>>  Thanks,
>>     Matt
>> On Wed, Jun 18, 2008 at 12:42 PM, Shi Jin <jinzishuai at gmail.com> wrote:
>> > It looks like the problem is on the macro variable __SDIR__
>> > After preprocessing, it shows up as a string without quotes, such as
>> > src/dm/mesh
>> > I think the solution is to put quotes to it.
>> > Shi
>> > On Wed, Jun 18, 2008 at 11:24 AM, Shi Jin <jinzishuai at gmail.com> wrote:
>> >> Hi,
>> >> After looking at the problem in more details, I realized that the
>> offsetof
>> >> POD problem is not the critical one.
>> >> It is just a warning.
>> >> However, I had several more serious errors, which are all related to
>> >> macros defined in petsc.
>> >> I have found out that CHKERRQ, SETERRQ, SETERRQ1 and PetscHeaderCreate
>> are
>> >> all giving  severe error  messages like
>> >> "mesh.c", line 414.10: 1540-0063 (S) The text "," is unexpected.
>> >> "mesh.c", line 466.10: 1540-0063 (S) The text ")" is unexpected.
>> >> I think they are caused by the macros but not sure exactly what the
>> >> problem is and how to fix it.
>> >> Shi
>> >> On Tue, Jun 17, 2008 at 7:43 PM, Matthew Knepley <knepley at gmail.com>
>> >> wrote:
>> >>> On Tue, Jun 17, 2008 at 7:40 PM, Shi Jin <jinzishuai at gmail.com>
>> wrote:
>> >>> > Hi,
>> >>> > I noticed that changes have been made to make petsc-dev compilable
>> on
>> >>> > AIX
>> >>> > systems with the xlc compilers.  Therefore, I re-visited the same
>> issue
>> >>> > again with the latest petsc-dev code on an IBM P5 machine running
>> AIX
>> >>> > 5.3.0.50.
>> >>> > I tried to build petsc-dev with
>> >>> > PETSC_DIR=`pwd` PETSC_ARCH="aix5.3.0.0-cxx-opt" config/configure.py
>> >>> > --with-debugging=no --with-cxx="mpCC_r  -q64" --with-fortran=0
>> >>> > --with-shared=1  --with-clanguage=C++  --with-sieve=1
>> >>> > --download-boost=1
>> >>> > PETSC_DIR=`pwd` PETSC_ARCH="aix5.3.0.0-cxx-opt"  make
>> >>> > The configuration went perfectly, without any complaint.
>> >>> > However, I got lots of messages during the make:
>> >>> > "../../sieve/Sifter.hh", line 560.180: 1540-1281 (W) "offsetof"
>> cannot
>> >>> > be
>> >>> > applied to "struct Arrow<int,int,int>".  It is not a POD (plain old
>> >>> > data)
>> >>> > type.
>> >>> > Other than this problem, the rest seems fine.  I got the same
>> offsetof
>> >>> > POD
>> >>> > problem when compiling my code with the newly built petsc-dev
>> library.
>> >>> > I am
>> >>> > very encouraged by with since last time we saw lots of different
>> error
>> >>> > messages.
>> >>> > So I am wondering what we can do to solve the offsetof POD problem.
>> We
>> >>> > definitely did not see this with g++. . My version is
>> >>> > seki at cortex conf $ mpCC_r -qversion
>> >>> > IBM XL C/C++ Enterprise Edition V8.0 for AIX
>> >>> > Version: 08.00.0000.0013
>> >>> I saw this as well. I tried to google the error message, but found
>> >>> nothing to help.
>> >>> Evidently Boost and MySQL also get this warning but it things still
>> run.
>> >>>  Matt
>> >>> > Shi Jin
>> >>> > On Tue, Feb 26, 2008 at 8:45 AM, Matthew Knepley <knepley at gmail.com
>> >>> > wrote:
>> >>> >> I have been trying to make sense of these compile errors, but only
>> >>> >> some
>> >>> >> of them are valid I believe. The rest seem to be bugs in the C++
>> >>> >> compiler.
>> >>> >> Are you sure you have the latest version? I suggest putting g++ on
>> >>> >> this
>> >>> >> machine first and building a valid copy. Then we can address the
>> >>> >> native
>> >>> >> compiler issues.
>> >>> >>  Thanks,
>> >>> >>     Matt
>> >>> What most experimenters take for granted before they begin their
>> >>> experiments is infinitely more interesting than any results to which
>> >>> their experiments lead.
>> >>> -- Norbert Wiener
>> >> Sincerely,
>> >> Shi Jin, Ph.D.
>> >> http://www.ualberta.ca/~sjin1/ <http://www.ualberta.ca/%7Esjin1/>
>> > Sincerely,
>> > Shi Jin, Ph.D.
>> -- Norbert Wiener
> Sincerely,
> Shi Jin, Ph.D.
Sincerely,
Shi Jin, Ph.D.
URL: <https://lists.mcs.anl.gov/mailman/private/sieve-dev/attachments/20080628/e9678199/attachment.htm>
More information about the sieve-dev mailing list
