sieve-dev building petsc-dev on IBM AIX
Wed Jun 18 16:50:39 CDT 2008
On Wed, Jun 18, 2008 at 4:48 PM, Shi Jin <jinzishuai at gmail.com> wrote:
> I did the test on src/dm/mesh/
> On my linux system, the mesh.c is built by (got it by running make mesh.o)
> g++ -o newmesh.c -E -Wall -Wwrite-strings -Wno-strict-aliasing -g    -Isieve
> -I/mnt/UofA/sekidata/petsc-dev/externalpackages/Boost/
> -I/home/seki/UofA/petsc-dev/linux-gnu-cxx-debug/include
> -I/home/seki/UofA/petsc-dev/include
> -I/mnt/UofA/sekidata/petsc-dev/src/dm/mesh/sieve -I/usr/local/include
> -D__SDIR__='"src/dm/mesh/"'  mesh.c
> This one works fine.
> On the AIX system,, it is done by
> mpCC_r -q64 -o mesh.o -c -qrtti=dyna -O -+ -Isieve
> -I/scratch_ibm/seki/software/src/petsc-dev/externalpackages/Boost/
> -I/home/seki/software/src/petsc-dev
> -I/home/seki/software/src/petsc-dev/aix5.3.0.0-cxx-opt/include
> -I/home/seki/software/src/petsc-dev/include
> -I/scratch_ibm/seki/software/src/petsc-dev/src/dm/mesh/sieve
> -I/usr/lpp/ppe.poe/include
> -D__SDIR__=src/dm/mesh/ mesh.c
> It gives lots of (S) error messages
> After putting quotes to the -D__SDIR__='"src/dm/mesh/"'  as in the first
> case, those errors are gone.
This is very strange. It seems like either the 'make' or the shell for
AIX is stripping
both sets of quotes off of the string before executing the command line. We can
look into this.
     Matt
> I hope this identifies the problem. I guess modification can be made to some
> global makefile variables so that it is effective everywhere.
> Please let me know if this is helpful.
> Thanks.
> Shi
> On Wed, Jun 18, 2008 at 11:45 AM, Matthew Knepley <knepley at gmail.com> wrote:
>> Please send me the compile line ofr this file.
>>  Thanks,
>>     Matt
>> On Wed, Jun 18, 2008 at 12:42 PM, Shi Jin <jinzishuai at gmail.com> wrote:
>> > It looks like the problem is on the macro variable __SDIR__
>> > After preprocessing, it shows up as a string without quotes, such as
>> > src/dm/mesh
>> > I think the solution is to put quotes to it.
>> > Shi
>> > On Wed, Jun 18, 2008 at 11:24 AM, Shi Jin <jinzishuai at gmail.com> wrote:
>> >> Hi,
>> >> After looking at the problem in more details, I realized that the
>> >> offsetof
>> >> POD problem is not the critical one.
>> >> It is just a warning.
>> >> However, I had several more serious errors, which are all related to
>> >> macros defined in petsc.
>> >> I have found out that CHKERRQ, SETERRQ, SETERRQ1 and PetscHeaderCreate
>> >> are
>> >> all giving  severe error  messages like
>> >> "mesh.c", line 414.10: 1540-0063 (S) The text "," is unexpected.
>> >> "mesh.c", line 466.10: 1540-0063 (S) The text ")" is unexpected.
>> >> I think they are caused by the macros but not sure exactly what the
>> >> problem is and how to fix it.
>> >> Shi
>> >> On Tue, Jun 17, 2008 at 7:43 PM, Matthew Knepley <knepley at gmail.com>
>> >> wrote:
>> >>> On Tue, Jun 17, 2008 at 7:40 PM, Shi Jin <jinzishuai at gmail.com> wrote:
>> >>> > Hi,
>> >>> > I noticed that changes have been made to make petsc-dev compilable
>> >>> > on
>> >>> > AIX
>> >>> > systems with the xlc compilers.  Therefore, I re-visited the same
>> >>> > issue
>> >>> > again with the latest petsc-dev code on an IBM P5 machine running
>> >>> > AIX
>> >>> > 5.3.0.50.
>> >>> > I tried to build petsc-dev with
>> >>> > PETSC_DIR=`pwd` PETSC_ARCH="aix5.3.0.0-cxx-opt" config/configure.py
>> >>> > --with-debugging=no --with-cxx="mpCC_r  -q64" --with-fortran=0
>> >>> > --with-shared=1  --with-clanguage=C++  --with-sieve=1
>> >>> > --download-boost=1
>> >>> > PETSC_DIR=`pwd` PETSC_ARCH="aix5.3.0.0-cxx-opt"  make
>> >>> > The configuration went perfectly, without any complaint.
>> >>> > However, I got lots of messages during the make:
>> >>> > "../../sieve/Sifter.hh", line 560.180: 1540-1281 (W) "offsetof"
>> >>> > cannot
>> >>> > be
>> >>> > applied to "struct Arrow<int,int,int>".  It is not a POD (plain old
>> >>> > data)
>> >>> > type.
>> >>> > Other than this problem, the rest seems fine.  I got the same
>> >>> > offsetof
>> >>> > POD
>> >>> > problem when compiling my code with the newly built petsc-dev
>> >>> > library.
>> >>> > I am
>> >>> > very encouraged by with since last time we saw lots of different
>> >>> > error
>> >>> > messages.
>> >>> > So I am wondering what we can do to solve the offsetof POD problem.
>> >>> > We
>> >>> > definitely did not see this with g++. . My version is
>> >>> > seki at cortex conf $ mpCC_r -qversion
>> >>> > IBM XL C/C++ Enterprise Edition V8.0 for AIX
>> >>> > Version: 08.00.0000.0013
>> >>> I saw this as well. I tried to google the error message, but found
>> >>> nothing to help.
>> >>> Evidently Boost and MySQL also get this warning but it things still
>> >>> run.
>> >>>  Matt
>> >>> > Thank you very much.
>> >>> > Shi Jin
>> >>> > On Tue, Feb 26, 2008 at 8:45 AM, Matthew Knepley <knepley at gmail.com>
>> >>> > wrote:
>> >>> >> I have been trying to make sense of these compile errors, but only
>> >>> >> some
>> >>> >> of them are valid I believe. The rest seem to be bugs in the C++
>> >>> >> compiler.
>> >>> >> Are you sure you have the latest version? I suggest putting g++ on
>> >>> >> this
>> >>> >> machine first and building a valid copy. Then we can address the
>> >>> >> native
>> >>> >> compiler issues.
>> >>> >>  Thanks,
>> >>> >>     Matt
>> >>> What most experimenters take for granted before they begin their
>> >>> experiments is infinitely more interesting than any results to which
>> >>> their experiments lead.
>> >>> -- Norbert Wiener
>> >> Sincerely,
>> >> Shi Jin, Ph.D.
>> >> http://www.ualberta.ca/~sjin1/
>> > Sincerely,
>> > Shi Jin, Ph.D.
>> -- Norbert Wiener
> Sincerely,
> Shi Jin, Ph.D.
-- Norbert Wiener
More information about the sieve-dev mailing list
