sieve-dev opt-sieve and parallel partitioner
Shi Jin jinzishuai at gmail.com
Thu Jul 24 11:18:47 CDT 2008
HI there,
I have another question with regard to the partitioning of meshes. In the
old version, we were able to call Chaco or Parmetis as the partitioner. I
can even modify the source at sieve/Partitioner.hh to have my own
partitionSieve() function.  However in the opt-sieve code, although I am
calling the same
ierr = MeshDistribute(mesh, "chaco", &parallelMesh);
the source show that the partitioner does not play any role.
Is there any way I can use to instruct the new code how to partition the
mesh? Actually I don't really need Chaco or Parmetis.  All I need is a way
to specify which process does a cell belong to. In the Chaco case, I can
supply an array of size numCells with its entries the integer rank of the
process each cell belongs to.
Thank you very much.
Shi
Sincerely,
Shi Jin, Ph.D.
http://www.ualberta.ca/~sjin1/
URL: <https://lists.mcs.anl.gov/mailman/private/sieve-dev/attachments/20080724/9039cd66/attachment.htm>
More information about the sieve-dev mailing list
