[petsc-users] Advice on creating vectors defined on lower dimensional manifolds of a DMPlex
Aldo Bonfiglioli
aldo.bonfiglioli at unibas.it
Tue Oct 7 08:24:06 CDT 2025
On 10/6/25 20:10, Matthew Knepley wrote:
> On Mon, Oct 6, 2025 at 1:11 PM Aldo Bonfiglioli
> <aldo.bonfiglioli at unibas.it> wrote:
> Dear all,
> what is the best approach for defining vectors that "sit" on the
> (vertices and/or faces) of a given stratum of the "Face Sets" of a
> DMPlex?
>> DM Object: 3D plex 1 MPI process
>> type: plex
>> 3D plex in 3 dimensions:
>> Number of 0-cells per rank: 9261
>> Number of 1-cells per rank: 59660
>> Number of 2-cells per rank: 98400
>> Number of 3-cells per rank: 48000
>> Labels:
>> marker: 1 strata with value/size (1 (14402))
>> celltype: 4 strata with value/size (0 (9261), 1 (59660), 3
>> (98400), 6 (48000))
>> depth: 4 strata with value/size (0 (9261), 1 (59660), 2 (98400),
>> 3 (48000))
>> Face Sets: 6 strata with value/size (1 (800), 2 (800), 3 (800),
>> 4 (800), 5 (800), 6 (800))
> These vectors are going to be used (for example) to store stresses
> and heat flux on solid surfaces.
> To be more specific: suppose stratum 3 of the "Face Sets" is a
> solid wall.
> I want to create a vector that that stores quantities computed on
> the (800) faces of that wall OR the vertices of that wall.
> It should be simple to just create such vectors. You request a submesh
> using that label
> DM subdm;
> DMLabel label, sublabel;
> DMGetLabel(dm, "Face Sets", &label);
> DMLabelDuplicate(label, &sublabel);
> DMPlexLabelComplete(dm, sublabel);
> DMPlexCreateSubmesh(dm, sublabel, 3, PETSC_TRUE, &subdm)
> DMLabelDestroy(&sublabel);
> Now you can define a PetscFE over this submesh in the same way as any
> other mesh. Moreover, the subdm contains a mapping back to the
> original DM, from which you can create a mapping of dofs, so that you
> can inject the subvector into a larger field if you wish.
> If you want to use fields on submeshes inside a PetscDS, so that the
> Plex manages the solve, the procedure is slightly different, but I can
> detail it if you want.
> Thanks,
> Matt
> Thanks,
> Aldo
> Dr. Aldo Bonfiglioli
> Associate professor of Fluid Mechanics
> Dipartimento di Ingegneria
> Universita' della Basilicata
> V.le dell'Ateneo Lucano, 10 85100 Potenza ITALY
> tel:+39.0971.205203 fax:+39.0971.205215
> web:https://urldefense.us/v3/__http://docenti.unibas.it/site/home/docente.html?m=002423__;!!G_uCfscf7eWS!Yk-uGKnWGfd4b87jjp07cII-ta6Rld0p_kmImii1ZuYnG2DCFwjpUQkeQ8z3mrWOHPd6-oKoBkZsW8rkoKSWFblHNxPyamZ0CHI$ <https://urldefense.us/v3/__http://docenti.unibas.it/site/home/docente.html?m=002423__;!!G_uCfscf7eWS!dx5g28NqJW34oxLLKP1Fjtp65c0KkvUjelPzjza0lBJtf6uu5ROFqpa2GTX5Cle8L7S_YjHssSDqe6szXd2PEYvYVHHq5mtW8EU$>
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!Yk-uGKnWGfd4b87jjp07cII-ta6Rld0p_kmImii1ZuYnG2DCFwjpUQkeQ8z3mrWOHPd6-oKoBkZsW8rkoKSWFblHNxPykk2-vZU$
> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!Yk-uGKnWGfd4b87jjp07cII-ta6Rld0p_kmImii1ZuYnG2DCFwjpUQkeQ8z3mrWOHPd6-oKoBkZsW8rkoKSWFblHNxPy-jdNsBo$ >
Matthew,
I followed your suggestions, but I face a deadlock when the enclosed
demonstrator is run in parallel (for the attached dotfile, deadlock
occurs when nproc = 3).
I suspect it might be due to the fact that in a parallel environment the
various strata of the "Face Sets" are not necessarily available to all
processes.
Therefore, not all processes are going to call DMPlexCreateSubmesh with
a given "value".
The attached piece of code links with petsc-3.24.0.
Aldo
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20251007/43ed4f50/attachment.html>
Type: text/x-fortran
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20251007/43ed4f50/attachment.bin>
-dm_plex_dim 3
-dm_plex_shape box
-dm_plex_box_faces 20,20,20
-dm_plex_box_lower 0.,0.,0.
-dm_plex_box_upper 1.,1.,1.
##-dm_plex_filename cube6.msh
-dm_plex_simplex true
-dm_plex_interpolate
-dm_plex_check_all
#-dm_view
##-dm_plex_view_labels "marker"
##-dm_plex_view_labels "Face Sets"
-petscpartitioner_view
####-dm_petscsection_view
-options_left
