[petsc-users] Advice on creating vectors defined on lower dimensional manifolds of a DMPlex
Matthew Knepley
knepley at gmail.com
Tue Oct 7 09:23:51 CDT 2025
On Tue, Oct 7, 2025 at 9:24 AM Aldo Bonfiglioli <aldo.bonfiglioli at unibas.it>
wrote:
> On 10/6/25 20:10, Matthew Knepley wrote:
> On Mon, Oct 6, 2025 at 1:11 PM Aldo Bonfiglioli <
> aldo.bonfiglioli at unibas.it> wrote:
>> Dear all,
>> what is the best approach for defining vectors that "sit" on the
>> (vertices and/or faces) of a given stratum of the "Face Sets" of a DMPlex?
>> DM Object: 3D plex 1 MPI process
>> type: plex
>> 3D plex in 3 dimensions:
>> Number of 0-cells per rank: 9261
>> Number of 1-cells per rank: 59660
>> Number of 2-cells per rank: 98400
>> Number of 3-cells per rank: 48000
>> Labels:
>> marker: 1 strata with value/size (1 (14402))
>> celltype: 4 strata with value/size (0 (9261), 1 (59660), 3 (98400), 6
>> (48000))
>> depth: 4 strata with value/size (0 (9261), 1 (59660), 2 (98400), 3
>> (48000))
>> Face Sets: 6 strata with value/size (1 (800), 2 (800), 3 (800), 4 (800),
>> 5 (800), 6 (800))
>> These vectors are going to be used (for example) to store stresses and
>> heat flux on solid surfaces.
>> To be more specific: suppose stratum 3 of the "Face Sets" is a solid
>> wall.
>> I want to create a vector that that stores quantities computed on the
>> (800) faces of that wall OR the vertices of that wall.
> It should be simple to just create such vectors. You request a submesh
> using that label
> DM subdm;
> DMLabel label, sublabel;
> DMGetLabel(dm, "Face Sets", &label);
> DMLabelDuplicate(label, &sublabel);
> DMPlexLabelComplete(dm, sublabel);
> DMPlexCreateSubmesh(dm, sublabel, 3, PETSC_TRUE, &subdm)
> DMLabelDestroy(&sublabel);
> Now you can define a PetscFE over this submesh in the same way as any
> other mesh. Moreover, the subdm contains a mapping back to the original DM,
> from which you can create a mapping of dofs, so that you can inject the
> subvector into a larger field if you wish.
> If you want to use fields on submeshes inside a PetscDS, so that the Plex
> manages the solve, the procedure is slightly different, but I can detail it
> if you want.
> Thanks,
> Matt
>> Thanks,
>> Aldo
>> Dr. Aldo Bonfiglioli
>> Associate professor of Fluid Mechanics
>> Dipartimento di Ingegneria
>> Universita' della Basilicata
>> V.le dell'Ateneo Lucano, 10 85100 Potenza ITALY
>> tel:+39.0971.205203 fax:+39.0971.205215
>> web: https://urldefense.us/v3/__http://docenti.unibas.it/site/home/docente.html?m=002423__;!!G_uCfscf7eWS!dqmn8J_g7VGPOtEwYJpwJ4cJ8KKVW3j_qflz1ied-mBFEqfnmodJ-OkWqbHntOdvfcELJcGln4S5B_zmPsvc$ <https://urldefense.us/v3/__http://docenti.unibas.it/site/home/docente.html?m=002423__;!!G_uCfscf7eWS!dx5g28NqJW34oxLLKP1Fjtp65c0KkvUjelPzjza0lBJtf6uu5ROFqpa2GTX5Cle8L7S_YjHssSDqe6szXd2PEYvYVHHq5mtW8EU$>
> experiments lead.
> -- Norbert Wiener
> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!dqmn8J_g7VGPOtEwYJpwJ4cJ8KKVW3j_qflz1ied-mBFEqfnmodJ-OkWqbHntOdvfcELJcGln4S5B9LrRWeW$
> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!dqmn8J_g7VGPOtEwYJpwJ4cJ8KKVW3j_qflz1ied-mBFEqfnmodJ-OkWqbHntOdvfcELJcGln4S5BxdpUbae$ >
> Matthew,
> I followed your suggestions, but I face a deadlock when the enclosed
> demonstrator is run in parallel (for the attached dotfile, deadlock occurs
> when nproc = 3).
> I suspect it might be due to the fact that in a parallel environment the
> various strata of the "Face Sets" are not necessarily available to all
> processes.
> Therefore, not all processes are going to call DMPlexCreateSubmesh with a
> given "value".
> DMPlexCreateSubmesh() is collective. You have to call it with identical
arguments, even if the result is empty on some process.
Matt
> The attached piece of code links with petsc-3.24.0.
> Thanks,
> Aldo
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!dqmn8J_g7VGPOtEwYJpwJ4cJ8KKVW3j_qflz1ied-mBFEqfnmodJ-OkWqbHntOdvfcELJcGln4S5B9LrRWeW$ <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!dqmn8J_g7VGPOtEwYJpwJ4cJ8KKVW3j_qflz1ied-mBFEqfnmodJ-OkWqbHntOdvfcELJcGln4S5BxdpUbae$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20251007/7a144797/attachment-0001.html>
