[petsc-users] Advice on creating vectors defined on lower dimensional manifolds of a DMPlex
Mon Oct 6 13:10:00 CDT 2025
On Mon, Oct 6, 2025 at 1:11 PM Aldo Bonfiglioli <aldo.bonfiglioli at unibas.it>
wrote:
> Dear all,
> what is the best approach for defining vectors that "sit" on the (vertices
> and/or faces) of a given stratum of the "Face Sets" of a DMPlex?
> DM Object: 3D plex 1 MPI process
>  type: plex
> 3D plex in 3 dimensions:
>  Number of 0-cells per rank: 9261
>  Number of 1-cells per rank: 59660
>  Number of 2-cells per rank: 98400
>  Number of 3-cells per rank: 48000
> Labels:
>  marker: 1 strata with value/size (1 (14402))
>  celltype: 4 strata with value/size (0 (9261), 1 (59660), 3 (98400), 6
> (48000))
>  depth: 4 strata with value/size (0 (9261), 1 (59660), 2 (98400), 3
> (48000))
>  Face Sets: 6 strata with value/size (1 (800), 2 (800), 3 (800), 4 (800),
> 5 (800), 6 (800))
> These vectors are going to be used (for example) to store stresses and
> heat flux on solid surfaces.
> To be more specific: suppose stratum 3 of the "Face Sets" is a solid wall.
> I want to create a vector that that stores quantities computed on the
> (800) faces of that wall OR the vertices of that wall.
It should be simple to just create such vectors. You request a submesh
using that label
  DM subdm;
  DMLabel label, sublabel;
  DMGetLabel(dm, "Face Sets", &label);
  DMLabelDuplicate(label, &sublabel);
  DMPlexLabelComplete(dm, sublabel);
  DMPlexCreateSubmesh(dm, sublabel, 3, PETSC_TRUE, &subdm)
  DMLabelDestroy(&sublabel);
Now you can define a PetscFE over this submesh in the same way as any other
mesh. Moreover, the subdm contains a mapping back to the original DM, from
which you can create a mapping of dofs, so that you can inject the
subvector into a larger field if you wish.
If you want to use fields on submeshes inside a PetscDS, so that the Plex
manages the solve, the procedure is slightly different, but I can detail it
if you want.
     Matt
> Thanks,
> Aldo
> Dr. Aldo Bonfiglioli
> Associate professor of Fluid Mechanics
> Dipartimento di Ingegneria
> Universita' della Basilicata
> V.le dell'Ateneo Lucano, 10 85100 Potenza ITALY
> tel:+39.0971.205203 fax:+39.0971.205215
> web: https://urldefense.us/v3/__http://docenti.unibas.it/site/home/docente.html?m=002423__;!!G_uCfscf7eWS!agxuKTesyLfH3uplL5jGjn6KTo6lQTqlAtD7aN9x4Nao7Q1B1yi933LeiaBDdRvOl-Eusg-tJFIjzfmXLiuH$  <https://urldefense.us/v3/__http://docenti.unibas.it/site/home/docente.html?m=002423__;!!G_uCfscf7eWS!dx5g28NqJW34oxLLKP1Fjtp65c0KkvUjelPzjza0lBJtf6uu5ROFqpa2GTX5Cle8L7S_YjHssSDqe6szXd2PEYvYVHHq5mtW8EU$>
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!agxuKTesyLfH3uplL5jGjn6KTo6lQTqlAtD7aN9x4Nao7Q1B1yi933LeiaBDdRvOl-Eusg-tJFIjzVxLgYfM$  <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!agxuKTesyLfH3uplL5jGjn6KTo6lQTqlAtD7aN9x4Nao7Q1B1yi933LeiaBDdRvOl-Eusg-tJFIjzd0H4x8r$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20251006/46c7f3f6/attachment.html>
