[petsc-users] Out of memory for using DMPlexCreateFromFile when load large-scale mesh
    Matthew Knepley
    knepley at gmail.com
    Wed May 14 06:24:48 CDT 2025
On Wed, May 14, 2025 at 6:19 AM Mark Adams <mfadams at lbl.gov> wrote:
> There are examples listed at the end of the *DMPlexCreateFromFile
> <https://urldefense.us/v3/__https://petsc.org/release/manualpages/DMPlex/DMPlexCreateFromFile/__;!!G_uCfscf7eWS!b8tabJOQMBPGdL853VyP1yu-DrBuHaOQDcvf368RW41TmzhfdTRagLyrwBnZBeZ6OM3g6neOJBuBS2RCNnBwe35XChWNH5S3bg$>,*and
> the first two are designed for parallel file load-store.
> Matt may have a better idea but I would test that you can run these tests
> (there are test arguments in a comment at the end of the source file), to
> get your installation working, and then clone that code.
On the machine on which you created the GMsh file there is definitely
enough memory. Thus I would load it there and save it as HDF5 or NetCDF, so
that you could load it in parallel elsewhere. For HDF5, I would use the
latest formet
  -dm_plex_view_hdf5_storage_version 3.1.0
     Matt
> Mark
> On Tue, May 13, 2025 at 10:40 AM 程奔 <ctchengben at mail.scut.edu.cn> wrote:
>> Hello,
>> Recently I create unstructure mesh from Gmsh and its mesh format is msh
>> file. However the mesh file contain around 100 million nodes, so when I
>> use *DMPlexCreateFromFile
>> <https://urldefense.us/v3/__https://petsc.org/release/manualpages/DMPlex/DMPlexCreateFromFile/__;!!G_uCfscf7eWS!b8tabJOQMBPGdL853VyP1yu-DrBuHaOQDcvf368RW41TmzhfdTRagLyrwBnZBeZ6OM3g6neOJBuBS2RCNnBwe35XChWNH5S3bg$> *
>> it only perform on a single CPU process thus out of memory.
>> I ask GPT and it said PETSc may parallel perform *DMPlexCreateFromFile
>> <https://urldefense.us/v3/__https://petsc.org/release/manualpages/DMPlex/DMPlexCreateFromFile/__;!!G_uCfscf7eWS!b8tabJOQMBPGdL853VyP1yu-DrBuHaOQDcvf368RW41TmzhfdTRagLyrwBnZBeZ6OM3g6neOJBuBS2RCNnBwe35XChWNH5S3bg$> *when
>> the mesh file is HDF5/Exodus II/XDMF, so it will decrease the Memory
>> pressure for each CPU process.
>> So I sent this email for asking help that how can I load such large-scale
>> mesh to create DMPLEX.
>> Looking forward to your reply!
>> sinserely,
>> Cheng.
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!ZZx-2RTs8T5ThExGXILH1XXU3-8Ko9JD4p9a85zHm9D1bn8xxrag2HfMb0zD5jAYQJWiL6CyI62KgWl0TgHb$  <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!ZZx-2RTs8T5ThExGXILH1XXU3-8Ko9JD4p9a85zHm9D1bn8xxrag2HfMb0zD5jAYQJWiL6CyI62KgWPfWduy$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250514/44bae2f9/attachment.html>
