[petsc-users] Out of memory for using DMPlexCreateFromFile when load large-scale mesh
    Mark Adams
    mfadams at lbl.gov
    Wed May 14 05:19:30 CDT 2025
There are examples listed at the end of the *DMPlexCreateFromFile
<https://urldefense.us/v3/__https://petsc.org/release/manualpages/DMPlex/DMPlexCreateFromFile/__;!!G_uCfscf7eWS!b8tabJOQMBPGdL853VyP1yu-DrBuHaOQDcvf368RW41TmzhfdTRagLyrwBnZBeZ6OM3g6neOJBuBS2RCNnBwe35XChWNH5S3bg$>,*and
the first two are designed for parallel file load-store.
Matt may have a better idea but I would test that you can run these tests
(there are test arguments in a comment at the end of the source file), to
get your installation working, and then clone that code.
On Tue, May 13, 2025 at 10:40 AM 程奔 <ctchengben at mail.scut.edu.cn> wrote:
> Hello,
> Recently I create unstructure mesh from Gmsh and its mesh format is msh
> file. However the mesh file contain around 100 million nodes, so when I
> use *DMPlexCreateFromFile
> <https://urldefense.us/v3/__https://petsc.org/release/manualpages/DMPlex/DMPlexCreateFromFile/__;!!G_uCfscf7eWS!b8tabJOQMBPGdL853VyP1yu-DrBuHaOQDcvf368RW41TmzhfdTRagLyrwBnZBeZ6OM3g6neOJBuBS2RCNnBwe35XChWNH5S3bg$> *
> it only perform on a single CPU process thus out of memory.
> I ask GPT and it said PETSc may parallel perform *DMPlexCreateFromFile
> <https://urldefense.us/v3/__https://petsc.org/release/manualpages/DMPlex/DMPlexCreateFromFile/__;!!G_uCfscf7eWS!b8tabJOQMBPGdL853VyP1yu-DrBuHaOQDcvf368RW41TmzhfdTRagLyrwBnZBeZ6OM3g6neOJBuBS2RCNnBwe35XChWNH5S3bg$> *when
> the mesh file is HDF5/Exodus II/XDMF, so it will decrease the Memory
> pressure for each CPU process.
> So I sent this email for asking help that how can I load such large-scale
> mesh to create DMPLEX.
> Looking forward to your reply!
> sinserely,
> Cheng.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250514/2ede19cb/attachment-0001.html>
