[petsc-users] Problems with the null-space removal
Matthew Knepley
knepley at gmail.com
Mon May 5 03:44:05 CDT 2025
On Mon, May 5, 2025 at 3:52 AM MIGUEL MOLINOS PEREZ <mmolinos at us.es> wrote:
> Dear all,
> I am working on the resolution of a non-linear problem via SNES with a
> large null-space (at least 70% of the equations are trivial). In a nutshell
> I have a mesh with active and non-active nodes, and the non-active nodes
> introduces the null-space.
> So far I've dealing with it using NGMRES but I want to use a scheme based
> on NR. However, despite removing the null-space using PETSc's in-build
> functions the linear solver (KSP+PC) diverges at the first iteration.
> However, If I remove the non-active nodes and use the same solver
> (SNES+KSP+PC), which failed before, now I can solve the non-linear system.
> Any clue? I’m missing something?
The most likely thing is that the nullspace is slightly wrong, or the
convergence test is not accounting for the nullspace somehow.
However, since so many equations are inactive, I would consider projecting
the problem. I might either
1) Select a subset of the mesh to phrase the problem on. In you use DMPlex,
you could use DMPlexFilter().
2) Use a constraint to get a subsystem for Newton using SNESVI. The
SNESVIRS will project the linear system onto a subspace without the
constraints.
Matt
> Thanks,
> Miguel
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!bByLEARdv_XsY4xZu0ezoqCT2bh14450x43ffJDakWXMjru0Po-BcPS5TJl_mDXpjWZaJkliCDj07YjYyLjm$ <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!bByLEARdv_XsY4xZu0ezoqCT2bh14450x43ffJDakWXMjru0Po-BcPS5TJl_mDXpjWZaJkliCDj07TT0nwzb$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250505/8b6361c4/attachment.html>
