[petsc-users] Problems with the null-space removal
MIGUEL MOLINOS PEREZ mmolinos at us.es
Mon May 5 13:08:21 CDT 2025
Hi Matt, thank you for your response!
The most likely thing is that the nullspace is slightly wrong, or the convergence test is not accounting for the nullspace somehow.
However, since so many equations are inactive, I would consider projecting the problem. I might either
1) Select a subset of the mesh to phrase the problem on. In you use DMPlex, you could use DMPlexFilter().
I’am using a DMSwarm mesh so I can’t use this function.
2) Use a constraint to get a subsystem for Newton using SNESVI. The SNESVIRS will project the linear system onto a subspace without the constraints.
I assume you meant SNESVINEWTONRSLS (former SNESVI). I’ve been digging on this approach. However,I don’t think this fits my problem since I can not define the list of active nodes using upper and lower limits like in:
<https://urldefense.us/v3/__https://petsc.org/release/src/snes/tutorials/ex9.c.html__;!!G_uCfscf7eWS!cj7qNAh93kq-C0vTUW85LoKCBqZJa3dpHaCBjrEo7kqQlyaWw5U6ek5pEUU9RQxE1WercDZ97FMnOdUitk4NiA$ >
petsc.org<https://urldefense.us/v3/__https://petsc.org/release/src/snes/tutorials/ex9.c.html__;!!G_uCfscf7eWS!cj7qNAh93kq-C0vTUW85LoKCBqZJa3dpHaCBjrEo7kqQlyaWw5U6ek5pEUU9RQxE1WercDZ97FMnOdUitk4NiA$ >
[X]<https://urldefense.us/v3/__https://petsc.org/release/src/snes/tutorials/ex9.c.html__;!!G_uCfscf7eWS!cj7qNAh93kq-C0vTUW85LoKCBqZJa3dpHaCBjrEo7kqQlyaWw5U6ek5pEUU9RQxE1WercDZ97FMnOdUitk4NiA$ >
Miguel
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250505/4c1c1ca1/attachment.html>
