[petsc-users] MatView for parallel jobs
Arun Soman Pillai - STFC UKRI Arun.Soman-Pillai at stfc.ac.uk
Thu Jul 10 03:35:29 CDT 2025
I am trying to view a matrix object when running a job in parallel. The application is BOUT++ (https://urldefense.us/v3/__https://boutproject.github.io/__;!!G_uCfscf7eWS!Z-f_HrmUaFAwAK4e2pBspL2oRFtfq9O3GtRCoS_Nb1e9y5j2Vjq6THJTnoot7XiMeRAxlNhskW0QrMV7x_v_VsBXVAsGHRrIifxc$ ) which uses petsc as solver.
While the option -mat_view gives a jumbled output on STDOUT from across the processors, redirecting output to a specific file results in race condition. The only option that works for me is -mat_view binary with -viewer_binary_filename <name>. I am processing this binary file with petsc4py as follows:
from petsc4py import PETSc
import numpy as np
import matplotlib.pyplot as plt
import glob
def read_binary(filename):
    viewer = PETSc.Viewer().createMPIIO(filename, "r", comm=PETSc.COMM_WORLD)
    A = PETSc.Mat().load(viewer)
    A.assemble()
    print("Matrix type:", A.getType())
    print("Matrix size:", A.getSize())
    info = A.getInfo()
    print("Number of nonzeros:", info['nz_used'])
    print("Nonzeros allocated:", info['nz_allocated'])
    m, n = A.getSize()
    dense_mat = np.zeros((m, n), dtype=np.float64)
    for i in range(m):
        cols, vals = A.getRow(i)
        dense_mat[i, cols] = vals
    rstart, rend = A.getOwnershipRange()
    rows, cols = [], []
    for i in range(rstart, rend):
        cols_i, _ = A.getRow(i)
        rows.extend([i] * len(cols_i))
        cols.extend(cols_i)
    rows = np.array(rows)
    cols = np.array(cols)
    return dense_mat, rows, cols
A, rows, cols  = read_binary(“matrix”)
This yields accurate number of non-zeros and matrix sparsity. However, the dense matrix turns out to be a null matrix. I wonder what is going wrong here.
Thank you, best regards
Arun Pillai
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250710/d4b11556/attachment.html>
