[petsc-users] MatView for parallel jobs
Matthew Knepley
knepley at gmail.com
Thu Jul 10 10:34:30 CDT 2025
On Thu, Jul 10, 2025 at 11:29 AM Arun Soman Pillai - STFC UKRI via
petsc-users <petsc-users at mcs.anl.gov> wrote:
> Hi,
> I am trying to view a matrix object when running a job in parallel. The
> application is BOUT++ (https://urldefense.us/v3/__https://boutproject.github.io/__;!!G_uCfscf7eWS!ZLeEFXZF4ASJ2hjoTAuK-DQjJkNz_wPtN8mH3P557R1p2cltUNodOb0wrXsWAcQlamre0C1SJy4cn2cXZDeX$
> <https://urldefense.us/v3/__https://boutproject.github.io/__;!!G_uCfscf7eWS!Z-f_HrmUaFAwAK4e2pBspL2oRFtfq9O3GtRCoS_Nb1e9y5j2Vjq6THJTnoot7XiMeRAxlNhskW0QrMV7x_v_VsBXVAsGHRrIifxc$>)
> which uses petsc as solver.
> While the option -mat_view gives a jumbled output on STDOUT from across
> the processors,
This means that something is terribly wrong. I suspect that you are not
actually running in parallel, but rather launching independent jobs. That
can happen when mpiexec does not match the MPI library that you linked with.
Matt
> redirecting output to a specific file results in race condition. The only
> option that works for me is *-mat_view binary* with *-viewer_binary_filename
> <name>**. *I am processing this binary file with petsc4py as follows:
> from petsc4py import PETSc
> import numpy as np
> import matplotlib.pyplot as plt
> import glob
> def read_binary(filename):
> viewer = PETSc.Viewer().createMPIIO(filename, "r",
> comm=PETSc.COMM_WORLD)
> A = PETSc.Mat().load(viewer)
> A.assemble()
> print("Matrix type:", A.getType())
> print("Matrix size:", A.getSize())
> info = A.getInfo()
> print("Number of nonzeros:", info['nz_used'])
> print("Nonzeros allocated:", info['nz_allocated'])
> m, n = A.getSize()
> dense_mat = np.zeros((m, n), dtype=np.float64)
> for i in range(m):
> cols, vals = A.getRow(i)
> dense_mat[i, cols] = vals
> rstart, rend = A.getOwnershipRange()
> rows, cols = [], []
> for i in range(rstart, rend):
> cols_i, _ = A.getRow(i)
> rows.extend([i] * len(cols_i))
> cols.extend(cols_i)
> rows = np.array(rows)
> cols = np.array(cols)
> return dense_mat, rows, cols
> A, rows, cols = read_binary(“matrix”)
> This yields accurate number of non-zeros and matrix sparsity. However, the
> dense matrix turns out to be a null matrix. I wonder what is going wrong
> here.
> Thank you, best regards
> Arun Pillai
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!ZLeEFXZF4ASJ2hjoTAuK-DQjJkNz_wPtN8mH3P557R1p2cltUNodOb0wrXsWAcQlamre0C1SJy4cn2k7zbgZ$ <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!ZLeEFXZF4ASJ2hjoTAuK-DQjJkNz_wPtN8mH3P557R1p2cltUNodOb0wrXsWAcQlamre0C1SJy4cn5XgDHit$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250710/0115c6f5/attachment-0001.html>
