[petsc-users] About PetscFD
mengjie liang 13390589636 at 163.com
Tue Jul 8 12:29:25 CDT 2025
Dear Petsc,
Big fan here, you are amazing.
I want to test a finite difference method with parallel multigrid. I have done it using DMDA and now I need to do it with local mesh (non-conforming) refinement. I notice that the unreleased PetscFD is all I need. I did find Dr. Abhishek's thesis, which provides the unreleased PetscFD code. I also go through professor Dave Salac's  talk in the annual meeting.
I know that there is no PetscFD code implementing local mesh refinement in the fd/tests directory. I tried to adapt the mesh in ex2 and view it in a vtk file. It doesn't work. But, in the talk and the thesis, there is a Laplace example implementing the local mesh refinement. I plan to go through the fd source code so that i can find out what is going on. Before that, I have to ask if you can show me the mentioned Laplace code, that would be great.
Best regards,
--Mengjie
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250709/1fba7138/attachment.html>
