[petsc-users] Inquiry about PetscDS for discretization of second order system
Matthew Knepley
knepley at gmail.com
Fri Jan 3 13:09:21 CST 2025
On Fri, Jan 3, 2025 at 5:11 AM Gong Yujie <yc17470 at connect.um.edu.mo> wrote:
> Dear PETSc developer group,
> I'd like to inquire that if PetscDSSetResidual can be used for second
> order system? Are there a DS function that is related to solve a system
> that contains second order time derivative such as time dependent linear
> elasticity problem.
> I found there is tutorial for elastostatics problem using PetscDS but this
> doesn't involve time discretization. In TS, there is alpha method for
> solving second order system, but I haven't found a tutorial using DS yet.
> Is there a way to combine PetscDS with the alpha method in TS?
I did not include the second derivative in the interface. Instead what I do
is rewrite it as a first order system using
v = \dot u. I hope to augment the interface sometime to add the second
derivative, but it really only applies to that
alpha integrator.
Matt
> Best Regards,
> Yujie
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!aJ9bb4A4GeC3g-mMF6JrF-h30KdOz02aD1BUS889Xw2dK6lyHAe3QWUEfIcoiymARmU9ozG5CzsQXVlpi3c-$ <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!aJ9bb4A4GeC3g-mMF6JrF-h30KdOz02aD1BUS889Xw2dK6lyHAe3QWUEfIcoiymARmU9ozG5CzsQXQnIZQab$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250103/97b5ba4a/attachment.html>
