[petsc-users] Inquiry about PetscDS for discretization of second order system
Gong Yujie
yc17470 at connect.um.edu.mo
Fri Jan 3 09:11:04 CST 2025
Dear PETSc developer group,
I'd like to inquire that if PetscDSSetResidual can be used for second order system? Are there a DS function that is related to solve a system that contains second order time derivative such as time dependent linear elasticity problem.
I found there is tutorial for elastostatics problem using PetscDS but this doesn't involve time discretization. In TS, there is alpha method for solving second order system, but I haven't found a tutorial using DS yet. Is there a way to combine PetscDS with the alpha method in TS?
Best Regards,
Yujie
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250103/4b0b26f8/attachment.html>
