[petsc-users] subdomain solver options
Matthew Knepley
knepley at gmail.com
Wed Aug 27 07:05:38 CDT 2025
See you next week!
Matt
On Wed, Aug 27, 2025 at 3:39 AM Anton Popov <popov at uni-mainz.de> wrote:
> Thanks Matt, it works!
> Anton
> On 26.08.25 22:34, Matthew Knepley wrote:
> On Tue, Aug 26, 2025 at 12:45 PM Anton Popov <popov at uni-mainz.de> wrote:
>> There is an important addition, I use asm and bjacobi as smoothers on
>> multigrid levels.
>> So I probably need to set the options with -mg_levels_sub_, or
>> -mg_levels_3_sub_(if they are different on different levels), instead of
>> just -sub_.
>> Correct?
> Yes, and as Mark says, you can see the prefix if you View the solver.
> Thanks,
> Matt
>> Anton
>> On 26.08.25 18:20, Anton Popov wrote:
>> > Hi all,
>> > I have a strange behavior setting the solver options for asm and
>> > bjacobi blocks.
>> > Irrespective of what I set with -sub_ksp_ -sub_pc_ it just selects the
>> > default preonly and ilu options.
>> > This behavior does not change no matter how many local blocks per cpu
>> > I try to use, for example with the default one block/cpu it does not
>> > work as well.
>> > Is there anything wrong?
>> > Best,
>> > Anton
> experiments lead.
> -- Norbert Wiener
> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!ae4Aps9OCcaKciUHsxH-E9BnL2D7koMv1G07Exb_JY9ucOmJAyxzUmcN2-yQA2HhQwqM60PF6N6iaxjalQE9$
> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!ae4Aps9OCcaKciUHsxH-E9BnL2D7koMv1G07Exb_JY9ucOmJAyxzUmcN2-yQA2HhQwqM60PF6N6ia_wAppzA$ >
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!ae4Aps9OCcaKciUHsxH-E9BnL2D7koMv1G07Exb_JY9ucOmJAyxzUmcN2-yQA2HhQwqM60PF6N6iaxjalQE9$ <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!ae4Aps9OCcaKciUHsxH-E9BnL2D7koMv1G07Exb_JY9ucOmJAyxzUmcN2-yQA2HhQwqM60PF6N6ia_wAppzA$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250827/c9bd60a3/attachment.html>
