[petsc-users] subdomain solver options
Anton Popov
popov at uni-mainz.de
Wed Aug 27 02:39:42 CDT 2025
Thanks Matt, it works!
Anton
On 26.08.25 22:34, Matthew Knepley wrote:
> On Tue, Aug 26, 2025 at 12:45 PM Anton Popov <popov at uni-mainz.de> wrote:
> There is an important addition, I use asm and bjacobi as smoothers on
> multigrid levels.
> So I probably need to set the options with -mg_levels_sub_, or
> -mg_levels_3_sub_(if they are different on different levels),
> instead of
> just -sub_.
> Correct?
> Yes, and as Mark says, you can see the prefix if you View the solver.
> Thanks,
> Matt
> Anton
> On 26.08.25 18:20, Anton Popov wrote:
> > Hi all,
> > I have a strange behavior setting the solver options for asm and
> > bjacobi blocks.
> > Irrespective of what I set with -sub_ksp_ -sub_pc_ it just
> selects the
> > default preonly and ilu options.
> > This behavior does not change no matter how many local blocks
> per cpu
> > I try to use, for example with the default one block/cpu it does
> not
> > work as well.
> > Is there anything wrong?
> > Best,
> > Anton
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!dduznZr2wz7YJHJJczD2Qkrwr8f7vwu56e_Z3HlM5b0coSWG33ZtoI9QE275Yki2aVtsa8vtSODfzsxo-uZkERvq$
> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!dduznZr2wz7YJHJJczD2Qkrwr8f7vwu56e_Z3HlM5b0coSWG33ZtoI9QE275Yki2aVtsa8vtSODfzsxo-qcAS3vN$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250827/abed8c5e/attachment.html>
