[petsc-users] subdomain solver options
Tue Aug 26 15:34:32 CDT 2025
On Tue, Aug 26, 2025 at 12:45 PM Anton Popov <popov at uni-mainz.de> wrote:
> There is an important addition, I use asm and bjacobi as smoothers on
> multigrid levels.
> So I probably need to set the options with -mg_levels_sub_, or
> -mg_levels_3_sub_(if they are different on different levels), instead of
> just -sub_.
> Correct?
Yes, and as Mark says, you can see the prefix if you View the solver.
     Matt
> Anton
> On 26.08.25 18:20, Anton Popov wrote:
> > Hi all,
> > I have a strange behavior setting the solver options for asm and
> > bjacobi blocks.
> > Irrespective of what I set with -sub_ksp_ -sub_pc_ it just selects the
> > default preonly and ilu options.
> > This behavior does not change no matter how many local blocks per cpu
> > I try to use, for example with the default one block/cpu it does not
> > work as well.
> > Is there anything wrong?
> > Best,
> > Anton
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!YJ62X-g3HWHOyVCSc8dsKNAO6uNehYJ2i4JwXTMP6lr_dBNvcvnnAgqOWC_c6IGw3_mqX47OtDZpkBsDOJyR$  <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!YJ62X-g3HWHOyVCSc8dsKNAO6uNehYJ2i4JwXTMP6lr_dBNvcvnnAgqOWC_c6IGw3_mqX47OtDZpkFfAsDJy$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250826/b5f055ee/attachment.html>
