[petsc-users] petsc4py installation via conda-forge
Eike Mueller em459 at bath.ac.uk
Mon Aug 18 06:55:46 CDT 2025
Dear PETSc developers,
I need to install petsc4py on a specific machine for teaching, and one of my colleagues pointed out that this can be done with conda-forge using this: https://urldefense.us/v3/__https://anaconda.org/conda-forge/petsc4py__;!!G_uCfscf7eWS!aObnO6iDXElFvWx8fXEjFR-baM6bUK1tm-qPqLb5kFKPoo_GYUC260Pm5WkJmanUStqmZ1HhWtmNudJeMLyxcg$
Are you aware of any problems with this approach? It’s not listed as an option under the petsc4py installation instructions https://urldefense.us/v3/__https://petsc.org/release/petsc4py/install.html__;!!G_uCfscf7eWS!aObnO6iDXElFvWx8fXEjFR-baM6bUK1tm-qPqLb5kFKPoo_GYUC260Pm5WkJmanUStqmZ1HhWtmNudKT9XFvlA$  . I had tried these first, but the pip install of petsc/petsc4py didn’t work. The install via anaconda/conda-forge did give me a working petsc4py, however. My colleague says that he also successfully used it on google collab.
Thank you very much,
Eike
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250818/3716cdbc/attachment.html>
