[petsc-users] petsc4py installation via conda-forge
Satish Balay
balay.anl at fastmail.org
Mon Aug 18 07:07:50 CDT 2025
On Mon, 18 Aug 2025, Eike Mueller via petsc-users wrote:
> Dear PETSc developers,
> I need to install petsc4py on a specific machine for teaching, and one of my colleagues pointed out that this can be done with conda-forge using this: https://urldefense.us/v3/__https://anaconda.org/conda-forge/petsc4py__;!!G_uCfscf7eWS!aObnO6iDXElFvWx8fXEjFR-baM6bUK1tm-qPqLb5kFKPoo_GYUC260Pm5WkJmanUStqmZ1HhWtmNudJeMLyxcg$
> Are you aware of any problems with this approach? It’s not listed as an option under the petsc4py installation instructions https://urldefense.us/v3/__https://petsc.org/release/petsc4py/install.html__;!!G_uCfscf7eWS!aObnO6iDXElFvWx8fXEjFR-baM6bUK1tm-qPqLb5kFKPoo_GYUC260Pm5WkJmanUStqmZ1HhWtmNudKT9XFvlA$ .
Hm we have conda (conda-forge) listed for PETSc at https://urldefense.us/v3/__https://petsc.org/release/install/__;!!G_uCfscf7eWS!YT8MIxLRgM1M4EgDQyr_BM0VkjMdsGa8sKUiEY6MeTB0XmurcA8ihfNry-uSv2zR1bQR7n-ceTf9ue71hwpmgSTl8a4$
> I had tried these first, but the pip install of petsc/petsc4py didn’t work.
It usually requires PETSc installed correctly. Some of us developers just install PETSc+PETSc4py via:
./configure [PETSc configure options] --with-petsc4py=1
> The install via anaconda/conda-forge did give me a working petsc4py, however. My colleague says that he also successfully used it on google collab.
Good to know.
Thanks!
Satish
> Thank you very much,
> Eike
