[petsc-users] [petsc-maint] norm L2 problemQuestion about changing the norm used in nonlinear solvers (L2 Euclidean vs. L2 Lebesgue)
Matthew Knepley
knepley at gmail.com
Wed Aug 13 14:52:09 CDT 2025
Ah, then you can just use
https://urldefense.us/v3/__https://petsc.org/main/manualpages/SNES/SNESSetConvergenceTest/__;!!G_uCfscf7eWS!b5Rm6Uca7nRuIRvz5loe-2If8OgOq1pxZCIhkk6IOO8PsiK7P7ooXpEK053J03WuANNw-ZftUDLu1NeNMT8G$
and compute your weighted norm yourself.
Matt
On Wed, Aug 13, 2025 at 3:45 PM Ali ALI AHMAD <ali.ali_ahmad at utt.fr> wrote:
> * As I mentioned earlier, the weighted norm I am referring to is:
> ||f||^2_2 = \int_{\Omega} |f(x)|^2 \, dx \approx \sum_{K \in \Omega}
> \sum_q |f(G_q)|^2 \, area(K)
> where G_q is the centroid of triangle K, computed using a first-order
> Gaussian quadrature rule.
> Yes, I am using the inexact Newton method, where the method stops when
> ||F(x_k) + J_{x_k} \, d_k|| \leq \nu_k \, ||F(x_k)||.
> Here, I would also like to change the norm to see whether this
> modification affects the quality of the descent direction. I know that
> these norms are theoretically equivalent, but I would like to test them to
> observe any difference between the two. My initial expectation is that the
> method may converge faster when using the L^2 norm.
> Best regards,
> Ali ALI AHMAD
> *De: *"Matthew Knepley" <knepley at gmail.com>
> *À: *"Ali ALI AHMAD" <ali.ali_ahmad at utt.fr>
> *Cc: *"Barry Smith" <bsmith at petsc.dev>, "petsc-users" <
> petsc-users at mcs.anl.gov>, "petsc-maint" <petsc-maint at mcs.anl.gov>
> *Envoyé: *Lundi 28 Juillet 2025 18:55:04
> *Objet: *Re: [petsc-maint] norm L2 problemQuestion about changing the
> On Mon, Jul 28, 2025 at 11:00 AM Ali ALI AHMAD <ali.ali_ahmad at utt.fr>
> wrote:
>> I’m sorry for getting back to you so late. Thank you for your patience
>> and understanding.
>> For example, when using L2 algorithms where a different norm is
>> applied in the line search, see *Line_search_L2.png* as an example
>> from this reference: https://urldefense.us/v3/__https://arxiv.org/abs/1607.04254__;!!G_uCfscf7eWS!b5Rm6Uca7nRuIRvz5loe-2If8OgOq1pxZCIhkk6IOO8PsiK7P7ooXpEK053J03WuANNw-ZftUDLu1CcZFu6I$
>> <https://urldefense.us/v3/__https://arxiv.org/abs/1607.04254__;!!G_uCfscf7eWS!ep85s6aXge00Uc1_kixR9yGEU0FBO9W8HTZ6LsVYzy9n9Jel5_r26mPMP138k1Ilhi2CAN6cR4DGe4kKZG997W1E0q3AIw$>.
>> Here, we can change the norm from the L2 Euclidean to the L2 Lebesgue norm.
>> What does "L2 Lebesgue" mean here? I know what I mean by L_2. It is
> ||f||^2_2 = \int_Omega |f(x)|^2 dx \approx \sum_q |f(x_q)|^2 w_q
> Oh, from below it seems you want a weight function wt(x) in the norm. So
> we would have
> \sum_q |f(x_q)|^2 wt(x_q) w_q
>> - For GMRES, we need to replace NORM_2 (L2 Euclidean) in your code
>> with weighted_NormL2 (L2 Lebesgue) everywhere, including all the
>> details such as in the Arnoldi algorithm...
>> I do not quite understand here, because GMRES does not use the L:_2 norm.
> It uses the l_2 norm, which is
> ||v||^2_2 = \sum |v_i|^2
> The things in the vector are coefficients of basis functions. I guess, if
> you had an interpolatory element, you could interpret this as quadrature
> rule, meaning you would have
> \sum wt(x_i) |v_i|^2
> where x_i were the coordinates of the dual basis evaluation functionals.
>> For the convergence test as well, in the linear system for finding
>> the direction *d* (A · d = b),
>> You want to use the inner product that generates your weighted L_2 norm?
>> and also when we search for a good step using the line search
>> formula: xk+1=xk+step×d.
>> You want to minimize your weighted L_2 norm. That should work in the same
> way.
> Thanks,
> Matt
>> I hope this explanation is clear for you.
>> Best regards,
>> Ali ALI AHMAD
>> *De: *"Barry Smith" <bsmith at petsc.dev>
>> *Cc: *"petsc-users" <petsc-users at mcs.anl.gov>, "petsc-maint" <
>> *Envoyé: *Vendredi 20 Juin 2025 15:50:17
>> On Jun 20, 2025, at 5:10 AM, Ali ALI AHMAD <ali.ali_ahmad at utt.fr> wrote:
>> * Yes, I am indeed using an inexact Newton method in my code. The descent
>> direction is computed by solving a linear system involving the Jacobian, so
>> the update follows the classical formula "J(un)^{-1}d(un)=-F(un)" I'm also
>> trying to use a line search strategy based on a weighted L2 norm (in the
>> Lebesgue sense), which a priori should lead to better accuracy and faster
>> convergence in anisotropic settings.
>> Ok, could you point to sample code (any language) or written
>> algorithms where a different norm is used in the line search?
>> * During the subsequent iterations, I apply the Eisenstat–Walker method
>> to adapt the tolerance, which should also involve modifying the norm used
>> in the algorithm.
>> * The current implementation still uses the standard Euclidean L2 norm in
>> PETSc's linear solver and in GMRES. I believe this should ideally be
>> replaced by a weighted L2 norm consistent with the discretization. However,
>> I haven't yet succeeded in modifying the norm used internally by the linear
>> solver in PETSc, so, I'm not yet sure how much impact this change would
>> have on the overall convergence, but I suspect it could improve robustness,
>> especially for highly anisotropic problems. I would greatly appreciate any
>> guidance on how to implement this properly in PETSc.
>> Norms are used in multiple ways in GMRES.
>> 1) defining convergence
>> 2) as part of preconditioning
>> Again can you point to sample code (any language) or written algorithms
>> that describe exactly what you would like to accomplish.
>> Barry
>> Do not hesitate to contact me again if anything remains unclear or if you
>> need further information.
>> Best regards,
>> Ali ALI AHMAD
>> *Envoyé: *Samedi 14 Juin 2025 01:06:52
>> I appreciate the clarification. I would call 3) preconditioning.
>> To increase my understanding, you are already using Newton's method?
>> That is, you compute the Jacobian of the function and use - J^{-1}(u^n)
>> F(u^n) as your update direction?
>> When you switch the inner product (or precondition) how will the
>> search direction be different?
>> Thanks
>> Barry
>> The case you need support for is becoming important to PETSc so we need
>> to understand it well and support it well which is why I am asking these
>> (perhaps to you) trivial questions.
>> On Jun 13, 2025, at 4:55 AM, Ali ALI AHMAD <ali.ali_ahmad at utt.fr> wrote:
>> Thank you for your message.
>> To answer your question: I would like to use the L2 norm in the sense of
>> Lebesgue for *all three purposes*, especially the *third one*.
>> *1- For displaying residuals* during the nonlinear iterations, I would
>> like to observe the convergence behavior using a norm that better reflects
>> the physical properties of the problem.
>> *2- For convergence testing*, I would like the stopping criterion to be
>> based on a weighted L2 norm that accounts for the geometry of the mesh
>> (since I am working with unstructured, anisotropic triangular meshes).
>> *3 - Most importantly*, I would like to modify the *inner product* used
>> in the algorithm so that it aligns with the weighted L2 norm (since I am
>> Best regards,
>> Ali ALI AHMAD
>> *Envoyé: *Vendredi 13 Juin 2025 03:14:06
>> You haven't answered my question. Where (conceptually) and for what
>> purpose do you want to use the L2 norm.
>> 1) displaying norms to observe the convergence behavior
>> 2) in the convergence testing to determine when to stop
>> 3) changing the "inner product" in the algorithm which amounts to
>> preconditioning.
>> Barry
>> On Jun 12, 2025, at 9:42 AM, Ali ALI AHMAD <ali.ali_ahmad at utt.fr> wrote:
>> Thank you for your answer.
>> I am currently working with the nonlinear solvers *newtonls* (with bt, l2,
>> etc.) and *newtontr* (using newton, cauchy, and dogleg strategies)
>> combined with the linear solver *gmres* and the *ILU* preconditioner,
>> since my Jacobian matrix is nonsymmetric.
>> I also use the Eisenstat-Walker method for newtonls, as my initial guess
>> is often very far from the exact solution.
>> What I would like to do now is to *replace the standard Euclidean L2
>> norm* with the *L2 norm in the Lebesgue sense in the above numerical
>> algorithm*, because my problem is defined on an *unstructured,
>> anisotropic triangular mesh* where a weighted norm would be more
>> physically appropriate.
>> Would you be able to advise me on how to implement this change properly?
>> I would deeply appreciate any guidance or suggestions you could provide.
>> Thank you in advance for your help.
>> Best regards,
>> Ali ALI AHMAD
>> *De: *"Ali ALI AHMAD" <ali.ali_ahmad at utt.fr>
>> *À: *"Barry Smith" <bsmith at petsc.dev>
>> *Envoyé: *Jeudi 12 Juin 2025 15:28:02
>> norm* with the *L2 norm in the Lebesgue sense*, because my problem is
>> defined on an *unstructured, anisotropic triangular mesh* where a
>> weighted norm would be more physically appropriate.
>> Best regards,
>> Ali ALI AHMAD
>> *Envoyé: *Jeudi 12 Juin 2025 14:57:40
>> Do you wish to use a different norm
>> 1) ONLY for displaying (printing out) the residual norms to track
>> progress
>> 3) to change the numerical algorithm (for example using the L2 inner
>> product instead of the usual linear algebra R^N l2 inner product).
>> For 1) use SNESMonitorSet() and in your monitor function use
>> SNESGetSolution() to grab the solution and then VecGetArray(). Now you can
>> compute any weighted norm you want on the solution.
>> For 2) similar but you need to use SNESSetConvergenceTest
>> For 3) yes, but you need to ask us specifically.
>> Barry
>> On Jun 11, 2025, at 4:45 AM, Ali ALI AHMAD <ali.ali_ahmad at utt.fr> wrote:
>> Dear PETSc team,
>> I hope this message finds you well.
>> I am currently using PETSc in a C++, where I rely on the nonlinear
>> solvers `SNES` with either `newtonls` or `newtontr` methods. I would like
>> to ask if it is possible to change the default norm used (typically the L2
>> Euclidean norm) to a custom norm, specifically the L2 norm in the sense of
>> Lebesgue (e.g., involving cell-wise weighted integrals over the domain).
>> My main goal is to define a custom residual norm that better reflects the
>> physical quantities of interest in my simulation.
>> Would this be feasible within the PETSc framework? If so, could you point
>> me to the recommended approach (e.g., redefining the norm manually, using
>> specific PETSc hooks or options)?
>> Thank you very much in advance for your help and for the great work on
>> PETSc!
>> Best regards,
>> Ali ALI AHMAD
>> PhD Student
>> University of Technology of Troyes - UTT - France
>> GAMMA3 Project - Office H008 - Phone No: +33 7 67 44 68 18
>> 12 rue Marie Curie - CS 42060 10004 TROYES Cedex
> experiments lead.
> -- Norbert Wiener
> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!b5Rm6Uca7nRuIRvz5loe-2If8OgOq1pxZCIhkk6IOO8PsiK7P7ooXpEK053J03WuANNw-ZftUDLu1NXIqWUQ$
> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!b5Rm6Uca7nRuIRvz5loe-2If8OgOq1pxZCIhkk6IOO8PsiK7P7ooXpEK053J03WuANNw-ZftUDLu1OjIfo34$ >
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!b5Rm6Uca7nRuIRvz5loe-2If8OgOq1pxZCIhkk6IOO8PsiK7P7ooXpEK053J03WuANNw-ZftUDLu1NXIqWUQ$ <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!b5Rm6Uca7nRuIRvz5loe-2If8OgOq1pxZCIhkk6IOO8PsiK7P7ooXpEK053J03WuANNw-ZftUDLu1OjIfo34$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250813/fd382caa/attachment-0001.html>
