[petsc-users] Compiling 3.21.5 version on a Grace Hopper node failed
Qiyue Lu
qiyuelu1 at gmail.com
Wed Sep 25 08:50:14 CDT 2024
Thanks Junchao and Satish,
However, using 'make V=1 CUDAFLAGS="-g -O0" all' produces the same error.
I will forward these discussions to our system admin, hoping they can get
some hints on this internal compiler error.
Qiyue Lu
On Tue, Sep 24, 2024 at 11:09 PM Satish Balay <balay.anl at fastmail.org>
wrote:
> Can you try the following and see if it makes a difference
> Satish
> On Tue, 24 Sep 2024, Junchao Zhang wrote:
> > Hi, Qiyue,
> > I don't have the exact compilers as yours (cuda-12.3 + gcc-13.2.1). I
> > tried petsc-3.21.5 with cuda-12.6 + gcc-13.3.0 and it compiled fine.
> > Since it was an internal compiler error, it seems the only option is to
> > change compilers.
> > Thanks.
> > --Junchao Zhang
> > On Fri, Sep 20, 2024 at 2:22 PM Qiyue Lu <qiyuelu1 at gmail.com> wrote:
> > > Sure, here it is. Thanks.
> > > On Fri, Sep 20, 2024 at 2:07 PM Junchao Zhang <junchao.zhang at gmail.com
> > > wrote:
> > >> Could you send the configure.log file?
> > >> --Junchao Zhang
> > >> On Fri, Sep 20, 2024 at 1:33 PM Qiyue Lu <qiyuelu1 at gmail.com> wrote:
> > >>> Thanks for your response.
> > >>> Here is my module loaded:
> > >>> *Currently Loaded Modules: 1) craype-arm-grace 4)
> > >>> perftools-base/24.03.0 7) craype/2.7.31 10)
> > >>> cray-libsci/24.03.0 13) default 2) libfabric/1.15.2.0
> https://urldefense.us/v3/__http://1.15.2.0__;!!G_uCfscf7eWS!ZHTIMyeRVq_2VWhDO4gvbHRyVBXfTyJ7D25fWIZqvdeq5izIpEwmCtqUmYOjItUtNDX2wgMxilvBpjEZv0WMfOTeAAxd$
> > 5) xpmem/2.8.4-1.0_7.1__ga37cbd9.shasta 8)
> > >>> cray-dsmml/0.3.0 11) PrgEnv-gnu/8.5.0 3) craype-network-ofi 6)
> > >>> gcc-native/13.2 9) cray-mpich/8.1.29 12)
> > >>> cudatoolkit/23.11_12.3*
> > >>> And here is the configuration option now:
> > >>> *--with-cc=cc --with-cxx=CC --with-fc=ftn --download-f2cblaslapack=1
> > >>> --with-cuda=1 *
> > >>> That error is still there.
> > >>> Best,
> > >>> Qiyue Lu
> > >>> On Fri, Sep 20, 2024 at 11:58 AM Junchao Zhang <
> junchao.zhang at gmail.com>
> > >>> wrote:
> /u/qiyuelu1/petsc/src/vec/vec/impls/seq/cupm/cuda/../vecseqcupm_impl.hpp:1313:150:
> > >>>> *internal compiler error*: in maybe_undo_parenthesized_ref, at
> > >>>> cp/semantics.c:1740
> > >>>> Did you use nvidia compilers, e.g. nvc, nvc++? If yes, you may
> want to
> > >>>> change to other compilers by loading other cray PrgEnvs
> > >>>> --Junchao Zhang
> > >>>> On Fri, Sep 20, 2024 at 11:42 AM Qiyue Lu <qiyuelu1 at gmail.com>
> wrote:
> > >>>>> Hello,
> > >>>>> I am trying to build the PETSc version 3.21.5 (the latest, cloned
> from
> > >>>>> git) version on a Grace Hopper node with this configuration
> options:
> > >>>>> --with-cudac=nvcc --with-cuda=1 --with-threadsafety=1*
> > >>>>> with module cudatoolkit/23.11_12.3.
> > >>>>> And I got this error:
> > >>>>> In instantiation of
> ‘Petsc::vec::cupm::impl::VecSeq_CUPM<<anonymous>
> > >>>>> >::SetAsync(Vec, PetscScalar, PetscDeviceContext)::<lambda()> [with
> > >>>>> Petsc::device::cupm::DeviceType T =
> (Petsc::device::cupm::DeviceType)0]’:
> /u/qiyuelu1/petsc/src/vec/vec/impls/seq/cupm/cuda/../vecseqcupm_impl.hpp:1313:157:
> > >>>>> required from ‘struct
> > >>>>> >::SetAsync(Vec, PetscScalar, PetscDeviceContext) [with
> (Petsc::device::cupm::DeviceType)0;
> > >>>>> PetscErrorCode = int; Vec = _p_Vec*; PetscScalar = double;
> > >>>>> PetscDeviceContext = _p_PetscDeviceContext*]::<lambda()>’
> /u/qiyuelu1/petsc/src/vec/vec/impls/seq/cupm/cuda/../vecseqcupm_impl.hpp:1313:167:
> > >>>>> required from ‘static PetscErrorCode
> > >>>>> Petsc::vec::cupm::impl::VecSeq_CUPM<<anonymous> >::SetAsync(Vec,
> > >>>>> (Petsc::device::cupm::DeviceType)0; PetscErrorCode = int; Vec =
> _p_Vec*;
> > >>>>> PetscScalar = double; PetscDeviceContext = _p_PetscDeviceContext*]’
> > >>>>> /u/qiyuelu1/petsc/src/vec/vec/impls/seq/cupm/cuda/vecseqcupm.cu:7
> :40:
> > >>>>> required from here
> > >>>>> internal compiler error: in maybe_undo_parenthesized_ref, at
> > >>>>> cp/semantics.c:1740
> > >>>>> PetscCallThrust(THRUST_CALL(thrust::fill, stream, dptr,
> dptr +
> > >>>>> n, alpha));
> > >>>>> Could you please show some hints on this issue?
> > >>>>> Thanks,
> > >>>>> Qiyue Lu
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240925/32c173e4/attachment-0001.html>
