[petsc-users] Compiling 3.21.5 version on a Grace Hopper node failed
Satish Balay
balay.anl at fastmail.org
Tue Sep 24 23:09:29 CDT 2024
Can you try the following and see if it makes a difference
make V=1 CUDAFLAGS="-g -O0" all
Satish
On Tue, 24 Sep 2024, Junchao Zhang wrote:
> Hi, Qiyue,
> I don't have the exact compilers as yours (cuda-12.3 + gcc-13.2.1). I
> tried petsc-3.21.5 with cuda-12.6 + gcc-13.3.0 and it compiled fine.
> Since it was an internal compiler error, it seems the only option is to
> change compilers.
> Thanks.
> --Junchao Zhang
> On Fri, Sep 20, 2024 at 2:22 PM Qiyue Lu <qiyuelu1 at gmail.com> wrote:
> > Sure, here it is. Thanks.
> > On Fri, Sep 20, 2024 at 2:07 PM Junchao Zhang <junchao.zhang at gmail.com>
> > wrote:
> >> Could you send the configure.log file?
> >> --Junchao Zhang
> >> On Fri, Sep 20, 2024 at 1:33 PM Qiyue Lu <qiyuelu1 at gmail.com> wrote:
> >>> Thanks for your response.
> >>> Here is my module loaded:
> >>> *Currently Loaded Modules: 1) craype-arm-grace 4)
> >>> perftools-base/24.03.0 7) craype/2.7.31 10)
> >>> cray-libsci/24.03.0 13) default 2) libfabric/1.15.2.0
> >>> <https://urldefense.us/v3/__http://1.15.2.0__;!!G_uCfscf7eWS!ZHTIMyeRVq_2VWhDO4gvbHRyVBXfTyJ7D25fWIZqvdeq5izIpEwmCtqUmYOjItUtNDX2wgMxilvBpjEZv0WMfOTeAAxd$ > 5) xpmem/2.8.4-1.0_7.1__ga37cbd9.shasta 8)
> >>> cray-dsmml/0.3.0 11) PrgEnv-gnu/8.5.0 3) craype-network-ofi 6)
> >>> gcc-native/13.2 9) cray-mpich/8.1.29 12)
> >>> cudatoolkit/23.11_12.3*
> >>> And here is the configuration option now:
> >>> *--with-cc=cc --with-cxx=CC --with-fc=ftn --download-f2cblaslapack=1
> >>> --with-cuda=1 *
> >>> That error is still there.
> >>> Best,
> >>> Qiyue Lu
> >>> On Fri, Sep 20, 2024 at 11:58 AM Junchao Zhang <junchao.zhang at gmail.com>
> >>> wrote:
> >>>> /u/qiyuelu1/petsc/src/vec/vec/impls/seq/cupm/cuda/../vecseqcupm_impl.hpp:1313:150:
> >>>> *internal compiler error*: in maybe_undo_parenthesized_ref, at
> >>>> cp/semantics.c:1740
> >>>> Did you use nvidia compilers, e.g. nvc, nvc++? If yes, you may want to
> >>>> change to other compilers by loading other cray PrgEnvs
> >>>> --Junchao Zhang
> >>>> On Fri, Sep 20, 2024 at 11:42 AM Qiyue Lu <qiyuelu1 at gmail.com> wrote:
> >>>>> Hello,
> >>>>> I am trying to build the PETSc version 3.21.5 (the latest, cloned from
> >>>>> git) version on a Grace Hopper node with this configuration options:
> >>>>> --with-cudac=nvcc --with-cuda=1 --with-threadsafety=1*
> >>>>> with module cudatoolkit/23.11_12.3.
> >>>>> And I got this error:
> >>>>> In instantiation of ‘Petsc::vec::cupm::impl::VecSeq_CUPM<<anonymous>
> >>>>> >::SetAsync(Vec, PetscScalar, PetscDeviceContext)::<lambda()> [with
> >>>>> Petsc::device::cupm::DeviceType T = (Petsc::device::cupm::DeviceType)0]’:
> >>>>> /u/qiyuelu1/petsc/src/vec/vec/impls/seq/cupm/cuda/../vecseqcupm_impl.hpp:1313:157:
> >>>>> required from ‘struct Petsc::vec::cupm::impl::VecSeq_CUPM<<anonymous>
> >>>>> >::SetAsync(Vec, PetscScalar, PetscDeviceContext) [with
> >>>>> Petsc::device::cupm::DeviceType T = (Petsc::device::cupm::DeviceType)0;
> >>>>> PetscErrorCode = int; Vec = _p_Vec*; PetscScalar = double;
> >>>>> PetscDeviceContext = _p_PetscDeviceContext*]::<lambda()>’
> >>>>> /u/qiyuelu1/petsc/src/vec/vec/impls/seq/cupm/cuda/../vecseqcupm_impl.hpp:1313:167:
> >>>>> required from ‘static PetscErrorCode
> >>>>> Petsc::vec::cupm::impl::VecSeq_CUPM<<anonymous> >::SetAsync(Vec,
> >>>>> PetscScalar, PetscDeviceContext) [with Petsc::device::cupm::DeviceType T =
> >>>>> (Petsc::device::cupm::DeviceType)0; PetscErrorCode = int; Vec = _p_Vec*;
> >>>>> PetscScalar = double; PetscDeviceContext = _p_PetscDeviceContext*]’
> >>>>> /u/qiyuelu1/petsc/src/vec/vec/impls/seq/cupm/cuda/vecseqcupm.cu:7:40:
> >>>>> required from here
> >>>>> internal compiler error: in maybe_undo_parenthesized_ref, at
> >>>>> cp/semantics.c:1740
> >>>>> PetscCallThrust(THRUST_CALL(thrust::fill, stream, dptr, dptr +
> >>>>> n, alpha));
> >>>>> Could you please show some hints on this issue?
> >>>>> Thanks,
> >>>>> Qiyue Lu
