[petsc-users] Compiling 3.21.5 version on a Grace Hopper node failed
Satish Balay balay.anl at fastmail.org
Wed Sep 25 09:03:00 CDT 2024
V=1 should print the exact compile command used - that produced that internal compiler error.
Satish
On Wed, 25 Sep 2024, Qiyue Lu wrote:
> Thanks Junchao and Satish,
> However, using 'make V=1 CUDAFLAGS="-g -O0" all' produces the same error.
> I will forward these discussions to our system admin, hoping they can get
> some hints on this internal compiler error.
> Thanks,
> Qiyue Lu
> On Tue, Sep 24, 2024 at 11:09 PM Satish Balay <balay.anl at fastmail.org>
> wrote:
> > Can you try the following and see if it makes a difference
> > Satish
> > On Tue, 24 Sep 2024, Junchao Zhang wrote:
> > > Hi, Qiyue,
> > >   I don't have the exact compilers as yours (cuda-12.3 + gcc-13.2.1).  I
> > > tried petsc-3.21.5 with cuda-12.6 +  gcc-13.3.0 and it compiled fine.
> > >   Since it was an internal compiler error, it seems the only option is to
> > > change compilers.
> > >   Thanks.
> > > --Junchao Zhang
> > > On Fri, Sep 20, 2024 at 2:22 PM Qiyue Lu <qiyuelu1 at gmail.com> wrote:
> > > > Sure, here it is. Thanks.
> > > > On Fri, Sep 20, 2024 at 2:07 PM Junchao Zhang <junchao.zhang at gmail.com
> > > > wrote:
> > > >> Could you send the configure.log file?
> > > >> --Junchao Zhang
> > > >> On Fri, Sep 20, 2024 at 1:33 PM Qiyue Lu <qiyuelu1 at gmail.com> wrote:
> > > >>> Thanks for your response.
> > > >>> Here is my module loaded:
> > > >>> *Currently Loaded Modules:  1) craype-arm-grace     4)
> > > >>> perftools-base/24.03.0                 7) craype/2.7.31      10)
> > > >>> cray-libsci/24.03.0     13) default  2) libfabric/1.15.2.0
> > https://urldefense.us/v3/__http://1.15.2.0__;!!G_uCfscf7eWS!ZHTIMyeRVq_2VWhDO4gvbHRyVBXfTyJ7D25fWIZqvdeq5izIpEwmCtqUmYOjItUtNDX2wgMxilvBpjEZv0WMfOTeAAxd$
> > >   5) xpmem/2.8.4-1.0_7.1__ga37cbd9.shasta   8)
> > > >>> cray-dsmml/0.3.0   11) PrgEnv-gnu/8.5.0  3) craype-network-ofi   6)
> > > >>> gcc-native/13.2                        9) cray-mpich/8.1.29  12)
> > > >>> cudatoolkit/23.11_12.3*
> > > >>> And here is the configuration option now:
> > > >>> *--with-cc=cc --with-cxx=CC --with-fc=ftn --download-f2cblaslapack=1
> > > >>> --with-cuda=1 *
> > > >>> That error is still there.
> > > >>> Best,
> > > >>> Qiyue Lu
> > > >>> On Fri, Sep 20, 2024 at 11:58 AM Junchao Zhang <
> > junchao.zhang at gmail.com>
> > > >>> wrote:
> > /u/qiyuelu1/petsc/src/vec/vec/impls/seq/cupm/cuda/../vecseqcupm_impl.hpp:1313:150:
> > > >>>> *internal compiler error*: in maybe_undo_parenthesized_ref, at
> > > >>>> cp/semantics.c:1740
> > > >>>> Did you use nvidia compilers, e.g. nvc, nvc++?  If yes, you may
> > want to
> > > >>>> change to other compilers by loading other cray PrgEnvs
> > > >>>> --Junchao Zhang
> > > >>>> On Fri, Sep 20, 2024 at 11:42 AM Qiyue Lu <qiyuelu1 at gmail.com>
> > wrote:
> > > >>>>> Hello,
> > > >>>>> I am trying to build the PETSc version 3.21.5 (the latest, cloned
> > from
> > > >>>>> git) version on a Grace Hopper node with this configuration
> > options:
> > > >>>>> --with-cudac=nvcc --with-cuda=1 --with-threadsafety=1*
> > > >>>>> with module cudatoolkit/23.11_12.3.
> > > >>>>> And I got this error:
> > > >>>>> In instantiation of
> > ‘Petsc::vec::cupm::impl::VecSeq_CUPM<<anonymous>
> > > >>>>> >::SetAsync(Vec, PetscScalar, PetscDeviceContext)::<lambda()> [with
> > > >>>>> Petsc::device::cupm::DeviceType T =
> > (Petsc::device::cupm::DeviceType)0]’:
> > /u/qiyuelu1/petsc/src/vec/vec/impls/seq/cupm/cuda/../vecseqcupm_impl.hpp:1313:157:
> > > >>>>>   required from ‘struct
> > > >>>>> >::SetAsync(Vec, PetscScalar, PetscDeviceContext) [with
> > (Petsc::device::cupm::DeviceType)0;
> > > >>>>> PetscErrorCode = int; Vec = _p_Vec*; PetscScalar = double;
> > > >>>>> PetscDeviceContext = _p_PetscDeviceContext*]::<lambda()>’
> > /u/qiyuelu1/petsc/src/vec/vec/impls/seq/cupm/cuda/../vecseqcupm_impl.hpp:1313:167:
> > > >>>>>   required from ‘static PetscErrorCode
> > > >>>>> Petsc::vec::cupm::impl::VecSeq_CUPM<<anonymous> >::SetAsync(Vec,
> > > >>>>> (Petsc::device::cupm::DeviceType)0; PetscErrorCode = int; Vec =
> > _p_Vec*;
> > > >>>>> PetscScalar = double; PetscDeviceContext = _p_PetscDeviceContext*]’
> > > >>>>> /u/qiyuelu1/petsc/src/vec/vec/impls/seq/cupm/cuda/vecseqcupm.cu:7
> > :40:
> > > >>>>>   required from here
> > > >>>>> internal compiler error: in maybe_undo_parenthesized_ref, at
> > > >>>>> cp/semantics.c:1740
> > > >>>>>        PetscCallThrust(THRUST_CALL(thrust::fill, stream, dptr,
> > dptr +
> > > >>>>> n, alpha));
> > > >>>>> Could you please show some hints on this issue?
> > > >>>>> Thanks,
> > > >>>>> Qiyue Lu
