[petsc-users] Compiling 3.21.5 version on a Grace Hopper node failed
Junchao Zhang junchao.zhang at gmail.com
Tue Sep 24 23:00:34 CDT 2024
Hi, Qiyue,
  I don't have the exact compilers as yours (cuda-12.3 + gcc-13.2.1).  I
tried petsc-3.21.5 with cuda-12.6 +  gcc-13.3.0 and it compiled fine.
  Since it was an internal compiler error, it seems the only option is to
change compilers.
  Thanks.
--Junchao Zhang
On Fri, Sep 20, 2024 at 2:22 PM Qiyue Lu <qiyuelu1 at gmail.com> wrote:
> Sure, here it is. Thanks.
> On Fri, Sep 20, 2024 at 2:07 PM Junchao Zhang <junchao.zhang at gmail.com>
> wrote:
>> Could you send the configure.log file?
>> --Junchao Zhang
>> On Fri, Sep 20, 2024 at 1:33 PM Qiyue Lu <qiyuelu1 at gmail.com> wrote:
>>> Thanks for your response.
>>> Here is my module loaded:
>>> *Currently Loaded Modules:  1) craype-arm-grace     4)
>>> perftools-base/24.03.0                 7) craype/2.7.31      10)
>>> cray-libsci/24.03.0     13) default  2) libfabric/1.15.2.0
>>> <https://urldefense.us/v3/__http://1.15.2.0__;!!G_uCfscf7eWS!ZHTIMyeRVq_2VWhDO4gvbHRyVBXfTyJ7D25fWIZqvdeq5izIpEwmCtqUmYOjItUtNDX2wgMxilvBpjEZv0WMfOTeAAxd$ >   5) xpmem/2.8.4-1.0_7.1__ga37cbd9.shasta   8)
>>> cray-dsmml/0.3.0   11) PrgEnv-gnu/8.5.0  3) craype-network-ofi   6)
>>> gcc-native/13.2                        9) cray-mpich/8.1.29  12)
>>> cudatoolkit/23.11_12.3*
>>> And here is the configuration option now:
>>> *--with-cc=cc --with-cxx=CC --with-fc=ftn --download-f2cblaslapack=1
>>> --with-cuda=1 *
>>> That error is still there.
>>> Best,
>>> Qiyue Lu
>>> On Fri, Sep 20, 2024 at 11:58 AM Junchao Zhang <junchao.zhang at gmail.com>
>>> wrote:
>>>> /u/qiyuelu1/petsc/src/vec/vec/impls/seq/cupm/cuda/../vecseqcupm_impl.hpp:1313:150:
>>>> *internal compiler error*: in maybe_undo_parenthesized_ref, at
>>>> cp/semantics.c:1740
>>>> Did you use nvidia compilers, e.g. nvc, nvc++?  If yes, you may want to
>>>> change to other compilers by loading other cray PrgEnvs
>>>> --Junchao Zhang
>>>> On Fri, Sep 20, 2024 at 11:42 AM Qiyue Lu <qiyuelu1 at gmail.com> wrote:
>>>>> Hello,
>>>>> I am trying to build the PETSc version 3.21.5 (the latest, cloned from
>>>>> git) version on a Grace Hopper node with this configuration options:
>>>>> --with-cudac=nvcc --with-cuda=1 --with-threadsafety=1*
>>>>> with module cudatoolkit/23.11_12.3.
>>>>> And I got this error:
>>>>> In instantiation of ‘Petsc::vec::cupm::impl::VecSeq_CUPM<<anonymous>
>>>>> >::SetAsync(Vec, PetscScalar, PetscDeviceContext)::<lambda()> [with
>>>>> Petsc::device::cupm::DeviceType T = (Petsc::device::cupm::DeviceType)0]’:
>>>>> /u/qiyuelu1/petsc/src/vec/vec/impls/seq/cupm/cuda/../vecseqcupm_impl.hpp:1313:157:
>>>>>   required from ‘struct Petsc::vec::cupm::impl::VecSeq_CUPM<<anonymous>
>>>>> >::SetAsync(Vec, PetscScalar, PetscDeviceContext) [with
>>>>> Petsc::device::cupm::DeviceType T = (Petsc::device::cupm::DeviceType)0;
>>>>> PetscErrorCode = int; Vec = _p_Vec*; PetscScalar = double;
>>>>> PetscDeviceContext = _p_PetscDeviceContext*]::<lambda()>’
>>>>> /u/qiyuelu1/petsc/src/vec/vec/impls/seq/cupm/cuda/../vecseqcupm_impl.hpp:1313:167:
>>>>>   required from ‘static PetscErrorCode
>>>>> Petsc::vec::cupm::impl::VecSeq_CUPM<<anonymous> >::SetAsync(Vec,
>>>>> PetscScalar, PetscDeviceContext) [with Petsc::device::cupm::DeviceType T =
>>>>> (Petsc::device::cupm::DeviceType)0; PetscErrorCode = int; Vec = _p_Vec*;
>>>>> PetscScalar = double; PetscDeviceContext = _p_PetscDeviceContext*]’
>>>>> /u/qiyuelu1/petsc/src/vec/vec/impls/seq/cupm/cuda/vecseqcupm.cu:7:40:
>>>>>   required from here
>>>>> internal compiler error: in maybe_undo_parenthesized_ref, at
>>>>> cp/semantics.c:1740
>>>>>        PetscCallThrust(THRUST_CALL(thrust::fill, stream, dptr, dptr +
>>>>> n, alpha));
>>>>> Could you please show some hints on this issue?
>>>>> Thanks,
>>>>> Qiyue Lu
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240924/1b77100f/attachment.html>
