[petsc-users] Compiling 3.21.5 version on a Grace Hopper node failed
Junchao Zhang
junchao.zhang at gmail.com
Fri Sep 20 14:07:21 CDT 2024
Could you send the configure.log file?
--Junchao Zhang
On Fri, Sep 20, 2024 at 1:33 PM Qiyue Lu <qiyuelu1 at gmail.com> wrote:
> Thanks for your response.
> Here is my module loaded:
> *Currently Loaded Modules: 1) craype-arm-grace 4)
> perftools-base/24.03.0 7) craype/2.7.31 10)
> cray-libsci/24.03.0 13) default 2) libfabric/1.15.2.0
> <https://urldefense.us/v3/__http://1.15.2.0__;!!G_uCfscf7eWS!Yw0qmZpg6krBHpFd6Vo7oV3UPRv0Mgj2eSxu4qmUH78Dy-_dBA8MDplOrA-bdqZb3yNxK4E-_Xvsc-Sg9Yw5kd-AoAJE$ > 5) xpmem/2.8.4-1.0_7.1__ga37cbd9.shasta 8)
> cray-dsmml/0.3.0 11) PrgEnv-gnu/8.5.0 3) craype-network-ofi 6)
> gcc-native/13.2 9) cray-mpich/8.1.29 12)
> cudatoolkit/23.11_12.3*
> And here is the configuration option now:
> *--with-cc=cc --with-cxx=CC --with-fc=ftn --download-f2cblaslapack=1
> --with-cuda=1 *
> That error is still there.
> Best,
> Qiyue Lu
> On Fri, Sep 20, 2024 at 11:58 AM Junchao Zhang <junchao.zhang at gmail.com>
> wrote:
>> /u/qiyuelu1/petsc/src/vec/vec/impls/seq/cupm/cuda/../vecseqcupm_impl.hpp:1313:150:
>> *internal compiler error*: in maybe_undo_parenthesized_ref, at
>> cp/semantics.c:1740
>> Did you use nvidia compilers, e.g. nvc, nvc++? If yes, you may want to
>> change to other compilers by loading other cray PrgEnvs
>> --Junchao Zhang
>> On Fri, Sep 20, 2024 at 11:42 AM Qiyue Lu <qiyuelu1 at gmail.com> wrote:
>>> Hello,
>>> I am trying to build the PETSc version 3.21.5 (the latest, cloned from
>>> git) version on a Grace Hopper node with this configuration options:
>>> --with-cudac=nvcc --with-cuda=1 --with-threadsafety=1*
>>> with module cudatoolkit/23.11_12.3.
>>> And I got this error:
>>> In instantiation of ‘Petsc::vec::cupm::impl::VecSeq_CUPM<<anonymous>
>>> >::SetAsync(Vec, PetscScalar, PetscDeviceContext)::<lambda()> [with
>>> Petsc::device::cupm::DeviceType T = (Petsc::device::cupm::DeviceType)0]’:
>>> /u/qiyuelu1/petsc/src/vec/vec/impls/seq/cupm/cuda/../vecseqcupm_impl.hpp:1313:157:
>>> required from ‘struct Petsc::vec::cupm::impl::VecSeq_CUPM<<anonymous>
>>> >::SetAsync(Vec, PetscScalar, PetscDeviceContext) [with
>>> Petsc::device::cupm::DeviceType T = (Petsc::device::cupm::DeviceType)0;
>>> PetscErrorCode = int; Vec = _p_Vec*; PetscScalar = double;
>>> PetscDeviceContext = _p_PetscDeviceContext*]::<lambda()>’
>>> /u/qiyuelu1/petsc/src/vec/vec/impls/seq/cupm/cuda/../vecseqcupm_impl.hpp:1313:167:
>>> required from ‘static PetscErrorCode
>>> Petsc::vec::cupm::impl::VecSeq_CUPM<<anonymous> >::SetAsync(Vec,
>>> PetscScalar, PetscDeviceContext) [with Petsc::device::cupm::DeviceType T =
>>> (Petsc::device::cupm::DeviceType)0; PetscErrorCode = int; Vec = _p_Vec*;
>>> PetscScalar = double; PetscDeviceContext = _p_PetscDeviceContext*]’
>>> /u/qiyuelu1/petsc/src/vec/vec/impls/seq/cupm/cuda/vecseqcupm.cu:7:40:
>>> required from here
>>> internal compiler error: in maybe_undo_parenthesized_ref, at
>>> cp/semantics.c:1740
>>> PetscCallThrust(THRUST_CALL(thrust::fill, stream, dptr, dptr + n,
>>> alpha));
>>> Could you please show some hints on this issue?
>>> Thanks,
>>> Qiyue Lu
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240920/45d20eb0/attachment-0001.html>
