[petsc-users] Compiling 3.21.5 version on a Grace Hopper node failed
Qiyue Lu qiyuelu1 at gmail.com
Fri Sep 20 13:33:13 CDT 2024
Thanks for your response.
Here is my module loaded:
*Currently Loaded Modules:  1) craype-arm-grace     4)
perftools-base/24.03.0                 7) craype/2.7.31      10)
cray-libsci/24.03.0     13) default  2) libfabric/1.15.2.0
<https://urldefense.us/v3/__http://1.15.2.0__;!!G_uCfscf7eWS!YxwuA3RZGrDbd-WJg-ikPS5FGHt0IuvRdt50Xlh8K2yBzh5tUaPQ1RLsI9EotlhCLGtht706RRdTqmet898TWw$ >   5) xpmem/2.8.4-1.0_7.1__ga37cbd9.shasta   8)
cray-dsmml/0.3.0   11) PrgEnv-gnu/8.5.0  3) craype-network-ofi   6)
gcc-native/13.2                        9) cray-mpich/8.1.29  12)
cudatoolkit/23.11_12.3*
And here is the configuration option now:
*--with-cc=cc --with-cxx=CC --with-fc=ftn --download-f2cblaslapack=1
--with-cuda=1 *
That error is still there.
Best,
Qiyue Lu
On Fri, Sep 20, 2024 at 11:58 AM Junchao Zhang <junchao.zhang at gmail.com>
wrote:
> /u/qiyuelu1/petsc/src/vec/vec/impls/seq/cupm/cuda/../vecseqcupm_impl.hpp:1313:150:
> *internal compiler error*: in maybe_undo_parenthesized_ref, at
> cp/semantics.c:1740
> Did you use nvidia compilers, e.g. nvc, nvc++?  If yes, you may want to
> change to other compilers by loading other cray PrgEnvs
> --Junchao Zhang
> On Fri, Sep 20, 2024 at 11:42 AM Qiyue Lu <qiyuelu1 at gmail.com> wrote:
>> Hello,
>> I am trying to build the PETSc version 3.21.5 (the latest, cloned from
>> git) version on a Grace Hopper node with this configuration options:
>> --with-cudac=nvcc --with-cuda=1 --with-threadsafety=1*
>> with module cudatoolkit/23.11_12.3.
>> And I got this error:
>> In instantiation of ‘Petsc::vec::cupm::impl::VecSeq_CUPM<<anonymous>
>> >::SetAsync(Vec, PetscScalar, PetscDeviceContext)::<lambda()> [with
>> Petsc::device::cupm::DeviceType T = (Petsc::device::cupm::DeviceType)0]’:
>> /u/qiyuelu1/petsc/src/vec/vec/impls/seq/cupm/cuda/../vecseqcupm_impl.hpp:1313:157:
>>   required from ‘struct Petsc::vec::cupm::impl::VecSeq_CUPM<<anonymous>
>> >::SetAsync(Vec, PetscScalar, PetscDeviceContext) [with
>> Petsc::device::cupm::DeviceType T = (Petsc::device::cupm::DeviceType)0;
>> PetscErrorCode = int; Vec = _p_Vec*; PetscScalar = double;
>> PetscDeviceContext = _p_PetscDeviceContext*]::<lambda()>’
>> /u/qiyuelu1/petsc/src/vec/vec/impls/seq/cupm/cuda/../vecseqcupm_impl.hpp:1313:167:
>>   required from ‘static PetscErrorCode
>> Petsc::vec::cupm::impl::VecSeq_CUPM<<anonymous> >::SetAsync(Vec,
>> PetscScalar, PetscDeviceContext) [with Petsc::device::cupm::DeviceType T =
>> (Petsc::device::cupm::DeviceType)0; PetscErrorCode = int; Vec = _p_Vec*;
>> PetscScalar = double; PetscDeviceContext = _p_PetscDeviceContext*]’
>> /u/qiyuelu1/petsc/src/vec/vec/impls/seq/cupm/cuda/vecseqcupm.cu:7:40:
>> required from here
>> internal compiler error: in maybe_undo_parenthesized_ref, at
>> cp/semantics.c:1740
>>        PetscCallThrust(THRUST_CALL(thrust::fill, stream, dptr, dptr + n,
>> alpha));
>> Could you please show some hints on this issue?
>> Thanks,
>> Qiyue Lu
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240920/e3eec155/attachment.html>
