[petsc-users] Compiling 3.21.5 version on a Grace Hopper node failed
Junchao Zhang
junchao.zhang at gmail.com
Fri Sep 20 11:58:46 CDT 2024
/u/qiyuelu1/petsc/src/vec/vec/impls/seq/cupm/cuda/../vecseqcupm_impl.hpp:1313:150:
*internal compiler error*: in maybe_undo_parenthesized_ref, at
cp/semantics.c:1740
Did you use nvidia compilers, e.g. nvc, nvc++? If yes, you may want to
change to other compilers by loading other cray PrgEnvs
--Junchao Zhang
On Fri, Sep 20, 2024 at 11:42 AM Qiyue Lu <qiyuelu1 at gmail.com> wrote:
> Hello,
> I am trying to build the PETSc version 3.21.5 (the latest, cloned from
> git) version on a Grace Hopper node with this configuration options:
> *--with-cc=cc --with-cxx=CC --with-fc=ftn --download-f2cblaslapack=1
> --with-cudac=nvcc --with-cuda=1 --with-threadsafety=1*
> with module cudatoolkit/23.11_12.3.
> And I got this error:
> In instantiation of ‘Petsc::vec::cupm::impl::VecSeq_CUPM<<anonymous>
> >::SetAsync(Vec, PetscScalar, PetscDeviceContext)::<lambda()> [with
> Petsc::device::cupm::DeviceType T = (Petsc::device::cupm::DeviceType)0]’:
> /u/qiyuelu1/petsc/src/vec/vec/impls/seq/cupm/cuda/../vecseqcupm_impl.hpp:1313:157:
> required from ‘struct Petsc::vec::cupm::impl::VecSeq_CUPM<<anonymous>
> >::SetAsync(Vec, PetscScalar, PetscDeviceContext) [with
> Petsc::device::cupm::DeviceType T = (Petsc::device::cupm::DeviceType)0;
> PetscErrorCode = int; Vec = _p_Vec*; PetscScalar = double;
> PetscDeviceContext = _p_PetscDeviceContext*]::<lambda()>’
> /u/qiyuelu1/petsc/src/vec/vec/impls/seq/cupm/cuda/../vecseqcupm_impl.hpp:1313:167:
> required from ‘static PetscErrorCode
> Petsc::vec::cupm::impl::VecSeq_CUPM<<anonymous> >::SetAsync(Vec,
> PetscScalar, PetscDeviceContext) [with Petsc::device::cupm::DeviceType T =
> (Petsc::device::cupm::DeviceType)0; PetscErrorCode = int; Vec = _p_Vec*;
> PetscScalar = double; PetscDeviceContext = _p_PetscDeviceContext*]’
> /u/qiyuelu1/petsc/src/vec/vec/impls/seq/cupm/cuda/vecseqcupm.cu:7:40:
> required from here
> internal compiler error: in maybe_undo_parenthesized_ref, at
> cp/semantics.c:1740
> PetscCallThrust(THRUST_CALL(thrust::fill, stream, dptr, dptr + n,
> alpha));
> Could you please show some hints on this issue?
> Thanks,
> Qiyue Lu
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240920/d0f4f9ca/attachment.html>
