[petsc-users] Hypre AMS usage
Karthikeyan Chockalingam - STFC UKRI
karthikeyan.chockalingam at stfc.ac.uk
Mon Sep 9 12:21:03 CDT 2024
Hi Stefano,
Thank you. That was helpful. I tried the following:
petscErr = PetscOptionsSetValue(NULL,"-ksp_type", "gmres");
petscErr = PetscOptionsSetValue(NULL,"-pc_type", "hypre");
petscErr = PetscOptionsSetValue(NULL,"-pc_hypre_type", "ams");
// Set discrete gradient
petscErr = PCHYPRESetDiscreteGradient(pc, par_G);
// Set vertex coordinates
petscErr = PCHYPRESetEdgeConstantVectors(pc, par_xvec, par_yvec, par_zvec);
petscErr = PetscOptionsSetValue(NULL, "-ksp_view", NULL);
petscErr = PetscOptionsSetValue(NULL, "-ksp_monitor_true_residual", NULL);
petscErr = PetscOptionsSetValue(NULL, "-ksp_converged_reason", NULL);
petscErr = PetscOptionsSetValue(NULL, "-options_left", NULL);
petscErr = KSPSetFromOptions(ksp);
It errored though I have set PCHYPRESetEdgeConstantVectors.
But my program works, without PetscOptionsSetValue and by passing everything on the command line.
[0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[0]PETSC ERROR: HYPRE AMS preconditioner needs either the coordinate vectors via PCSetCoordinates() or the edge constant vectors via PCHYPRESetEdgeConstantVectors() or the interpolation matrix via PCHYPRESetInterpolations()
[0]PETS C ERROR: WARNING! There are unused option(s) set! Could be the program crashed before usage or a spelling mistake, etc!
[0]PETSC ERROR: Option left: name:-ksp_converged_reason (no value) source: code
[0]PETSC ERROR: Option left: name:-options_left (no value) source: code
[0]PETSC ERROR: See https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!bo8NogztIWNrMacTFrpY794WDAB_YywFIYjTEhfjw2AbsXby70K4dOS2r9FsXF_bZ8HoYvAVh93LRjf-_2KHd9PMnR3kMMB6siqa$ for trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.20.3, unknown
[0]PETSC ERROR: ./example-dbg on a arch-moose named HC20210312 by karthikeyan.chockalingam Mon Sep 9 18:10:13 2024
[0]PETSC ERROR: Configure options --with-64-bit-indices --with-cxx-dialect=C++17 --with-debugging=no --with-fortran-bindings=0 --with-mpi=1 --with-openmp=1 --with-shared-libraries=1 --with-sowing=0 --download-fblaslapack=1 --download-hypre=1 --download-metis=1 --download-mumps=1 --download-ptscotch=1 --download-parmetis=1 --download-scalapack=1 --download-slepc=1 --download-strumpack=1 --download-superlu_dist=1 --download-bison=1 --download-hdf5=1 --with-hdf5-fortran-bindings=0 --download-hdf5-configure-arguments="--with-zlib" --with-make-np=4
[0]PETSC ERROR: #1 PCSetUp_HYPRE() at /Users/karthikeyan.chockalingam/moose/petsc/src/ksp/pc/impls/hypre/hypre.c:295
[0]PETSC ERROR: #2 PCSetUp() at /Users/karthikeyan.chockalingam/moose/petsc/src/ksp/pc/interface/precon.c:1080
[0]PETSC ERROR: #3 KSPSetUp() at /Users/karthikeyan.chockalingam/moose/petsc/src/ksp/ksp/interface/itfunc.c:415
[0]PETSC ERROR: #4 KSPSolve_Private() at /Users/karthikeyan.chockalingam/moose/petsc/src/ksp/ksp/interface/itfunc.c:833
[0]PETSC ERROR: #5 KSPSolve() at /Users/karthikeyan.chockalingam/moose/petsc/src/ksp/ksp/interface/itfunc.c:1080
libMesh terminating:
From: Stefano Zampini <stefano.zampini at gmail.com>
Date: Monday, 9 September 2024 at 17:02
To: Matthew Knepley <knepley at gmail.com>
Cc: Chockalingam, Karthikeyan (STFC,DL,HC) <karthikeyan.chockalingam at stfc.ac.uk>, petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
Subject: Re: [petsc-users] Hypre AMS usage
I would say the best way is to look at the source code
https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-/blob/main/src/ksp/pc/impls/hypre/hypre.c?ref_type=heads*L2061__;Iw!!G_uCfscf7eWS!bo8NogztIWNrMacTFrpY794WDAB_YywFIYjTEhfjw2AbsXby70K4dOS2r9FsXF_bZ8HoYvAVh93LRjf-_2KHd9PMnR3kMHJAFTNc$
https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-/blob/main/src/ksp/pc/impls/hypre/hypre.c?ref_type=heads*L1239__;Iw!!G_uCfscf7eWS!bo8NogztIWNrMacTFrpY794WDAB_YywFIYjTEhfjw2AbsXby70K4dOS2r9FsXF_bZ8HoYvAVh93LRjf-_2KHd9PMnR3kMEACXByg$
Il giorno lun 9 set 2024 alle ore 18:50 Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>> ha scritto:
On Mon, Sep 9, 2024 at 10:17 AM Karthikeyan Chockalingam - STFC UKRI <karthikeyan.chockalingam at stfc.ac.uk<mailto:karthikeyan.chockalingam at stfc.ac.uk>> wrote:
Hi Matt,
You mentioned it doesn’t hurt to set the smoothing flags
https://urldefense.us/v3/__https://github.com/hypre-space/hypre/blob/3caa81955eb8d1b4e35d9b450e27cf6d07b50f6e/src/examples/ex15.c*L965__;Iw!!G_uCfscf7eWS!bo8NogztIWNrMacTFrpY794WDAB_YywFIYjTEhfjw2AbsXby70K4dOS2r9FsXF_bZ8HoYvAVh93LRjf-_2KHd9PMnR3kMDXhR5ES$ <https://urldefense.us/v3/__https:/github.com/hypre-space/hypre/blob/3caa81955eb8d1b4e35d9b450e27cf6d07b50f6e/src/examples/ex15.c*L965__;Iw!!G_uCfscf7eWS!biuCOXkV-qD-e8iTXiwaD9XJ0EWuqr2PidZJdPqbnFzCshQFo-mclGSvGBOPuGSTkjPvMKnIfJzWos7QShcSitpwyrhL55yOMB-v$>
Do you know where I can look for the equivalent PETSc commands? Thank you.
Yes, this is described here: https://urldefense.us/v3/__https://petsc.org/main/manualpages/PC/PCHYPRE/__;!!G_uCfscf7eWS!bo8NogztIWNrMacTFrpY794WDAB_YywFIYjTEhfjw2AbsXby70K4dOS2r9FsXF_bZ8HoYvAVh93LRjf-_2KHd9PMnR3kMON8QZMk$ <https://urldefense.us/v3/__https:/petsc.org/main/manualpages/PC/PCHYPRE/__;!!G_uCfscf7eWS!dM_jKT_vX0NCVNcY9XOTTUaTSW-TF2CgOkB2UDeZ2ztYXapdmLlSBT4XhV7PknN3ewygGWDbKFEP9e0RfePC$>
The best way is to run with -help or look at the source.
Matt
Kind regards,
Karthik.
From: Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>>
Date: Friday, 6 September 2024 at 17:57
To: Chockalingam, Karthikeyan (STFC,DL,HC) <karthikeyan.chockalingam at stfc.ac.uk<mailto:karthikeyan.chockalingam at stfc.ac.uk>>
Cc: petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov> <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>
On Fri, Sep 6, 2024 at 11:37 AM Karthikeyan Chockalingam - STFC UKRI via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
Hello,
I am trying to use the Hypre AMS preconditioner for the first time.
I am following the example problem from Hypre
https://urldefense.us/v3/__https://github.com/hypre-space/hypre/blob/3caa81955eb8d1b4e35d9b450e27cf6d07b50f6e/src/examples/ex15.c*L954__;Iw!!G_uCfscf7eWS!bo8NogztIWNrMacTFrpY794WDAB_YywFIYjTEhfjw2AbsXby70K4dOS2r9FsXF_bZ8HoYvAVh93LRjf-_2KHd9PMnR3kMFdo2F6F$ <https://urldefense.us/v3/__https:/github.com/hypre-space/hypre/blob/3caa81955eb8d1b4e35d9b450e27cf6d07b50f6e/src/examples/ex15.c*L954__;Iw!!G_uCfscf7eWS!biuCOXkV-qD-e8iTXiwaD9XJ0EWuqr2PidZJdPqbnFzCshQFo-mclGSvGBOPuGSTkjPvMKnIfJzWos7QShcSitpwyrhL5ySgA0XM$>
I have so far successfully set the discrete gradient operator and vertex co-ordinates,
Do I need to set the following smoothing options?
It cannot hurt. I would set them to begin with.
Also, do I need to convert from MATMPIAIJ to CSR?
https://urldefense.us/v3/__https://github.com/hypre-space/hypre/blob/3caa81955eb8d1b4e35d9b450e27cf6d07b50f6e/src/examples/ex15.c*L984__;Iw!!G_uCfscf7eWS!bo8NogztIWNrMacTFrpY794WDAB_YywFIYjTEhfjw2AbsXby70K4dOS2r9FsXF_bZ8HoYvAVh93LRjf-_2KHd9PMnR3kMJU8hG7u$ <https://urldefense.us/v3/__https:/github.com/hypre-space/hypre/blob/3caa81955eb8d1b4e35d9b450e27cf6d07b50f6e/src/examples/ex15.c*L984__;Iw!!G_uCfscf7eWS!biuCOXkV-qD-e8iTXiwaD9XJ0EWuqr2PidZJdPqbnFzCshQFo-mclGSvGBOPuGSTkjPvMKnIfJzWos7QShcSitpwyrhL53Trv1si$>
No.
What are the other PETSc calls to invoke AMS? Is there an example problem I can look at?
I do not know. I don't think we have an example.
Matt
Thank you.
Karthik.
Karthik Chockalingam, Ph.D.
Senior Research Software Engineer
High Performance Systems Engineering Group
Hartree Centre | Science and Technology Facilities Council
[signature_3970890138]
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!bo8NogztIWNrMacTFrpY794WDAB_YywFIYjTEhfjw2AbsXby70K4dOS2r9FsXF_bZ8HoYvAVh93LRjf-_2KHd9PMnR3kME7kopmI$ <https://urldefense.us/v3/__http:/www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!dM_jKT_vX0NCVNcY9XOTTUaTSW-TF2CgOkB2UDeZ2ztYXapdmLlSBT4XhV7PknN3ewygGWDbKFEP9ZyhqOzc$>
-- Norbert Wiener
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240909/f732ed97/attachment-0001.html>
Type: image/png
Desc: image001.png
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240909/f732ed97/attachment-0001.png>
