[petsc-users] Hypre AMS usage
Stefano Zampini
stefano.zampini at gmail.com
Mon Sep 9 11:02:24 CDT 2024
I would say the best way is to look at the source code
https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-/blob/main/src/ksp/pc/impls/hypre/hypre.c?ref_type=heads*L2061__;Iw!!G_uCfscf7eWS!b8Tv_XEoRSSehhvrYTELfhg0W08IjaDPGx3gkioYVRlIia4rZz7XLH7GXmXmEbathoNXMMfFaU8hWftak1IUQLf7BSgg7vg$
https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-/blob/main/src/ksp/pc/impls/hypre/hypre.c?ref_type=heads*L1239__;Iw!!G_uCfscf7eWS!b8Tv_XEoRSSehhvrYTELfhg0W08IjaDPGx3gkioYVRlIia4rZz7XLH7GXmXmEbathoNXMMfFaU8hWftak1IUQLf7I5s85AM$
Il giorno lun 9 set 2024 alle ore 18:50 Matthew Knepley <knepley at gmail.com>
ha scritto:
> On Mon, Sep 9, 2024 at 10:17 AM Karthikeyan Chockalingam - STFC UKRI <
> karthikeyan.chockalingam at stfc.ac.uk> wrote:
>> Hi Matt,
>> You mentioned it doesn’t hurt to set the smoothing flags
>> https://urldefense.us/v3/__https://github.com/hypre-space/hypre/blob/3caa81955eb8d1b4e35d9b450e27cf6d07b50f6e/src/examples/ex15.c*L965__;Iw!!G_uCfscf7eWS!b8Tv_XEoRSSehhvrYTELfhg0W08IjaDPGx3gkioYVRlIia4rZz7XLH7GXmXmEbathoNXMMfFaU8hWftak1IUQLf7ymdPBOQ$
>> <https://urldefense.us/v3/__https:/github.com/hypre-space/hypre/blob/3caa81955eb8d1b4e35d9b450e27cf6d07b50f6e/src/examples/ex15.c*L965__;Iw!!G_uCfscf7eWS!biuCOXkV-qD-e8iTXiwaD9XJ0EWuqr2PidZJdPqbnFzCshQFo-mclGSvGBOPuGSTkjPvMKnIfJzWos7QShcSitpwyrhL55yOMB-v$>
>> Do you know where I can look for the equivalent PETSc commands? Thank you.
> Yes, this is described here:
> https://urldefense.us/v3/__https://petsc.org/main/manualpages/PC/PCHYPRE/__;!!G_uCfscf7eWS!b8Tv_XEoRSSehhvrYTELfhg0W08IjaDPGx3gkioYVRlIia4rZz7XLH7GXmXmEbathoNXMMfFaU8hWftak1IUQLf7oW09bmM$
> <https://urldefense.us/v3/__https://petsc.org/main/manualpages/PC/PCHYPRE/__;!!G_uCfscf7eWS!dM_jKT_vX0NCVNcY9XOTTUaTSW-TF2CgOkB2UDeZ2ztYXapdmLlSBT4XhV7PknN3ewygGWDbKFEP9e0RfePC$>
> The best way is to run with -help or look at the source.
> Thanks,
> Matt
>> Kind regards,
>> Karthik.
>> *From: *Matthew Knepley <knepley at gmail.com>
>> *Date: *Friday, 6 September 2024 at 17:57
>> *To: *Chockalingam, Karthikeyan (STFC,DL,HC) <
>> *Cc: *petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
>> *Subject: *Re: [petsc-users] Hypre AMS usage
>> On Fri, Sep 6, 2024 at 11:37 AM Karthikeyan Chockalingam - STFC UKRI via
>> petsc-users <petsc-users at mcs.anl.gov> wrote:
>> Hello,
>> I am trying to use the Hypre AMS preconditioner for the first time.
>> I am following the example problem from Hypre
>> https://urldefense.us/v3/__https://github.com/hypre-space/hypre/blob/3caa81955eb8d1b4e35d9b450e27cf6d07b50f6e/src/examples/ex15.c*L954__;Iw!!G_uCfscf7eWS!b8Tv_XEoRSSehhvrYTELfhg0W08IjaDPGx3gkioYVRlIia4rZz7XLH7GXmXmEbathoNXMMfFaU8hWftak1IUQLf73VDWhpc$
>> <https://urldefense.us/v3/__https:/github.com/hypre-space/hypre/blob/3caa81955eb8d1b4e35d9b450e27cf6d07b50f6e/src/examples/ex15.c*L954__;Iw!!G_uCfscf7eWS!biuCOXkV-qD-e8iTXiwaD9XJ0EWuqr2PidZJdPqbnFzCshQFo-mclGSvGBOPuGSTkjPvMKnIfJzWos7QShcSitpwyrhL5ySgA0XM$>
>> I have so far successfully set the discrete gradient operator and vertex
>> co-ordinates,
>> // Set discrete gradient
>> petscErr = PCHYPRESetDiscreteGradient(pc, par_G);
>> // Set vertex coordinates
>> petscErr = PCHYPRESetEdgeConstantVectors(pc, par_xvec, par_yvec,
>> par_zvec);
>> Do I need to set the following smoothing options?
>> It cannot hurt. I would set them to begin with.
>> Also, do I need to convert from MATMPIAIJ to CSR?
>> https://urldefense.us/v3/__https://github.com/hypre-space/hypre/blob/3caa81955eb8d1b4e35d9b450e27cf6d07b50f6e/src/examples/ex15.c*L984__;Iw!!G_uCfscf7eWS!b8Tv_XEoRSSehhvrYTELfhg0W08IjaDPGx3gkioYVRlIia4rZz7XLH7GXmXmEbathoNXMMfFaU8hWftak1IUQLf7wD78NAo$
>> <https://urldefense.us/v3/__https:/github.com/hypre-space/hypre/blob/3caa81955eb8d1b4e35d9b450e27cf6d07b50f6e/src/examples/ex15.c*L984__;Iw!!G_uCfscf7eWS!biuCOXkV-qD-e8iTXiwaD9XJ0EWuqr2PidZJdPqbnFzCshQFo-mclGSvGBOPuGSTkjPvMKnIfJzWos7QShcSitpwyrhL53Trv1si$>
>> No.
>> What are the other PETSc calls to invoke AMS? Is there an example problem
>> I can look at?
>> I do not know. I don't think we have an example.
>> Thanks,
>> Matt
>> Thank you.
>> Karthik.
>> *Karthik Chockalingam, Ph.D.*
>> Senior Research Software Engineer
>> High Performance Systems Engineering Group
>> Hartree Centre | Science and Technology Facilities Council
>> [image: signature_3970890138]
>> experiments lead.
>> -- Norbert Wiener
>> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!b8Tv_XEoRSSehhvrYTELfhg0W08IjaDPGx3gkioYVRlIia4rZz7XLH7GXmXmEbathoNXMMfFaU8hWftak1IUQLf7uDER6bU$
>> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!dM_jKT_vX0NCVNcY9XOTTUaTSW-TF2CgOkB2UDeZ2ztYXapdmLlSBT4XhV7PknN3ewygGWDbKFEP9ZyhqOzc$>
> experiments lead.
> -- Norbert Wiener
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240909/343d7e6b/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240909/343d7e6b/attachment-0001.png>
