[petsc-users] Hypre AMS usage
Matthew Knepley
knepley at gmail.com
Mon Sep 9 13:09:20 CDT 2024
On Mon, Sep 9, 2024 at 1:21 PM Karthikeyan Chockalingam - STFC UKRI <
karthikeyan.chockalingam at stfc.ac.uk> wrote:
> Hi Stefano,
> Thank you. That was helpful. I tried the following:
> petscErr = PetscOptionsSetValue(NULL,"-ksp_type", "gmres");
> petscErr = PetscOptionsSetValue(NULL,"-pc_type", "hypre");
> petscErr = PetscOptionsSetValue(NULL,"-pc_hypre_type", "ams");
> // Set discrete gradient
> petscErr = PCHYPRESetDiscreteGradient(pc, par_G);
> // Set vertex coordinates
> petscErr = PCHYPRESetEdgeConstantVectors(pc, par_xvec, par_yvec,
> par_zvec);
> petscErr = PetscOptionsSetValue(NULL, "-ksp_view", NULL);
> petscErr = PetscOptionsSetValue(NULL, "-ksp_monitor_true_residual",
> NULL);
> petscErr = PetscOptionsSetValue(NULL, "-ksp_converged_reason", NULL);
> petscErr = PetscOptionsSetValue(NULL, "-options_left", NULL);
> petscErr = KSPSetFromOptions(ksp);
> It errored though I have set PCHYPRESetEdgeConstantVectors.
My guess is that the "pc" was not yet Hypre, since that type was not set
until KSPSetFromOptions() was called. So you need
to call those two functions after that call.
Matt
> But my program works, without PetscOptionsSetValue and by passing
> everything on the command line.
> *[0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: HYPRE AMS preconditioner needs either the coordinate
> vectors via PCSetCoordinates() or the edge constant vectors via
> PCHYPRESetEdgeConstantVectors() or the interpolation matrix via
> PCHYPRESetInterpolations()
> [0]PETS C ERROR: WARNING! There are unused option(s) set! Could be the
> program crashed before usage or a spelling mistake, etc!
> [0]PETSC ERROR: Option left: name:-ksp_converged_reason (no value)
> source: code
> [0]PETSC ERROR: Option left: name:-options_left (no value) source: code
> [0]PETSC ERROR: See https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!fe84MxfHZLtDHZMk46RBJyizvPamDZ_ysHWfHCyD26Z_SGQv2oMDYu7yeAV_WtK5hoqAqUuepnGqGC-mIHaN$ for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.20.3, unknown
> [0]PETSC ERROR: ./example-dbg on a arch-moose named HC20210312 by
> karthikeyan.chockalingam Mon Sep 9 18:10:13 2024
> [0]PETSC ERROR: Configure options --with-64-bit-indices
> --with-cxx-dialect=C++17 --with-debugging=no --with-fortran-bindings=0
> --with-mpi=1 --with-openmp=1 --with-shared-libraries=1 --with-sowing=0
> --download-fblaslapack=1 --download-hypre=1 --download-metis=1
> --download-mumps=1 --download-ptscotch=1 --download-parmetis=1
> --download-scalapack=1 --download-slepc=1 --download-strumpack=1
> --download-superlu_dist=1 --download-bison=1 --download-hdf5=1
> --with-hdf5-fortran-bindings=0
> --download-hdf5-configure-arguments="--with-zlib" --with-make-np=4
> [0]PETSC ERROR: #1 PCSetUp_HYPRE() at
> /Users/karthikeyan.chockalingam/moose/petsc/src/ksp/pc/impls/hypre/hypre.c:295
> [0]PETSC ERROR: #2 PCSetUp() at
> /Users/karthikeyan.chockalingam/moose/petsc/src/ksp/pc/interface/precon.c:1080
> [0]PETSC ERROR: #3 KSPSetUp() at
> /Users/karthikeyan.chockalingam/moose/petsc/src/ksp/ksp/interface/itfunc.c:415
> [0]PETSC ERROR: #4 KSPSolve_Private() at
> /Users/karthikeyan.chockalingam/moose/petsc/src/ksp/ksp/interface/itfunc.c:833
> [0]PETSC ERROR: #5 KSPSolve() at
> /Users/karthikeyan.chockalingam/moose/petsc/src/ksp/ksp/interface/itfunc.c:1080
> libMesh terminating:
> HYPRE AMS preconditioner needs either the coordinate vectors via
> *From: *Stefano Zampini <stefano.zampini at gmail.com>
> *Date: *Monday, 9 September 2024 at 17:02
> *To: *Matthew Knepley <knepley at gmail.com>
> *Cc: *Chockalingam, Karthikeyan (STFC,DL,HC) <
> karthikeyan.chockalingam at stfc.ac.uk>, petsc-users at mcs.anl.gov <
> petsc-users at mcs.anl.gov>
> *Subject: *Re: [petsc-users] Hypre AMS usage
> I would say the best way is to look at the source code
> https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-/blob/main/src/ksp/pc/impls/hypre/hypre.c?ref_type=heads*L2061__;Iw!!G_uCfscf7eWS!fe84MxfHZLtDHZMk46RBJyizvPamDZ_ysHWfHCyD26Z_SGQv2oMDYu7yeAV_WtK5hoqAqUuepnGqGGrHyHo_$
> https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-/blob/main/src/ksp/pc/impls/hypre/hypre.c?ref_type=heads*L1239__;Iw!!G_uCfscf7eWS!fe84MxfHZLtDHZMk46RBJyizvPamDZ_ysHWfHCyD26Z_SGQv2oMDYu7yeAV_WtK5hoqAqUuepnGqGJfzHU4z$
> Il giorno lun 9 set 2024 alle ore 18:50 Matthew Knepley <knepley at gmail.com>
> ha scritto:
> On Mon, Sep 9, 2024 at 10:17 AM Karthikeyan Chockalingam - STFC UKRI <
> Hi Matt,
> You mentioned it doesn’t hurt to set the smoothing flags
> https://urldefense.us/v3/__https://github.com/hypre-space/hypre/blob/3caa81955eb8d1b4e35d9b450e27cf6d07b50f6e/src/examples/ex15.c*L965__;Iw!!G_uCfscf7eWS!fe84MxfHZLtDHZMk46RBJyizvPamDZ_ysHWfHCyD26Z_SGQv2oMDYu7yeAV_WtK5hoqAqUuepnGqGNAEo0Pf$
> <https://urldefense.us/v3/__https:/github.com/hypre-space/hypre/blob/3caa81955eb8d1b4e35d9b450e27cf6d07b50f6e/src/examples/ex15.c*L965__;Iw!!G_uCfscf7eWS!biuCOXkV-qD-e8iTXiwaD9XJ0EWuqr2PidZJdPqbnFzCshQFo-mclGSvGBOPuGSTkjPvMKnIfJzWos7QShcSitpwyrhL55yOMB-v$>
> Do you know where I can look for the equivalent PETSc commands? Thank you.
> Yes, this is described here:
> https://urldefense.us/v3/__https://petsc.org/main/manualpages/PC/PCHYPRE/__;!!G_uCfscf7eWS!fe84MxfHZLtDHZMk46RBJyizvPamDZ_ysHWfHCyD26Z_SGQv2oMDYu7yeAV_WtK5hoqAqUuepnGqGMxyA9Jy$
> <https://urldefense.us/v3/__https:/petsc.org/main/manualpages/PC/PCHYPRE/__;!!G_uCfscf7eWS!dM_jKT_vX0NCVNcY9XOTTUaTSW-TF2CgOkB2UDeZ2ztYXapdmLlSBT4XhV7PknN3ewygGWDbKFEP9e0RfePC$>
> The best way is to run with -help or look at the source.
> Thanks,
> Matt
> Kind regards,
> Karthik.
> *From: *Matthew Knepley <knepley at gmail.com>
> *Date: *Friday, 6 September 2024 at 17:57
> *To: *Chockalingam, Karthikeyan (STFC,DL,HC) <
> *Cc: *petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
> On Fri, Sep 6, 2024 at 11:37 AM Karthikeyan Chockalingam - STFC UKRI via
> petsc-users <petsc-users at mcs.anl.gov> wrote:
> Hello,
> I am trying to use the Hypre AMS preconditioner for the first time.
> I am following the example problem from Hypre
> https://urldefense.us/v3/__https://github.com/hypre-space/hypre/blob/3caa81955eb8d1b4e35d9b450e27cf6d07b50f6e/src/examples/ex15.c*L954__;Iw!!G_uCfscf7eWS!fe84MxfHZLtDHZMk46RBJyizvPamDZ_ysHWfHCyD26Z_SGQv2oMDYu7yeAV_WtK5hoqAqUuepnGqGAi69yc_$
> <https://urldefense.us/v3/__https:/github.com/hypre-space/hypre/blob/3caa81955eb8d1b4e35d9b450e27cf6d07b50f6e/src/examples/ex15.c*L954__;Iw!!G_uCfscf7eWS!biuCOXkV-qD-e8iTXiwaD9XJ0EWuqr2PidZJdPqbnFzCshQFo-mclGSvGBOPuGSTkjPvMKnIfJzWos7QShcSitpwyrhL5ySgA0XM$>
> I have so far successfully set the discrete gradient operator and vertex
> co-ordinates,
> par_zvec);
> Do I need to set the following smoothing options?
> It cannot hurt. I would set them to begin with.
> Also, do I need to convert from MATMPIAIJ to CSR?
> https://urldefense.us/v3/__https://github.com/hypre-space/hypre/blob/3caa81955eb8d1b4e35d9b450e27cf6d07b50f6e/src/examples/ex15.c*L984__;Iw!!G_uCfscf7eWS!fe84MxfHZLtDHZMk46RBJyizvPamDZ_ysHWfHCyD26Z_SGQv2oMDYu7yeAV_WtK5hoqAqUuepnGqGC8cELGt$
> <https://urldefense.us/v3/__https:/github.com/hypre-space/hypre/blob/3caa81955eb8d1b4e35d9b450e27cf6d07b50f6e/src/examples/ex15.c*L984__;Iw!!G_uCfscf7eWS!biuCOXkV-qD-e8iTXiwaD9XJ0EWuqr2PidZJdPqbnFzCshQFo-mclGSvGBOPuGSTkjPvMKnIfJzWos7QShcSitpwyrhL53Trv1si$>
> No.
> What are the other PETSc calls to invoke AMS? Is there an example problem
> I can look at?
> I do not know. I don't think we have an example.
> Thanks,
> Matt
> Thank you.
> Karthik.
> *Karthik Chockalingam, Ph.D.*
> Senior Research Software Engineer
> High Performance Systems Engineering Group
> Hartree Centre | Science and Technology Facilities Council
> [image: signature_3970890138]
> experiments lead.
> -- Norbert Wiener
> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!fe84MxfHZLtDHZMk46RBJyizvPamDZ_ysHWfHCyD26Z_SGQv2oMDYu7yeAV_WtK5hoqAqUuepnGqGD2aXdkU$
> <https://urldefense.us/v3/__http:/www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!dM_jKT_vX0NCVNcY9XOTTUaTSW-TF2CgOkB2UDeZ2ztYXapdmLlSBT4XhV7PknN3ewygGWDbKFEP9ZyhqOzc$>
> experiments lead.
> -- Norbert Wiener
> Stefano
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!fe84MxfHZLtDHZMk46RBJyizvPamDZ_ysHWfHCyD26Z_SGQv2oMDYu7yeAV_WtK5hoqAqUuepnGqGD2aXdkU$ <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!fe84MxfHZLtDHZMk46RBJyizvPamDZ_ysHWfHCyD26Z_SGQv2oMDYu7yeAV_WtK5hoqAqUuepnGqGFaA00n5$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240909/fc66aead/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240909/fc66aead/attachment-0001.png>
