[petsc-users] Unable to configure errors
Stefano Zampini
stefano.zampini at gmail.com
Mon Nov 25 11:11:18 CST 2024
Send configure.log
On Mon, Nov 25, 2024, 20:09 Brian Bainbridge - BGS via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hi there,
> I have downloaded petsc-.3.22.1 via git, but when I try to configure with
> the Intel compilers I get this message:
> [bba at kwvmxbridgeHPC petsc]$ ./configure --prefix=/home/bba/bin/petsc
> --with-mpi-dir=/home/bba/intel/oneapi/mpi/2021.14/
> Configuring PETSc to compile on your system
> TESTING: checkCCompiler from
> config.setCompilers(config/BuildSystem/config/setCompilers.py:1457)
> UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for
> details):
> MPI compiler wrappers in /home/bba/intel/oneapi/mpi/2021.14/bin cannot
> be found or do not
> work. See https://urldefense.us/v3/__https://petsc.org/release/faq/*invalid-mpi-compilers__;Iw!!G_uCfscf7eWS!YuP2JPBRwPMjW-R0DlunxcaYcHx0zjy7uFz7aEsu_9Gj38klN7GMx7OmcFwbU9-V3EPvLhVEp9S0DLbjdZVNjgJ5KgODGVQ$
> <https://urldefense.us/v3/__https://petsc.org/release/faq/*invalid-mpi-compilers__;Iw!!G_uCfscf7eWS!bfBTBf0cnZ3REM41nHH1ecadhkhaOZ6Rj28ZmTt_QbyHuPvU3zdMDIVstg8C0aON_dJ-vLme96MmkQ_-tKw$>
> But:
> [bba at kwvmxbridgeHPC petsc]$ ls /home/bba/intel/oneapi/mpi/2021.14/bin
> cpuinfo hydra_nameserver IMB-MPI1 IMB-MT IMB-P2P
> impi_cpuinfo mpicc mpiexec mpif77 mpifc mpigxx mpiicpc
> mpiicx mpiifx mpitune_fast
> hydra_bstrap_proxy hydra_pmi_proxy IMB-MPI1-GPU IMB-NBC IMB-RMA
> impi_info mpicxx mpiexec.hydra mpif90 mpigcc mpiicc mpiicpx
> mpiifort mpirun
> So it should work, but it doesn't! I tried to use
> --with-cc=/home/bba/intel/oneapi/mpi/2021.14/bin/mpiicx
> but that doesn't work:
> details):
> C compiler you provided with
> cannot be found or does not work.
> If the above linker messages do not indicate failure of the compiler you
> can rerun with
> the option --ignoreLinkOutput=1
> The compiler is there, can you please help me to configure the petsc
> please?
> Regards,
> Brian
> This email and any attachments are intended solely for the use of the
> named recipients. If you are not the intended recipient you must not use,
> disclose, copy or distribute this email or any of its attachments and
> should notify the sender immediately and delete this email from your
> system. UK Research and Innovation (UKRI) has taken every reasonable
> precaution to minimise risk of this email or any attachments containing
> viruses or malware but the recipient should carry out its own virus and
> malware checks before opening the attachments. UKRI does not accept any
> liability for any losses or damages which the recipient may sustain due to
> presence of any viruses.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20241125/dd2cf9d9/attachment-0001.html>
