[petsc-users] Unable to configure errors
Satish Balay balay.anl at fastmail.org
Mon Nov 25 11:13:32 CST 2024
Please check: "Intel MPI" section of https://urldefense.us/v3/__https://petsc.org/release/install/install/*mpi__;Iw!!G_uCfscf7eWS!efneLerzMMPsXXWgEwlvn6Pdk_8YCIiz8n_VrMaeIB4E4gWzmx9BZKrY5NGR48MVdQ60BU43oXs8ZhXN5BIN9zu690s$   - Likely you need to correctly set I_MPI_CC etc. for the MPI compiler wrappers to work.
If you still have issues -  send configure.log from this failure.
Satish
On Mon, 25 Nov 2024, Brian Bainbridge - BGS via petsc-users wrote:
> Hi there,
> I have downloaded petsc-.3.22.1 via git, but when I try to configure with the Intel compilers I get this message:
> [bba at kwvmxbridgeHPC petsc]$ ./configure --prefix=/home/bba/bin/petsc --with-mpi-dir=/home/bba/intel/oneapi/mpi/2021.14/
>                          Configuring PETSc to compile on your system
> TESTING: checkCCompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:1457)
>            UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for details):
>   MPI compiler wrappers in /home/bba/intel/oneapi/mpi/2021.14/bin cannot be found or do not
>   work. See https://urldefense.us/v3/__https://petsc.org/release/faq/*invalid-mpi-compilers__;Iw!!G_uCfscf7eWS!bfBTBf0cnZ3REM41nHH1ecadhkhaOZ6Rj28ZmTt_QbyHuPvU3zdMDIVstg8C0aON_dJ-vLme96MmkQ_-tKw$
> But:
> [bba at kwvmxbridgeHPC petsc]$ ls /home/bba/intel/oneapi/mpi/2021.14/bin
> cpuinfo             hydra_nameserver  IMB-MPI1      IMB-MT   IMB-P2P  impi_cpuinfo  mpicc   mpiexec        mpif77  mpifc   mpigxx  mpiicpc  mpiicx    mpiifx  mpitune_fast
> hydra_bstrap_proxy  hydra_pmi_proxy   IMB-MPI1-GPU  IMB-NBC  IMB-RMA  impi_info     mpicxx  mpiexec.hydra  mpif90  mpigcc  mpiicc  mpiicpx  mpiifort  mpirun
> So it should work, but it doesn't! I tried to use --with-cc=/home/bba/intel/oneapi/mpi/2021.14/bin/mpiicx
> but that doesn't work:
> [bba at kwvmxbridgeHPC petsc]$ ./configure --prefix=/home/bba/bin/petsc --with-cc=/home/bba/intel/oneapi/mpi/2021.14/bin/mpiicx
>   C compiler you provided with -with-cc=/home/bba/intel/oneapi/mpi/2021.14/bin/mpiicx
>   cannot be found or does not work.
>   If the above linker messages do not indicate failure of the compiler you can rerun with
>   the option --ignoreLinkOutput=1
> [bba at kwvmxbridgeHPC petsc]$ ls /home/bba/intel/oneapi/mpi/2021.14/bin/mpiicx
> The compiler is there, can you please help me to configure the petsc please?
> Regards,
> Brian
> This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses.
