[petsc-users] Unable to configure errors
Brian Bainbridge - BGS
bba at bgs.ac.uk
Mon Nov 25 05:08:09 CST 2024
Hi there,
I have downloaded petsc-.3.22.1 via git, but when I try to configure with the Intel compilers I get this message:
[bba at kwvmxbridgeHPC petsc]$ ./configure --prefix=/home/bba/bin/petsc --with-mpi-dir=/home/bba/intel/oneapi/mpi/2021.14/
Configuring PETSc to compile on your system
TESTING: checkCCompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:1457)
UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for details):
MPI compiler wrappers in /home/bba/intel/oneapi/mpi/2021.14/bin cannot be found or do not
work. See https://urldefense.us/v3/__https://petsc.org/release/faq/*invalid-mpi-compilers__;Iw!!G_uCfscf7eWS!bfBTBf0cnZ3REM41nHH1ecadhkhaOZ6Rj28ZmTt_QbyHuPvU3zdMDIVstg8C0aON_dJ-vLme96MmkQ_-tKw$
But:
[bba at kwvmxbridgeHPC petsc]$ ls /home/bba/intel/oneapi/mpi/2021.14/bin
cpuinfo hydra_nameserver IMB-MPI1 IMB-MT IMB-P2P impi_cpuinfo mpicc mpiexec mpif77 mpifc mpigxx mpiicpc mpiicx mpiifx mpitune_fast
hydra_bstrap_proxy hydra_pmi_proxy IMB-MPI1-GPU IMB-NBC IMB-RMA impi_info mpicxx mpiexec.hydra mpif90 mpigcc mpiicc mpiicpx mpiifort mpirun
So it should work, but it doesn't! I tried to use --with-cc=/home/bba/intel/oneapi/mpi/2021.14/bin/mpiicx
but that doesn't work:
[bba at kwvmxbridgeHPC petsc]$ ./configure --prefix=/home/bba/bin/petsc --with-cc=/home/bba/intel/oneapi/mpi/2021.14/bin/mpiicx
C compiler you provided with -with-cc=/home/bba/intel/oneapi/mpi/2021.14/bin/mpiicx
cannot be found or does not work.
If the above linker messages do not indicate failure of the compiler you can rerun with
the option --ignoreLinkOutput=1
[bba at kwvmxbridgeHPC petsc]$ ls /home/bba/intel/oneapi/mpi/2021.14/bin/mpiicx
The compiler is there, can you please help me to configure the petsc please?
Brian
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20241125/5ae2c39c/attachment.html>
