[petsc-users] Memory Used When Reading petscrc
David Scott d.scott at epcc.ed.ac.uk
Mon Nov 25 03:49:02 CST 2024
Fabian,
That is indeed a typo. Thanks very much for pointing it out.
Cheers,
David
On 25/11/2024 08:45, Fabian.Jakub via petsc-users wrote:
> This email was sent to you by someone outside the University.
> You should only click on links or attachments if you are certain that
> the email is genuine and the content is safe.
> test_configuration_options.F90:l.55
> max_msg_length is quite large.... I guess the pow() is a typo.
> Cheers,
> Fabian
> On 11/25/24 09:32, David Scott wrote:
>> I'll have a look at heaptrack.
>> The code that I am looking at the moment does not create a mesh. All it
>> does is read a petscrc file.
>> Thanks,
>> David
>>> You're clearly doing almost all your allocation *not* using
>>> PetscMalloc (so not in a Vec or Mat). If you're managing your own mesh
>>> yourself, you might be allocating a global amount on each rank,
>>> instead of strictly using scalable data structures (i.e., always
>>> partitioned).
>>> My favorite tool for understanding memory use is heaptrack.
>>> https://urldefense.us/v3/__https://github.com/KDE/heaptrack__;!!G_uCfscf7eWS!bM8Vs5Ljq0ZJOl_Zl88PpU1JJWw39UMiu50wgyt0zhG4ax6DxOvabmaDYbKrrCATTeWrKDmDR5C-3bDziLRcXp30NMQ$
>>> David Scott <d.scott at epcc.ed.ac.uk> writes:
>>>> OK.
>>>> I had started to wonder if that was the case. I'll do some further
>>>> investigation.
>>>> Thanks,
>>>> David
>>>>> On Fri, Nov 22, 2024 at 12:57 PM David Scott <d.scott at epcc.ed.ac.uk>
>>>>> wrote:
>>>>>      Matt,
>>>>>      Thanks for the quick response.
>>>>>      Yes 1) is trivially true.
>>>>>      With regard to 2), from the SLURM output:
>>>>>      [0] Maximum memory PetscMalloc()ed 29552 maximum size of entire
>>>>>      process 4312375296
>>>>>      [1] Maximum memory PetscMalloc()ed 29552 maximum size of entire
>>>>>      process 4311990272
>>>>>      Yes only 29KB was malloced but the total figure was 4GB per
>>>>> process.
>>>>>      Looking at
>>>>>       mem0 =    16420864.000000000
>>>>>       mem0 =    16117760.000000000
>>>>>       mem1 =    4311490560.0000000
>>>>>       mem1 =    4311826432.0000000
>>>>>       mem2 =    4311490560.0000000
>>>>>       mem2 =    4311826432.0000000
>>>>>      mem0 is written after PetscInitialize.
>>>>>      mem1 is written roughly half way through the options being read.
>>>>>      mem2 is written on completion of the options being read.
>>>>>      The code does very little other than read configuration options.
>>>>>      Why is so much memory used?
>>>>> This is not due to options processing, as that would fall under Petsc
>>>>> malloc allocations. I believe we are measuring this
>>>>> using RSS which includes the binary, all shared libraries which are
>>>>> paged in, and stack/heap allocations. I think you are
>>>>> seeing the shared libraries come in. You might be able to see all the
>>>>> libraries that come in using strace.
>>>>>    Thanks,
>>>>>       Matt
>>>>>      I do not understand what is going on and I may have expressed
>>>>>      myself badly but I do have a problem as I certainly cannot use
>>>>>      anywhere near 128 processes on a node with 128GB of RAM before I
>>>>>      get an OOM error. (The code runs successfully on 32 processes
>>>>> but
>>>>>      not 64.)
>>>>>      Regards,
>>>>>      David
>>>>>> certain
>>>>>>      that the email is genuine and the content is safe.
>>>>>>      On Fri, Nov 22, 2024 at 11:36 AM David Scott
>>>>>>      <d.scott at epcc.ed.ac.uk> wrote:
>>>>>>          Hello,
>>>>>>          I am using the options mechanism of PETSc to configure
>>>>>> my CFD
>>>>>>          code. I
>>>>>>          have introduced options describing the size of the domain
>>>>>>          etc. I have
>>>>>>          noticed that this consumes a lot of memory. I have found
>>>>>> that
>>>>>>          the amount
>>>>>>          of memory used scales linearly with the number of MPI
>>>>>>          processes used.
>>>>>>          This restricts the number of MPI processes that I can use.
>>>>>>      There are two statements:
>>>>>>      1) The memory scales linearly with P
>>>>>>      2) This uses a lot of memory
>>>>>>      Let's deal with 1) first. This seems to be trivially true. If I
>>>>>>      want every process to have
>>>>>>      access to a given option value, that option value must be in
>>>>>> the
>>>>>>      memory of every process.
>>>>>>      The only alternative would be to communicate with some
>>>>>> process in
>>>>>>      order to get values.
>>>>>>      Few codes seem to be willing to make this tradeoff, and we
>>>>>> do not
>>>>>>      offer it.
>>>>>>      Now 2). Looking at the source, for each option we store
>>>>>>      a PetscOptionItem, which I count
>>>>>>      as having size 37 bytes (12 pointers/ints and a char). However,
>>>>>>      there is data behind every
>>>>>>      pointer, like the name, help text, available values
>>>>>> (sometimes),
>>>>>>      I could see it being as large
>>>>>>      as 4K. Suppose it is. If I had 256 options, that would be
>>>>>> 1M. Is
>>>>>>      this a large amount of memory?
>>>>>>      The way I read the SLURM output, 29K was malloced. Is this a
>>>>>>      I am trying to get an idea of the scale.
>>>>>>        Thanks,
>>>>>>            Matt
>>>>>>          Is there anything that I can do about this or do I need to
>>>>>>          configure my
>>>>>>          code in a different way?
>>>>>>          I have attached some code extracted from my application
>>>>>> which
>>>>>>          demonstrates this along with the output from a running
>>>>>> it on
>>>>>>          2 MPI
>>>>>>          processes.
>>>>>>          Best wishes,
>>>>>>          David Scott
>>>>>>          The University of Edinburgh is a charitable body,
>>>>>> registered
>>>>>>          in Scotland, with registration number SC005336. Is e
>>>>>>          buidheann carthannais a th’ ann an Oilthigh Dhùn Èideann,
>>>>>>          clàraichte an Alba, àireamh clàraidh SC005336.
>>>>>>      What most experimenters take for granted before they begin
>>>>>> their
>>>>>>      experiments is infinitely more interesting than any results to
>>>>>>      which their experiments lead.
>>>>>>      -- Norbert Wiener
>>>>>> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!cH8SjJvsuVEK1zv8noUjNUJC0VnHFqems68PjB2E94pqxc3q55YprX1q2JXFvPAzXJkh40J1-erXPWdIvc-xrLkRIgg$
>>>>>> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!cH8SjJvsuVEK1zv8noUjNUJC0VnHFqems68PjB2E94pqxc3q55YprX1q2JXFvPAzXJkh40J1-erXPWdIvc-xGybRwKU$
>>>>> What most experimenters take for granted before they begin their
>>>>> experiments is infinitely more interesting than any results to which
>>>>> -- Norbert Wiener
