[petsc-users] duplicated libs
Runjian Wu wurunjian at gmail.com
Mon May 13 21:00:28 CDT 2024
Thanks for your reply!  Since I can manually remove duplicates, how about
adding a function to automatically remove duplicates at the end of
"configure" in the next PETSc version?
Runjian
On 5/13/2024 9:31 PM, Barry Smith wrote:
   Because the order of the libraries can be important, it is difficult for
./configure to remove unneeded duplicates automatically.
   You can manually remove duplicates by editing
$PETSC_ARCH/lib/petsc/conf/petscvariables after running ./configure
   Barry
On May 13, 2024, at 7:47 AM, Runjian Wu <wurunjian at gmail.com>
<wurunjian at gmail.com> wrote:
This Message Is From an External Sender
This message came from outside your organization.
Hi all,
After I compiled PETSc, I found some duplicated libs in the variable
PETSC_EXTERNAL_LIB_BASIC, e.g., -lm, -lgfortran -lstdc++.  I am curious how
it happened and how to remove the duplicates?
Runjian Wu
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240514/83e6f7f0/attachment.html>
