[petsc-users] duplicated libs
Barry Smith bsmith at petsc.dev
Mon May 13 21:34:25 CDT 2024
  It is not always safe to remove duplicate libraries listed in different places in the list. Hence we cannot simply always remove them.
  Barry
> On May 13, 2024, at 10:00 PM, Runjian Wu <wurunjian at gmail.com> wrote:
> Thanks for your reply!  Since I can manually remove duplicates, how about adding a function to automatically remove duplicates at the end of "configure" in the next PETSc version?
> Runjian
> On 5/13/2024 9:31 PM, Barry Smith wrote:
>>    Because the order of the libraries can be important, it is difficult for ./configure to remove unneeded duplicates automatically.
>>    You can manually remove duplicates by editing $PETSC_ARCH/lib/petsc/conf/petscvariables after running ./configure
>>    Barry
>>> On May 13, 2024, at 7:47 AM, Runjian Wu <wurunjian at gmail.com> <mailto:wurunjian at gmail.com> wrote:
>>> This Message Is From an External Sender
>>> This message came from outside your organization.
>>> Hi all,
>>> After I compiled PETSc, I found some duplicated libs in the variable PETSC_EXTERNAL_LIB_BASIC, e.g., -lm, -lgfortran -lstdc++.  I am curious how it happened and how to remove the duplicates?
>>> Thanks,
>>> Runjian Wu
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240513/a8da1917/attachment.html>
