[petsc-users] duplicated libs
Barry Smith
bsmith at petsc.dev
Mon May 13 08:31:45 CDT 2024
Because the order of the libraries can be important, it is difficult for ./configure to remove unneeded duplicates automatically.
You can manually remove duplicates by editing $PETSC_ARCH/lib/petsc/conf/petscvariables after running ./configure
Barry
> On May 13, 2024, at 7:47 AM, Runjian Wu <wurunjian at gmail.com> wrote:
> This Message Is From an External Sender
> This message came from outside your organization.
> Hi all,
> After I compiled PETSc, I found some duplicated libs in the variable PETSC_EXTERNAL_LIB_BASIC, e.g., -lm, -lgfortran -lstdc++. I am curious how it happened and how to remove the duplicates?
> Thanks,
> Runjian Wu
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240513/3561fe56/attachment-0001.html>
