[petsc-users] [EXTERNAL] Re: Is there anything like a "DMPlexSetCones()" ?
Ferrand, Jesus A.
FERRANJ2 at my.erau.edu
Fri May 3 18:32:28 CDT 2024
"Right, but that means that the connectivity you read in is not in local numbering. You will have to renumber it, so making a copy is probably necessary anyway. This is the same sort of processing I do for the parallel read."
True, the connectivity is read in global numbering.
Renumbering is facilitated by the table from PetscHashSetI.
The connectivity list I am able to renumber in place though, I don't see the need to have another interim copy of the numbers.
My concern is that I have two memory chunks that both contain the same information.
The only reason It has to be this way is because I can't manually set the Cones first and the Chart/ConeSizes second.
Sent: Friday, May 3, 2024 6:45 PM
To: Ferrand, Jesus A. <FERRANJ2 at my.erau.edu>
Cc: petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
Subject: Re: [EXTERNAL] Re: [petsc-users] Is there anything like a "DMPlexSetCones()" ?
On Wed, May 1, 2024 at 6:30 PM Ferrand, Jesus A. <FERRANJ2 at my.erau.edu<mailto:FERRANJ2 at my.erau.edu>> wrote:
"You know the number of cells if you can read connectivity. Do you mean that the format does not tell you
the number of vertices?"
Sort of...
So, the format does provide the number of vertices, however, due to the way I read the data in parallel I don't know immediately how many local vertices there will be.
Which prevents me from knowing the chart a priori.
I figured out the number of vertices using PetscHashSetI to determine the number of unique entries in the connectivity list.
Matt
From: Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>>
Sent: Wednesday, May 1, 2024 8:52 PM
To: Ferrand, Jesus A. <FERRANJ2 at my.erau.edu<mailto:FERRANJ2 at my.erau.edu>>
Cc: petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov> <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>
On Wed, May 1, 2024 at 4:23 PM Ferrand, Jesus A. <FERRANJ2 at my.erau.edu<mailto:FERRANJ2 at my.erau.edu>> wrote:
Matt:
My bad again, I need to clarify something that I just realized doesn't make sense.
I said: "The nature of the I/O makes it so that I need to read the connectivity before I get a semblance of buffer sizes."
Scratch that, obviously, if I can read the connectivity, I know the buffer sizes.
What I should have said is that I cannot know the "chart" that one sets in DMPlexSetChart() a priori like in most cases.
I need to determine the chart from the connectivity lists.
Matt
From: Ferrand, Jesus A. <FERRANJ2 at my.erau.edu<mailto:FERRANJ2 at my.erau.edu>>
Sent: Wednesday, May 1, 2024 8:17 PM
To: Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>>
Matt:
"I do not understand the "flag check". What is that?"
My bad, I should have referred to the "dm->setupcalled".
I believe this PetscBool is checked by the other DM (not just DMPlex) APIs.
The subsequent checks for dm->setupcalled == PETSC_TRUE is what I meant to say.
Here's a copy of DMSetUp().
PetscErrorCode<https://urldefense.us/v3/__https://petsc.org/release/manualpages/Sys/PetscErrorCode/__;!!G_uCfscf7eWS!c7KVr76YJDliUdUPWmCJIBMhcOTynQ-nax52ZuOkqzWsuI1Lfvv-6S8PGQIjKS_Fru4T84MO2sYpAORILP_FPofG4yo$ > DMSetUp<https://urldefense.us/v3/__https://petsc.org/release/manualpages/DM/DMSetUp/__;!!G_uCfscf7eWS!c7KVr76YJDliUdUPWmCJIBMhcOTynQ-nax52ZuOkqzWsuI1Lfvv-6S8PGQIjKS_Fru4T84MO2sYpAORILP_FyFaICEE$ >(DM<https://urldefense.us/v3/__https://petsc.org/release/manualpages/DM/DM/__;!!G_uCfscf7eWS!c7KVr76YJDliUdUPWmCJIBMhcOTynQ-nax52ZuOkqzWsuI1Lfvv-6S8PGQIjKS_Fru4T84MO2sYpAORILP_FQYYUzqg$ > dm)
817: {
818: PetscFunctionBegin<https://urldefense.us/v3/__https://petsc.org/release/manualpages/Sys/PetscFunctionBegin/__;!!G_uCfscf7eWS!c7KVr76YJDliUdUPWmCJIBMhcOTynQ-nax52ZuOkqzWsuI1Lfvv-6S8PGQIjKS_Fru4T84MO2sYpAORILP_Fj5e8nKA$ >;
820: if (dm->setupcalled) PetscFunctionReturn<https://urldefense.us/v3/__https://petsc.org/release/manualpages/Sys/PetscFunctionReturn/__;!!G_uCfscf7eWS!c7KVr76YJDliUdUPWmCJIBMhcOTynQ-nax52ZuOkqzWsuI1Lfvv-6S8PGQIjKS_Fru4T84MO2sYpAORILP_F3nt7akM$ >(PETSC_SUCCESS<https://urldefense.us/v3/__https://petsc.org/release/manualpages/Sys/PetscErrorCode/__;!!G_uCfscf7eWS!c7KVr76YJDliUdUPWmCJIBMhcOTynQ-nax52ZuOkqzWsuI1Lfvv-6S8PGQIjKS_Fru4T84MO2sYpAORILP_FPofG4yo$ >);
821: PetscTryTypeMethod<https://urldefense.us/v3/__https://petsc.org/release/manualpages/Sys/PetscTryTypeMethod/__;!!G_uCfscf7eWS!c7KVr76YJDliUdUPWmCJIBMhcOTynQ-nax52ZuOkqzWsuI1Lfvv-6S8PGQIjKS_Fru4T84MO2sYpAORILP_F0IpLYJM$ >(dm, setup);
822: dm->setupcalled = PETSC_TRUE<https://urldefense.us/v3/__https://petsc.org/release/manualpages/Sys/PETSC_TRUE/__;!!G_uCfscf7eWS!c7KVr76YJDliUdUPWmCJIBMhcOTynQ-nax52ZuOkqzWsuI1Lfvv-6S8PGQIjKS_Fru4T84MO2sYpAORILP_FQlTgBws$ >;
823: PetscFunctionReturn<https://urldefense.us/v3/__https://petsc.org/release/manualpages/Sys/PetscFunctionReturn/__;!!G_uCfscf7eWS!c7KVr76YJDliUdUPWmCJIBMhcOTynQ-nax52ZuOkqzWsuI1Lfvv-6S8PGQIjKS_Fru4T84MO2sYpAORILP_F3nt7akM$ >(PETSC_SUCCESS<https://urldefense.us/v3/__https://petsc.org/release/manualpages/Sys/PetscErrorCode/__;!!G_uCfscf7eWS!c7KVr76YJDliUdUPWmCJIBMhcOTynQ-nax52ZuOkqzWsuI1Lfvv-6S8PGQIjKS_Fru4T84MO2sYpAORILP_FPofG4yo$ >);
824: }
"We could make a DMPlexSetCones(), but as you point out, the workflow for DMSetUp() would have to change. Where does the memory come from for your connectivity?"
It's a memory that I myself allocate based on a file's contents.
Otherwise, I would stick to the tried and tested way.
Also, when replying to the PETSc developers, users must reply to petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov> and not just to the individual email accounts of the developers, right?
Sent: Wednesday, May 1, 2024 8:07 PM
Subject: [EXTERNAL] Re: [petsc-users] Is there anything like a "DMPlexSetCones()" ?
CAUTION: This email originated outside of Embry-Riddle Aeronautical University. Do not click links or open attachments unless you recognize the sender and know the content is safe.
On Wed, May 1, 2024 at 3:34 PM Ferrand, Jesus A. <FERRANJ2 at my.erau.edu<mailto:FERRANJ2 at my.erau.edu>> wrote:
This Message Is From an External Sender
This message came from outside your organization.
Dear PETSc team:
For a project that I'm working on, I need to manually build a DMPlex.
>From studying the source code of the various APIs in which the plex is built from some supported file format, I get that the workflow is this:
1.
DMPlexSetChart() <-- Input nCells + nVerts
2.
DMPlexSetConeSize() <-- Input ConeSize for each point in [0,nCells)
3.
DMSetUp() – Allocates memory internally.
4.
DMPlexGetCones() --> Gives you the memory onto which to write the cell connectivity.
5.
*Write connectivity*
6.
DMPlexReorderCell() <-- For each point in [0,nCells)
I'm in a situation where the memory given by step (4) is available a-priori.
I was hoping to skip steps 2, 3 , and 4 with something like a "DMPlexSetCones()", but such an API does not exist.
My current workaround is to implement steps 2 through 4 as always and have double the memory allocated in the interim (my instance + DM's internal instance).
I was thinking of looking for the name of the struct member and = it to my memory, but I can't overcome the flag check in DMSetUp() during later calls to DMPlexGetCones() or DMPlexGetTransitiveClosure().
Matt
Sincerely:
J.A. Ferrand
Embry-Riddle Aeronautical University - Daytona Beach - FL
Ph.D. Candidate, Aerospace Engineering
M.Sc. Aerospace Engineering
B.Sc. Aerospace Engineering
B.Sc. Computational Mathematics
Phone: (386)-843-1829
Email(s): ferranj2 at my.erau.edu<mailto:ferranj2 at my.erau.edu>
jesus.ferrand at gmail.com<mailto:jesus.ferrand at gmail.com>
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!c7KVr76YJDliUdUPWmCJIBMhcOTynQ-nax52ZuOkqzWsuI1Lfvv-6S8PGQIjKS_Fru4T84MO2sYpAORILP_FzJbeQPY$ <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!c7KVr76YJDliUdUPWmCJIBMhcOTynQ-nax52ZuOkqzWsuI1Lfvv-6S8PGQIjKS_Fru4T84MO2sYpAORILP_FptlwNDw$ >
Dear PETSc team:
1.
2.
3.
4.
5.
6.
Matt
Sincerely:
J.A. Ferrand
-- Norbert Wiener
-- Norbert Wiener
Matt:
Matt
Matt:
817: {
824: }
Dear PETSc team:
1.
2.
3.
4.
5.
6.
Matt
Sincerely:
J.A. Ferrand
-- Norbert Wiener
Dear PETSc team:
1.
2.
3.
4.
5.
6.
Matt
Sincerely:
J.A. Ferrand
-- Norbert Wiener
-- Norbert Wiener
-- Norbert Wiener
Sort of...
Matt
Matt:
Matt
Matt:
817: {
824: }
Dear PETSc team:
1.
2.
3.
4.
5.
6.
Matt
Sincerely:
J.A. Ferrand
-- Norbert Wiener
Dear PETSc team:
1.
2.
3.
4.
5.
6.
Matt
Sincerely:
J.A. Ferrand
-- Norbert Wiener
-- Norbert Wiener
Matt:
Matt
Matt:
817: {
824: }
Dear PETSc team:
1.
2.
3.
4.
5.
6.
Matt
Sincerely:
J.A. Ferrand
-- Norbert Wiener
Dear PETSc team:
1.
2.
3.
4.
5.
6.
Matt
Sincerely:
J.A. Ferrand
-- Norbert Wiener
-- Norbert Wiener
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240503/8d14b2ac/attachment-0001.html>
